node-red-contrib-periph-memory 1.5.2
Node-RED nodes for memory chips
Node-RED nodes for memory chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-memory.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-memory
| Node | Kind | Description |
23x1024-device |
config | Bus configuration for a 23X1024 |
23x1024 |
input | Reads, writes and fills a 23LC1024 / 23A1024 1-Mbit (128 KiB) SPI serial SRAM, and selects its operating mode. |
24aa02uid-device |
config | I²C bus and address for a 24AA02UID |
24aa02uid |
input | Reads the factory-programmed 32-bit unique serial number from a 24AA02UID EEPROM, or reads / writes user EEPROM bytes, over I²C. |
at24c02n-device |
config | I²C bus and address for an AT24C02N |
at24c02n |
input | Reads, writes and fills the 256 B EEPROM of an AT24C02N over I²C. Writes are split at 8-byte page boundaries and ACK-polled until each write cycle (5 ms max) has finished. |
at24c64-device |
config | I²C bus and address for an AT24C64 |
at24c64 |
input | Reads, writes and fills the 8 KiB EEPROM of an AT24C64 over I²C. Writes are split at 32-byte page boundaries and ACK-polled until each write cycle (10 ms max (20 ms at 1.8 V)) has finished. |
cat24c512-device |
config | I²C bus and address for a CAT24C512 |
cat24c512 |
input | Reads, writes and fills the 64 KiB EEPROM of a CAT24C512 over I²C. Writes are split at 128-byte page boundaries and ACK-polled until each write cycle (5 ms max) has finished. |
mb85rc-device |
config | I²C bus and address for a MB85RC |
mb85rc |
input | Reads, writes and fills the 32 KiB non-volatile FRAM of an MB85RC256V over I²C. FRAM writes complete at bus speed — no write delay, no page limit. |
mx25l12845e-device |
config | Bus configuration for a MX25L12845E |
mx25l12845e |
input | Reads, writes and erases the 16 MiB Macronix MX25L12845E SPI NOR flash by byte address. Writes are erase-aware: the node erases a 4 KiB sector itself when bits must go from 0 to 1, and keeps the other bytes of that sector. There is no filesystem. |
sd-spi-device |
config | Bus configuration for a SD-SPI |
sd-spi |
input | Reads and writes raw 512-byte blocks of an SD / SDHC / SDXC / microSD card in SPI mode. There is no filesystem: blocks are addressed by number. |
