node-red-contrib-pdf-hummus 0.0.3
Extract Text from a pdf using hummusjs
npm install node-red-contrib-pdf-hummus
Node-RED Node to be used to extract text from a pdf file making use of hummusjs.
This node splits text out of a PDF document making use of the npm module hummusjs and the text extraction sample.
This early release is a get it working node-red wrappering of the text extraction sample code, which does more than is actually is needed by this node. Hence it has a larger than necessary memory requirement.
Input
The node needs a filename and a PDF input buffer as input. The filename being written to can be overridden by setting msg.filename.
The document to be added should be passed in as a data buffer in msg.payload.
HTTP Input
The node can also be driven by a HTTP input node, where a pdf file is POSTed to the flow. The pdf file buffer and name will then be taken from the request field of the msg. To use this implementation, in the http input properties, ensure that "Method" is set to "POST", and "Accept file uploads?" is ticked.
Output
The output is a json object on msg.payload. If the split option is selected then an event is sent for each page.
Sample flow
File Inject Implementation
[{"id":"75540143.de239","type":"pdf-hummus","z":"434de041.4e4f4","name":"","filename":"myfile.txt","split":true,"mode":{"value":"asBuffer"},"x":270.5,"y":65,"wires":[["cd04c7ce.3b70c8","a84e0874.451318"]]},{"id":"38aade4f.ab0c12","type":"fileinject","z":"434de041.4e4f4","name":"","x":103,"y":62,"wires":[["75540143.de239"]]},{"id":"cd04c7ce.3b70c8","type":"debug","z":"434de041.4e4f4","name":"","active":true,"console":"false","complete":"false","x":449.5,"y":65,"wires":[]},{"id":"a84e0874.451318","type":"watson-discovery-v1-document-loader","z":"434de041.4e4f4","name":"","environment_id":"","collection_id":"","default-endpoint":true,"service-endpoint":"https://gateway.watsonplatform.net/discovery/api","x":411,"y":133,"wires":[["2e9ac940.1cd4c6"]]},{"id":"2e9ac940.1cd4c6","type":"debug","z":"434de041.4e4f4","name":"","active":true,"console":"false","complete":"true","x":610.5,"y":131,"wires":[]}]
HTTP POST Implementation
[ { "id": "1f7ebf39.38b309", "type": "pdf-hummus", "z": "639c38eb.3b18c8", "name": "", "filename": "", "split": false, "mode": { "value": "asBuffer" }, "x": 487, "y": 227, "wires": [ [ "757b38a5.04059" ] ] }, { "id": "e8e6b15b.868638", "type": "http in", "z": "639c38eb.3b18c8", "name": "", "url": "/pdfin", "method": "post", "upload": true, "swaggerDoc": "", "x": 204, "y": 228, "wires": [ [ "1f7ebf39.38b309" ] ] }, { "id": "757b38a5.04059", "type": "http response", "z": "639c38eb.3b18c8", "name": "", "statusCode": "200", "headers": {}, "x": 792, "y": 230, "wires": [] } ]
Deploy the sample flow, and create a HTTP POST as follows:
Contributing
For simple typos and fixes please just raise an issue pointing out our mistakes. If you need to raise a pull request please read our contribution guidelines before doing so.
Copyright and license
Copyright 2017 IBM Corp. under the Apache 2.0 license.
Version: 0.0.3
Updated 7 years, 9 months ago
10 in the last week
  • pdf-hummus
  • pdf
  • hummusjs
  • Soheel Chughtai
