node-red-contrib-periph-environmental 1.5.2
Node-RED nodes for environmental sensor chips
Node-RED nodes for environmental sensor chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-environmental.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-environmental
| Node | Kind | Description |
aht10-device |
config | I²C bus and address for an AHT10 |
aht10 |
input | Reads temperature and humidity from an AHT10 environmental sensor over I²C. |
aht20-device |
config | I²C bus and address for an AHT20 |
aht20 |
input | Reads temperature and humidity from an AHT20 environmental sensor over I²C. |
aht21-device |
config | I²C bus and address for an AHT21 |
aht21 |
input | Reads temperature and humidity from an AHT21 environmental sensor over I²C. |
am2315-device |
config | I²C bus and address for an AM2315 |
am2315 |
input | Reads temperature and relative humidity from an Aosong AM2315 over I²C (fixed address 0x5C). The sensor sleeps between transactions and returns the result of the previous measurement; the node keeps transactions at least 2 s apart, so a message arriving earlier is answered after the remaining delay. Every response is CRC-16 checked. |
am2320-device |
config | I²C bus and address for an AM2320 |
am2320 |
input | Reads temperature and relative humidity from an Aosong AM2320 over I²C (fixed address 0x5C). The sensor sleeps between transactions and returns the result of the previous measurement; the node keeps transactions at least 2 s apart, so a message arriving earlier is answered after the remaining delay. Every response is CRC-16 checked. |
bme280-device |
config | Bus configuration for a BME280 |
bme280 |
input | Reads temperature, pressure, humidity, altitude, and dew point from a BME280 combined humidity + pressure + temperature sensor. |
bme680-device |
config | Bus configuration for a BME680 |
bme680 |
input | Reads temperature, pressure, humidity, gas resistance, altitude, and dew point from a BME680 4-in-1 environmental sensor. |
