node-red-contrib-periph-accelerometer 1.5.2
Node-RED nodes for accelerometer chips
Node-RED nodes for accelerometer chips — part of the Periph library.
Open Node-RED, go to Manage Palette → Install and search for node-red-contrib-periph-accelerometer.
Or from the command line in your Node-RED user directory:
npm install node-red-contrib-periph-accelerometer
| Node | Kind | Description |
adxl345-device |
config | I²C bus and address for an ADXL345 |
adxl345 |
input | Reads 3-axis acceleration from an ADXL345 3-axis accelerometer over I²C. |
adxl362-device |
config | Bus configuration for an ADXL362 |
adxl362 |
input | Reads 3-axis acceleration from an ADXL362 3-axis ultralow-power accelerometer over SPI. |
bma150-device |
config | I²C bus and address for a BMA150 |
bma150 |
input | Reads 3-axis acceleration and on-chip temperature from a BMA150 3-axis accelerometer over I²C. |
bma180-device |
config | I²C bus and address for a BMA180 |
bma180 |
input | Reads 3-axis acceleration and on-chip temperature from a BMA180 3-axis accelerometer over I²C. |
fxos8700-device |
config | I²C bus and address for a FXOS8700 |
fxos8700 |
input | Reads 3-axis acceleration, 3-axis magnetic flux density, the tilt-compensated compass heading and the die temperature from an NXP FXOS8700CQ 6-axis e-compass over I²C. The chip runs in hybrid mode, so both sensors are read with one 12-byte burst. |
lis3dh-device |
config | I²C bus and address for a LIS3DH |
lis3dh |
input | Reads 3-axis acceleration and the relative on-chip temperature from a LIS3DH 3-axis accelerometer over I²C. |
lsm303-device |
config | Bus configuration for a LSM303 |
lsm303 |
input | Reads 3-axis acceleration, 3-axis magnetic flux density and the compass heading from an LSM303 3-axis accelerometer + magnetometer e-compass over I²C. |
mma8451q-device |
config | I²C bus and address for a MMA8451Q |
mma8451q |
input | Reads 3-axis acceleration and the hardware orientation detection from an MMA8451Q 3-axis accelerometer over I²C. |
