node-red-contrib-periph-io-expander 1.5.2
Node-RED nodes for IO expander chips
npm install node-red-contrib-periph-io-expander
Node-RED nodes for IO expander chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-io-expander.
Or from the command line in your Node-RED user directory:
Node Kind Description
mcp23008-device config I²C bus and address for a MCP23008
mcp23008 input Controls and reads an 8-bit MCP23008 (I²C) or MCP23S08 (SPI) I/O expander. Both chips share one register map and one node.
mcp23017-device config I²C bus and address for a MCP23017
mcp23017 input Controls and reads a 16-bit MCP23017 I/O expander over I²C.
pca6408a-device config I²C bus and address for a PCA6408A
pca6408a input Controls and reads an 8-bit PCA6408A I/O expander (I²C / SMBus, NXP). The chip has no internal pull-ups: inputs need external pull-up resistors.
pca6416a-device config I²C bus and address for a PCA6416A
pca6416a input Controls and reads a 16-bit PCA6416A I/O expander (I²C / SMBus, NXP). The chip has no internal pull-ups: inputs need external pull-up resistors.
pca9536-device config Bus configuration for a PCA9536
pca9536 input Controls and reads a 4-bit PCA9536 I/O expander (I²C / SMBus, TI). The chip has the fixed address 0x41 , no interrupt pin, and a weak (about 100 kΩ) pull-up that is always on each pin, so an open input reads 1.
pca9539-device config I²C bus and address for a PCA9539
pca9539 input Controls and reads a 16-bit PCA9539 I/O expander (I²C / SMBus, NXP). The chip has no internal pull-ups: inputs need external pull-up resistors.
pcf8574-device config I²C bus and address for a PCF8574
pcf8574 input Controls and reads an 8-bit PCF8574 I/O expander over I²C.
pcf8575-device config I²C bus and address for a PCF8575
pcf8575 input Controls and reads a 16-bit PCF8575 I/O expander over I²C.
tca9554-device config I²C bus and address for a TCA9554
tca9554 input Controls and reads an 8-bit TCA9554 I/O expander (I²C / SMBus, TI). Every input has a fixed internal 100 kΩ pull-up (always on).
tpic6b595-device config Bus configuration for a TPIC6B595
tpic6b595 input Drives a Texas Instruments TPIC6B595 8-bit power SIPO shift register (or multiple cascaded devices) through a SiPo (serial-in/parallel-out) connection. SER IN / SRCK may be either an SPI bus (hardware mode) or two plain GPIO lines (software / bit-bang mode); RCK is always a plain GPIO. Optional SRCLR and G lines add shift-register-clear and global output enable (PWM-style dimming).
Links
Version: 1.5.2
Updated 4 days ago
24 in the last week
  • mcp23008-device
  • mcp23008
  • mcp23017-device
  • mcp23017
  • pca6408a-device
  • pca6408a
  • pca6416a-device
  • pca6416a
  • pca9536-device
  • pca9536
  • pca9539-device
  • pca9539
  • pcf8574-device
  • pcf8574
  • pcf8575-device
  • pcf8575
  • tca9554-device
  • tca9554
  • tpic6b595-device
  • tpic6b595
  • io-expander
  • i2c
  • spi
  • peripheral
