node-red-contrib-periph-led 1.5.2
Node-RED nodes for LED driver chips
Node-RED nodes for LED driver chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-led.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-led
| Node | Kind | Description |
apa102-device |
config | SPI bus and device index for an APA102 |
apa102 |
output | Controls an APA102 addressable RGB LED strip over SPI (synchronous two-wire protocol). |
ht16k33-device |
config | I²C bus and address for a HT16K33 |
ht16k33 |
input | Controls a HT16K33 16 × 8 LED matrix driver over I²C: set pixels, write the display RAM, change brightness and blink rate, and read the 13 × 3 key matrix. |
is31fl3731-device |
config | I²C bus and address for an IS31FL3731 |
is31fl3731 |
input | Controls an IS31FL3731 144-LED matrix driver (9 × 16, 8-bit PWM per LED) over I²C. The node draws into frame 1 in Picture mode. |
pca9685-device |
config | I²C bus and address for a PCA9685 |
pca9685 |
input | Controls the 16 PWM channels of a PCA9685 (12-bit, 24–1526 Hz) over I²C. |
sk6812rgbw-device |
config | SPI bus and device index for a SK6812RGBW |
sk6812rgbw |
output | Controls an SK6812RGBW addressable RGBW LED strip over SPI (NeoPixel protocol). |
ws2812b-device |
config | SPI bus and device index for a WS2812B |
ws2812b |
output | Controls a WS2812B addressable RGB LED strip over SPI (NeoPixel protocol). |
ws2814-device |
config | SPI bus and device index for a WS2814 |
ws2814 |
output | Controls a WS2814 addressable RGBW LED strip over SPI (NeoPixel protocol). |
