node-red-contrib-periph-adc-dac 1.5.2
Node-RED nodes for ADC and DAC chips
Node-RED nodes for ADC and DAC chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-adc-dac.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-adc-dac
| Node | Kind | Description |
ad5243-device |
config | Bus configuration for an AD5243 |
ad5243 |
input | Sets and reads the two 256-position wipers of an AD5243 dual I²C digital potentiometer. Wiper values are volatile: both channels power up at midscale (128). |
ad5248-device |
config | I²C bus and address for an AD5248 |
ad5248 |
input | Sets or reads the two 256-position wipers of an AD5248 dual digital rheostat over I²C. The device is configured via an ad5248-device config node. |
ad5251-device |
config | I²C bus and address for an AD5251 |
ad5251 |
input | Sets and reads the two 64-position wipers of an AD5251 dual I²C digital potentiometer. Both channels power up from their stored EEMEM value (midscale, 32, until a value is stored). |
ad5252-device |
config | I²C bus and address for an AD5252 |
ad5252 |
input | Sets and reads the two 256-position wipers of an AD5252 dual I²C digital potentiometer. Both channels power up from their stored EEMEM value (midscale, 128, until a value is stored). |
ad7705-device |
config | Bus configuration for an AD7705 |
ad7705 |
input | Reads voltage from a 2-channel, 16-bit sigma-delta AD7705 ADC over SPI. The driver uses the chip's two-phase register-access protocol and polls DRDY over SPI, so only SCLK/DIN/DOUT/CS are needed (no dedicated DRDY GPIO). |
ad7706-device |
config | Bus configuration for an AD7706 |
ad7706 |
input | Reads voltage from a 3-channel, 16-bit sigma-delta AD7706 ADC over SPI. The driver uses the chip's two-phase register-access protocol and polls DRDY over SPI, so only SCLK/DIN/DOUT/CS are needed (no dedicated DRDY GPIO). All three channels share a single COMMON reference pin. |
ads1013-device |
config | I²C bus and address for an ADS1013 |
ads1013 |
input | Reads the voltage AIN0 − AIN1 from an ADS1013 12-bit ADC over I²C using a single-shot conversion. |
ads1014-device |
config | I²C bus and address for an ADS1014 |
ads1014 |
input | Reads the voltage AIN0 − AIN1 from an ADS1014 12-bit ADC over I²C using a single-shot conversion. |
ads1113-device |
config | I²C bus and address for an ADS1113 |
ads1113 |
input | Reads the ADS1113 16-bit ΔΣ ADC (one differential input (AIN0 − AIN1), fixed ±2.048 V) over I²C. Default address is 0x48 ; 0x48 – 0x4B are valid depending on the ADDR strap. |
ads1114-device |
config | I²C bus and address for an ADS1114 |
ads1114 |
input | Reads the ADS1114 16-bit ΔΣ ADC (one differential input (AIN0 − AIN1) with programmable gain) over I²C. Default address is 0x48 ; 0x48 – 0x4B are valid depending on the ADDR strap. |
ads1115-device |
config | I²C bus and address for an ADS1115 |
ads1115 |
input | Reads the ADS1115 16-bit ΔΣ ADC (four single-ended or two differential inputs with programmable gain) over I²C. Default address is 0x48 ; 0x48 – 0x4B are valid depending on the ADDR strap. |
ads7828-device |
config | I²C bus and address for an ADS7828 |
ads7828 |
input | Reads the 12-bit, 8-channel ADS7828 ADC over I²C as eight single-ended inputs or four differential pairs. Default address is 0x48 ; 0x48 – 0x4B are valid depending on the A1/A0 straps. With the internal 2.5 V reference the REFIN/REFOUT pin must be decoupled with 0.1 µF and nothing else may drive it. |
cat5171-device |
config | I²C bus and address for a CAT5171 |
cat5171 |
input | Sets and reads the 256-position wiper of a CAT5171 I²C digital potentiometer. The wiper is volatile: it powers up at midscale (128). |
cs43l22-device |
config | I²C bus and address for a CS43L22 |
cs43l22 |
input | Controls a CS43L22 stereo DAC with headphone and speaker amplifiers over its I²C control port. The audio stream (I²S: MCLK, SCLK, LRCK, SDIN) comes from the board and is not handled by this node. Send { start: true } only after MCLK is running. |
ds1881-device |
config | I²C bus and address for a DS1881 |
ds1881 |
input | Controls the two audio log-taper channels of a DS1881 dual digital potentiometer. Attenuation is in dB (0 dB = wiper at H); position 63 (Option 1) or 33 (Option 2) is mute. By default the wipers are volatile and power up at mute. |
ds3502-device |
config | I²C bus and address for a DS3502 |
ds3502 |
input | Sets and reads the 128-position wiper of a DS3502 high-voltage I²C digital potentiometer. Wiper writes go to SRAM only (MODE = 1) and never wear the EEPROM; the wiper powers up at the stored Initial Value Register position (factory default 64, midscale). |
es8311-device |
config | I²C bus and address for an ES8311 |
es8311 |
input | Controls an ES8311 low-power mono audio codec over its I²C control port. The audio stream itself (I²S) is not handled by this node. |
hx710a-device |
config | Bus configuration for a HX710A |
hx710a |
input | Reads weight from an HX710A 24-bit ADC connected to a load cell via two GPIO pins. Also exposes the chip's on-chip temperature sensor as a raw ADC code. |
hx710b-device |
config | Bus configuration for a HX710B |
hx710b |
input | Reads weight from an HX710B 24-bit ADC connected to a load cell via two GPIO pins. Also exposes the chip's DVDD-AVDD supply-voltage-difference channel as a raw ADC code for battery-monitoring applications. |
hx711-device |
config | Bus configuration for a HX711 |
hx711 |
input | Reads weight from an HX711 24-bit ADC connected to a load cell via two GPIO pins. |
hy3131-device |
config | Bus configuration for a HY3131 |
hy3131 |
input | Reads the AD1 differential input (PB2 vs AGND) of an HY3131 DMM analog front end over SPI. Data-ready is polled via the INTF register, so only CK/DI/DO/CS are needed. |
mcp3422-device |
config | I²C bus and address for a MCP3422 |
mcp3422 |
input | Reads the two differential inputs of a MCP3422 18-bit delta-sigma ADC (I²C) with a one-shot conversion per channel. Full scale is ±2.048 V / gain; the LSB is 2·2.048 V / 2 bits / gain. |
mcp4725-device |
config | I²C bus and address for a MCP4725 |
mcp4725 |
output | Sets the output voltage of an MCP4725 12-bit DAC over I²C. |
mcp4728-device |
config | I²C bus and address for a MCP4728 |
mcp4728 |
output | Sets the output voltage of one channel (A–D) of an MCP4728 quad-channel 12-bit DAC over I²C. |
mcp4xxx-device |
config | I²C bus and address for a MCP4XXX |
mcp4xxx |
input | Sets or reads the volatile wiper(s) of an MCP4XXX I²C digital potentiometer / rheostat (MCP4531 … MCP4662: 7 / 8-bit, one or two networks, volatile or non-volatile). The device is configured via an mcp4xxx-device config node. |
pcf8591-device |
config | I²C bus and address for a PCF8591 |
pcf8591 |
input | Reads the four analog inputs of a PCF8591 8-bit ADC/DAC over I²C. Default address is 0x48 ; any address in the range 0x48 – 0x4F is valid depending on the A0/A1/A2 pin states. |
