node-red-contrib-periph-comms 1.5.2
Node-RED nodes for communications peripheral chips
Node-RED nodes for communications peripheral chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-comms.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-comms
| Node | Kind | Description |
mcp2515-device |
config | Bus configuration for a MCP2515 |
mcp2515 |
input | Sends and receives CAN 2.0B frames with the Microchip MCP2515 stand-alone CAN controller over SPI. Supports standard (11-bit) and extended (29-bit) identifiers and 0–8 byte payloads. |
rda5807m-device |
config | I²C bus and address for a RDA5807M |
rda5807m |
input | Controls an RDA5807M single-chip FM stereo radio tuner over I²C: tune, seek, volume, and mute, with frequency/signal status on every trigger. |
rfm9x-device |
config | Bus configuration for a RFM9X |
rfm9x |
input | Sends and receives LoRa packets with the HopeRF RFM95/96/97/98W transceiver module over SPI. |
