node-red-contrib-passport-azure-ad 0.0.1
node red http in wrapper for the passport-azure-ad library
npm install node-red-contrib-passport-azure-ad
NPM Version NPM Downloads Node.js Version
Custom Nodes for Node RED to allow bearer authentication via passport-azure-ad.
The add-on is still in early development and the functionality will be enhanced over time.
Right now there are to available options to install Node RED add-ons.
Via the Web-Interface
  1. Open the menu in the upper right corner
  2. Choose Manage Palette
  3. Under Install, search for: node-red-contrib-passport-azure-ad
Via the command line
  1. Navigate to your Node RED user directory, usally $HOME/.node-red
  2. Run the following command:
Right now the is just a single Node implemented.
Config Node
Before using any nodes you have to configure the Active Directory. For that you have the option to create config nodes from within the normal nodes.
You only need 3 parameters from your Cosmos Database:
  1. Your identity metadata, usally something like this (for v2 endpoints):
    https://login.microsoftonline.com/[your_tenant_guid]/v2.0/.well-known/openid-configuration
  2. The client id, which is found under the Overview Tab in the Azure console for your app registration.
  3. The scope. It is recommended to use a custom scope. Do not use this format: api://[guid]/[scope], just use the scope.
You should also check the manifest of your app registration. The key accessTokenAcceptedVersion has to be 1 or 2, depending on your endpoint version you use.
HTTP In Auth Node
The HTTP node is derived from the offical http in node from node-red. See 21-httpin.js & 21-httpin.html.
In addition to the normal functionality you can specify an azure-ad config node.
Authentication
The node uses the BearerStrategy.
The following example uses MSAL Angular to authenticate users:
Within your MsalModule registration in app.module.ts add your custom scope in consentScopes. Also add your API endpoint to the protectedResourceMap array.
MsalModule.forRoot({
      auth: {
        ...environment.azureMSALConfig
      cache: {
        cacheLocation: 'localStorage',
        storeAuthStateInCookie: isIE, // Set to true for Internet Explorer 11
      popUp: !isIE,
      consentScopes: [
        'user.read',
        'openid',
        'profile',
        'api://[guid]/[scope]'
      unprotectedResources: [],
      protectedResourceMap: [
        ['https://graph.microsoft.com/v1.0/me', ['user.read']],
        ['https://[URL]/[your]/[endpoint]', ['api://[guid]/[scope]']]
      extraQueryParameters: {}
With the HTTP interceptor you can use the HttpClient as normal.
this.http.post('https://[URL]/[your]/[endpoint]', { test: "test" })
The Msal Module will automatically add the required bearer token to your request.
Apache 2.0
Version: 0.0.1
Updated 6 years, 6 months ago
4 in the last week
  • http-ad-config
  • http-in-ad-auth
  • azure
  • passport
  • active directory
  • ad
  • bearer
  • authentication
