node-red-contrib-pdf2text 1.0.0
Node-RED node that extracts text from a PDF Buffer using unpdf (PDF.js).
npm install node-red-contrib-pdf2text
A Node-RED node that extracts the text of a PDF using unpdf (PDF.js under the hood, no native dependency).
  • Extract text from a PDF supplied as a Buffer, Uint8Array or ArrayBuffer.
  • Limit the extraction to a page range (First page / Last page).
  • Result metadata available on msg.pdf2text.
  • Explicit, actionable errors for invalid input (never a silent empty output).
  • Pure JavaScript — works on Windows, Linux and macOS with no build step.
Requirements
  • Node.js 18 or newer
  • Node-RED 3.0 or newer
From the Node-RED editor: Manage palette → Install → search pdf2text.
Or from the command line, inside your Node-RED user directory (usually ~/.node-red):
Node: pdf2text
Category: parser
Input
Property Type Description
payload Buffer / Uint8Array / ArrayBuffer The PDF as binary data. Configurable via PDF property.
A string is not accepted. Reading a PDF as text (utf8 or base64) produces empty or corrupt output, so the node raises an explicit error telling you how to fix it. Configure the upstream node so it outputs binary data — for a file node set Output to "a single Buffer object". If you only have a base64 string, decode it first, e.g. with a function node: msg.payload = Buffer.from(msg.payload, "base64"); return msg;.
Output
payload string The extracted text. Configurable via Output property.
pdf2text object Result metadata (fixed property, see below).
msg.pdf2text contains:
Field Type Description
success boolean true when extraction succeeded.
totalPages number Total pages in the document.
pages number Number of pages actually extracted (the requested range).
fromPage number First extracted page (1-based).
toPage number Last extracted page (1-based).
elapsedMs number Processing time in milliseconds.
Options
Field Description
PDF property Message property holding the PDF. Default msg.payload. Uses the standard Node-RED property picker.
Output property Message property where the text is written. Default msg.payload.
First page First page to extract (1-based, inclusive). Empty = from page 1.
Last page Last page to extract (1-based, inclusive). Empty = to the last page.
The text of the selected pages is joined into a single string with a blank line between pages (\n\n).
Status
The node reports its result in the workspace:
  • extracting... (blue) — processing.
  • OK pages <last>/<total> (green) — success, e.g. OK pages 3/3.
  • invalid input / failed (red) — an error was raised.
Errors
The node raises an error (and emits no message) when:
  • The input is empty, or is not a Buffer/Uint8Array/ArrayBuffer (e.g. a string).
  • The PDF cannot be parsed (corrupt, or not actually a PDF).
  • First page is beyond the document, or First page > Last page.
A Last page beyond the document is clamped to the last page (a warning is logged).
Example flow
Import examples/extract-pdf-text.json via Menu → Import. It reads a PDF from disk into a Buffer and extracts the text.
Prefer a file node with Output: a single Buffer object over a function node — it avoids loading the whole file with fs.readFileSync.
Security notes
  • Input validation: only binary input is accepted; strings are rejected.
  • Prototype pollution: configured property paths are validated and reserved keys (__proto__, prototype, constructor) are refused.
  • Resource handling: the PDF.js document is destroyed after each message to avoid memory leaks on large documents.
A PDF is untrusted input. PDF.js is generally robust, but a malformed PDF can consume CPU/memory; process untrusted files on a worker/service you can restart, and consider a file-size limit upstream.
Development
npm install
npm test                                          # smoke test + Node-RED harness
node test/nr-harness.js "C:/path/to/file.pdf"     # harness against a real PDF
To develop against a local Node-RED, install the folder into your user directory:
npm install "C:/path/to/node-red-contrib-pdf2text"
Contributing
Issues and pull requests are welcome. Please run npm test before opening a PR.
MIT
Version: 1.0.0
Updated 3 weeks, 1 day ago
  • pdf2text
  • node-red-node
  • pdf
  • pdf2text
  • unpdf
  • pdfjs
  • text-extraction
  • extract-text
