node-red-contrib-pcf8574-cluster 0.0.5
Control each pin of a PCF8574/PCF8574A/PCF8574P I2C port expander IC with Node-RED ( <http://nodered.org> ).
npm install node-red-contrib-pcf8574-cluster
Description
Control each pin of a PCF8574/PCF8574A/PCF8574P I2C port expander IC with Node-RED ( http://nodered.org ).
$ cd ~/.node-red
$ npm i node-red-contrib-pcf8574-cluster
- cluster configurator
Configuration node for cluster.
Configuration:
  • Addresses : Define the addresses of the PCF8574/PCF8574A
  • Example : { "addresses": [32, 33] }
  • Initial states : Define the initialStates of the PCF8574/PCF8574A
  • Example : { "initial_states": [true, true] }
  • Interrupts : Define the interrupts of the PCF8574/PCF8574A
  • Example : { "interrupts": [{ "index": 1, "pin": 24 }, { "index":2, "pin": 25 }] }
- cluster in
Define a pin as an input.
Configuration:
  • Cluster : Select cluster configuration
  • Name : Define name
  • Pin : Define input pin
  • Inverted : true if this pin should be handled inverted (high=false, low=true)
- cluster out
Define a pin as an output.
Configuration:
  • Initiate: The initial value of this pin, which will be set immediatly.
- pin value
Returns the current value of a pin.
Configuration:
  • Pin : Define pin which value you want to get.
Version: 0.0.5
Updated 8 years, 4 months ago
6 in the last week
  • cluster-configurator
  • cluster-in
  • cluster-out
  • pin-value
  • pcf8574-cluster
