node-red-contrib-pdf-reader 1.0.0
Node-RED node to read pdf data using pdfjs
npm install node-red-contrib-pdf-reader
A Node-RED node to extract PDF text content. Heavily inspired by https://github.com/RedBackSpider/node-red-contrib-pdfjs
Differences from the original repository
  • Support for read files using file name is remove. Use a node to read a file and pass the contents to this node.
  • Password support and Selecting specific page has been included
  • Includes the latest (as of writing) version of https://github.com/mozilla/pdfjs-dist
  • Only supports Node 18 and up (due to pdfjs-dist not supporting lower Node versions)
  • Partial rewrite and JSDoc-annotated code
Inputs
Key Description
msg.payload.data (object | string) Either a buffer object that corresponds to a pdf file or a filepath leading to a pdf file to be decoded
msg.payload.password (string, optional) Password of the PDF file
Config
Key Description
pages (string, optional) List of pages and/or page ranges. If pages is not provided, includes all the pages of the PDF (e.g. 1, 2, 3-5)
Order text (boolean, optional) Check this option to force the text to be ordered top down using the y value if 'from top to bottom' is selected, or ordered left to right by it's x value if 'from left to right' is selected. If both options are selected, it will order from top to bottom, then left to right.
Merge text with next text (boolean, optional) CWhen inserting text into output payload array, if the previous text inserted has the same x value (are in the same column), or same y value (are in the same row), concatenate the string to be inserted with the previous string with a space instead.
Outputs
payload
Results of the parsing will be returned as an array with each element in the array corresponding to a page in the pdf. Each page in the array is stored as an array of objects which can be seen below. p is the order in the pdf document
    "p": 1,
    "x": 328.78, // distance away from the right edge
    "y": 1175.676, // distance away from the bottom of the page
    "t": "Survey Responses 1/02/19 - 31/04/19" // text content
    "p": 2,
    "x": 428.78,
    "y": 1175.676,
    "t": "Survey Responses 1/05/19 - 31/07/19"
Version: 1.0.0
Updated 2 years, 8 months ago
Rating: 1.0 1
48 in the last week
  • pdf
  • pdfjs
