node-red-contrib-periph-humidity 1.5.2
Node-RED nodes for humidity sensor chips
Node-RED nodes for humidity sensor chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-humidity.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-humidity
| Node | Kind | Description |
dht11-device |
config | Bus configuration for a DHT11 |
dht11 |
input | Reads temperature and humidity from a DHT11 sensor over a single GPIO data line. |
hdc1008-device |
config | I²C bus and address for a HDC1008 |
hdc1008 |
input | Reads temperature and relative humidity from a Texas Instruments HDC1008 over I²C (addresses 0x40–0x43) with one sequence measurement (temperature then humidity) per message. |
hdc1080-device |
config | I²C bus and address for a HDC1080 |
hdc1080 |
input | Reads temperature and relative humidity from a Texas Instruments HDC1080 over I²C (address 0x40) with one sequence measurement (temperature then humidity) per message. |
hs30xx-device |
config | I²C bus and address for a HS30XX |
hs30xx |
input | Reads temperature and relative humidity from a Renesas HS3001, HS3002 or HS3003 (the HS30xx family, one protocol) over I²C (fixed address 0x44) with one measurement per message. |
hs40xx-device |
config | I²C bus and address for a HS40XX |
hs40xx |
input | Reads temperature and relative humidity from a Renesas HS4001 or HS4003 (the HS40xx family, one protocol) over I²C (fixed address 0x54) with one no-hold measurement per message. HS4002 and the HS401x variants are physically different versions of the same part and are not offered separately. |
htu21df-device |
config | I²C bus and address for a HTU21DF |
htu21df |
input | Reads temperature and relative humidity from a Measurement Specialties HTU21D-F over I²C (fixed address 0x40) with one temperature and one humidity measurement per message. The CRC of both results is verified. |
sht31-device |
config | I²C bus and address for a SHT31 |
sht31 |
input | Reads temperature and relative humidity from a Sensirion SHT31 over I²C (0x44 with ADDR low, 0x45 with ADDR high) with one single-shot measurement per message. Both CRC bytes are verified. |
si7021-device |
config | I²C bus and address for a SI7021 |
si7021 |
input | Reads relative humidity and temperature from a Silicon Labs Si7021 over I²C (fixed address 0x40) with one relative-humidity measurement per message; the temperature comes from the same conversion. The CRC of the humidity result is verified. |
