node-red-contrib-periph-imu 1.5.2
Node-RED nodes for IMU chips
Node-RED nodes for IMU chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-imu.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-imu
| Node | Kind | Description |
bno055-device |
config | I²C bus and address for a BNO055 |
bno055 |
input | Reads the fused absolute orientation of a Bosch BNO055 9-axis sensor over I²C (0x29 with COM3 high, 0x28 with COM3 low). The chip stretches the I²C clock, so the host bus must support clock stretching. Allow up to about one second after deploying for the chip to boot. |
icm20948-device |
config | I²C bus and address for an ICM20948 |
icm20948 |
input | Reads acceleration, angular rate, die temperature and (optionally) the magnetic field from a TDK InvenSense ICM-20948 9-axis MotionTracking device over I²C. The AK09916 magnetometer is read through the chip's own I²C master, so only one I²C address is needed. VDDIO must be 1.71–1.95 V. |
mpu6050-device |
config | I²C bus and address for a MPU6050 |
mpu6050 |
input | Reads 3-axis acceleration and 3-axis angular rate from an MPU6050 IMU over I²C. |
mpu9250-device |
config | Bus configuration for a MPU9250 |
mpu9250 |
input | Reads bus voltage, load current, and power from an MPU-9250 9-axis MotionTracking device. |
mpu9255-device |
config | Bus configuration for a MPU9255 |
mpu9255 |
input | Reads acceleration and angular rate from an MPU-9255 9-axis MotionTracking device. |
qmi8658a-device |
config | I²C bus and address for a QMI8658A |
qmi8658a |
input | Reads acceleration, angular rate and die temperature from a QST QMI8658A 6-axis IMU over I²C (0x6B with SA0 = GND, 0x6A with SA0 = VDDIO) or 4-wire SPI. The three values come from one 14-byte burst, so they belong to the same sample. |
