node-red-contrib-peak-value-range 0.0.2
A Node-RED node for filtering values within a specified range and finding the peak value.
npm install node-red-contrib-peak-value-range
Node-RED Peak Value Range Node
This Node-RED node, named "peak-value-range," filters input values within a specified range and calculates the first peak value within that range.
Description
The "peak-value-range" node filters incoming values to ensure they fall within a specified range (minimum and maximum). It then calculates the first peak value within that range and emits it as output. This node is useful for finding the highest value within a specified range of analog or numerical data.
To install the "peak-value-range" node in your Node-RED environment, you can use the Manage Palette feature or manually copy the node files to your Node-RED nodes directory.
  1. Using Manage Palette (Recommended):
    • Open your Node-RED instance.
    • Click on the menu icon in the top-right corner and select "Manage palette."
    • Go to the "Install" tab, search for "peak-value-range," and click "install."
  2. Manual Installation:
    • Copy the "peak-value-range.js" and "peak-value-range.html" files to your Node-RED nodes directory (usually located at ~/.node-red/nodes).
  1. Drag and drop the "peak-value-range" node from the Node-RED palette onto your workspace.
  2. Configure the node by setting the minimum and maximum values for filtering.
  3. Connect the "peak-value-range" node to an input source that provides analog or numerical data.
  4. Deploy your flow.
  5. The "peak-value-range" node will calculate the first peak value within the specified range and emit it as output.
  • Minimum Value: The minimum value for filtering input data. Values below this threshold will be ignored.
  • Maximum Value: The maximum value for filtering input data. Values above this threshold will be ignored.
This Node-RED node is licensed under the GPL-3.0 License.
Author
Harshad Joshi @ Bufferstack.IO Analytics Technology LLP, Pune
Version: 0.0.2
Updated 2 years, 10 months ago
License: GPL-3.0
Rating: 5.0 5
5 in the last week
  • peak-value-range
  • peak
  • value
  • range
  • filter
  • peak detection
