node-red-contrib-pdfmake2 2.0.0
a node to create pdf documents from a well defined json
npm install node-red-contrib-pdfmake2
Fork of the original package with better error handling
This node is a simple wrapper around pdfmake, a JSON based solution to create PDFs from a given document definition.
pdfmake website
node-red-contrib-pdfmake can be install using the node-red editor's pallete or by running npm in the console:
There is just one node, and it expects an object in msg.payload with a valid docDefinition like:
	"content": [
		"First paragraph",
		"Another paragraph, this time a little bit longer to make sure, this line will be divided into at least two lines"
The node returns a msg.payload holding the created PDF either as a Buffer or a base64 encoded string (as configured in the node).
Examples
Examples are provided using the default node-red way, i.e. use import in the editor menu and look for examples in the node-red-contrib-pdfmake package
#1 simple text PDF
This is the first example found on the pdfmake website.
#2 image & svg example PDF
This is a custom example showing how to read an image from file and integrate it into the PDF. It also shows a simple SVG to be included as well.
Version: 2.0.0
Updated 3 years, 8 months ago
66 in the last week
  • pdfmake
  • pdf
  • pdfmake
