node-red-contrib-parrot-drones 0.0.4
A node that can be used in Node-Red to control Parrot drones
npm install node-red-contrib-parrot-drones
Overview
This project aims to provide a Nodes in Node-Red that can be used to control and monitor the data of Parrot drones based on Parrot ARDroneSDK3.
Two nodes is provided as explained below:
  • drone-data: is an output node that can be used to read all the data received from the drone such as battery, status, etc ..
  • drone-control: used to execute drone supported commands.
Additionally a configuration node drone-config is provided to group all the drone related settings and is accessible by the other nodes. All the commands and events are tested with real drone to verify that it works as expected.
Supported Parrot Drones as of now
  1. Parrot Jumping Mini Drones using existing node library.
npm i node-red-contrib-parrot-drones
Commands
The commands sent to the "drone-control" node is expected to be inside msg.command and the command parameters should be inside msg.payload. Below are the supported commands categorized by drone type:
  1. Jumping Mini Drones
  • forward
Move the drone forward at the specified speed (between 0 and 100). Required input msg.payload.speed
  • backward
Move the drone backward at the specified speed (between 0 and 100). Required input msg.payload.speed
  • right
Turn the drone right at the specified speed (between 0 and 100). Required input msg.payload.speed
  • left
Turn the drone left at the specified speed (between 0 and 100). Required input msg.payload.speed
  • stop
Tell the drone to stop moving.
  • posture-kicker
Move the drone into the kicker posture. The drone jump mechanism is used to kick objects behind the drone.
  • posture-jumper
Move the drone into the jumper posture. The drone jump mechanism is used to propel the drone into the air.
  • posture-standing
Move the drone into the standing (on head) posture.
  • animation-slalom
Make the drone drive in a slalom pattern.
  • animation-spiral
Make the drone drive in a spiral.
  • animation-spin-to-posture
Spin and then change posture.
  • animation-spin-jump
Spin and then jump the drone.
  • animation-ondulation
Perform the ondulation animation.
  • animation-metronome
Perform the metronome animation.
  • animation-slow-shake
Shake the drone from side-to-side.
  • animation-tap
Tap the drone jump mechanism.
  • animation-spin
Perform a spin.
  • animation-stop
Stop the pre-programmed animation.
  • animation-long-jump-kicker
Perform a long jump. The drone is in kicker posture before performing this animation.
  • animation-long-jump-jumper
Perform a long jump. The drone is in jumper posture before performing this animation.
  • animation-high-jump
Perform a high jump. The drone needs to be in the jumper posture to use this API.
  • take-picture
Take picture and store it internally
  • get-video-stream
Emits the MJPEG video stream. This will send the data representing the video as a stream of buffer data in object.payload.video
Drone Data and Events
This node will listen to multiple events triggered by the drone and publish the data to msg.payload object. Below are the publish events categorized by drone type:
batteryPercentage
A numeric value indicating the current battery level
batteryStatus
This can be two values based on the events received from the drone as explained below:
  • critical
Emitted when the battery is at a critically low level.
  • low
Emitted when the battery is at a low level.
status
The status of the drone which can be ready
posture
The current posture of the drone, this can be 5 values based on the events received from the drone as explained below:
  • standing
Emitted when the drone changes to the standing posture. The event may be emitted slightly before the movement is complete so you may want to wait a short time before sending the drone further commands.
  • jumper
Emitted when the drone changes to the jumper posture. The event may be emitted slightly before the movement is complete so you may want to wait a short time before sending the drone further commands.
  • kicker
Emitted when the drone changes to the kicker posture. The event may be emitted slightly before the movement is complete so you may want to wait a short time before sending the drone further commands.
  • stuck
Emitted when the drone is stuck.
  • unknown
Emitted when the drone posture is unknown.
jumpLoad
The jump loading status of the drone, this can be 6 values based on the events received from the drone as explained below:
  • busy
Emitted when the jump mechanism is busy (for example, if you tell the drone to jump while a jump is already in progress).
  • unloaded
Emitted when the jump mechanism is unloaded (for example, after a jump or kick). The event may be emitted slightly before the movement is complete so you may want to wait a short time before sending the drone further commands.
  • loaded
Emitted when the jump mechanism is retracted (for example, after a long jump while in the kicker posture). The event may be emitted slightly before the movement is complete so you may want to wait a short time before sending the drone further commands.
  • unknown
Emitted when the load state of the jump mechanism is unknown.
  • unloaded and no jump due to battery Low
Emitted when the jump mechanism is unloaded and the drone cannot perform the jump requested because the battery is low.
  • loaded and no jump due to battery Low
jumpMotor
The status of the jump motor of the drone, this can be three values based on the events received from the drone as explained below:
  • ok
Emitted when the jump motor is OK (it may have previously been blocked or overheated).
  • blocked
Emitted when the jump motor is blocked.
  • overheated
Emitted when the jump motor has overheated.
message
A message sent from the drone, this can be two values based on the events received from the drone as explained below:
  • image taken and stored internally
Emitted when a photo is taken and stored internally (response to takePicture(opts)).
  • video frame is (the video frame)
Emits single MJPEG video frame.
Example flow and how it works
The example flow below will show how to control a parrot drone using the "drone-control" node:
[{"id":"2225687d.0c5988","type":"drone-control","z":"128fc2a1.2fc64d","name":"Drone Control","settings":"c1e2cbff.a51ca8","x":619.5,"y":255,"wires":[["34fe3d0d.3a46a2"]]},{"id":"7747f1b8.aadc6","type":"function","z":"128fc2a1.2fc64d","name":"","func":"msg.command = msg.payload;\nmsg.payload = {};\n\nvar speed = flow.get('speed') || 0;\n\nmsg.payload.speed = speed;\nreturn msg;","outputs":1,"noerr":0,"x":413.5,"y":258,"wires":[["2225687d.0c5988"]]},{"id":"34fe3d0d.3a46a2","type":"debug","z":"128fc2a1.2fc64d","name":"","active":true,"console":"false","complete":"true","x":878.5,"y":260,"wires":[]},{"id":"34469adb.cdf3a6","type":"ui_text_input","z":"128fc2a1.2fc64d","tab":"aec1e0f8.c48b4","mode":"text","delay":300,"name":"Speed","topic":"speed","group":"Movement","order":1,"x":76.5,"y":146,"wires":[["98cd5977.c430c8"]]},{"id":"98cd5977.c430c8","type":"function","z":"128fc2a1.2fc64d","name":"","func":"\nflow.set('speed',msg.payload);\n\nreturn msg;","outputs":"1","noerr":0,"x":219,"y":145,"wires":[[]]},{"id":"ef8de3aa.e35a9","type":"ui_button_row","z":"128fc2a1.2fc64d","tab":"aec1e0f8.c48b4","name":"Up-Right","topic":"","group":"Movement","order":1,"toggle":false,"buttons":[{"payload":"forward","icon":"keyboard_arrow_up","color":"Blue","on_icon":"alarm_on","on_color":"red"},{"payload":"right","icon":"keyboard_arrow_right","color":"Blue","on_icon":"keyboard_arrow_down","on_color":"Blue"}],"inputs":0,"x":81.5,"y":204,"wires":[["7747f1b8.aadc6"]]},{"id":"457c0395.e4103c","type":"ui_button_row","z":"128fc2a1.2fc64d","tab":"aec1e0f8.c48b4","name":"Down-Left","topic":"","group":"Movement","order":1,"toggle":false,"buttons":[{"payload":"backward","icon":"keyboard_arrow_down","color":"Blue","on_icon":"alarm_on","on_color":"red"},{"payload":"left","icon":"keyboard_arrow_left","color":"Blue","on_icon":"keyboard_arrow_down","on_color":"Blue"}],"inputs":0,"x":81,"y":259,"wires":[["7747f1b8.aadc6"]]},{"id":"3c81b436.8cff3c","type":"ui_button_row","z":"128fc2a1.2fc64d","tab":"aec1e0f8.c48b4","name":"Stop","topic":"","group":"Movement","order":1,"toggle":false,"buttons":[{"payload":"stop","icon":"clear","color":"Blue","on_icon":"alarm_on","on_color":"red"}],"inputs":0,"x":71,"y":311,"wires":[["7747f1b8.aadc6"]]},{"id":"c0378e04.5fddd","type":"ui_template","z":"128fc2a1.2fc64d","tab":"aec1e0f8.c48b4","name":"Animations","group":"Animations","order":1,"format":"<md-button ng-click=\"send({payload: 'animation-stop'})\">\n  Animation Stop\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-slalom'})\">\n  Slalom\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-spiral'})\">\n  Spiral\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-spin-to-posture'})\">\n  Spin Posture\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-spin-jump'})\">\n  Spin Jump\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-ondulation'})\">\n  Ondulation\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-metronome'})\">\n  Metronome\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-slow-shake'})\">\n  Slow Shake\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-tap'})\">\n  Tap\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-spin'})\">\n  Spin\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-long-jump-kicker'})\">\n  Long Jump Kicker\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-long-jump-jumper'})\">\n  Long Jump Jumper\n</md-button>\n\n<md-button ng-click=\"send({payload: 'animation-high-jump'})\">\n  High Jump\n</md-button>","storeOutMessages":true,"fwdInMessages":true,"x":81.5,"y":453,"wires":[["7747f1b8.aadc6"]]},{"id":"e17316ed.020258","type":"ui_template","z":"128fc2a1.2fc64d","tab":"aec1e0f8.c48b4","name":"Postures","group":"Posture","order":1,"format":"<md-button ng-click=\"send({payload: 'posture-kicker'})\">\n Kicker\n</md-button>\n\n<md-button ng-click=\"send({payload: 'posture-jumper'})\">\n  Jumper\n</md-button>\n\n<md-button ng-click=\"send({payload: 'posture-standing'})\">\n  Standing\n</md-button>","storeOutMessages":true,"fwdInMessages":true,"x":68.5,"y":379,"wires":[["7747f1b8.aadc6"]]},{"id":"c4c919df.d8cc08","type":"ui_template","z":"128fc2a1.2fc64d","tab":"aec1e0f8.c48b4","name":"Media","group":"Media","order":1,"format":"<md-button ng-click=\"send({payload: 'take-picture'})\">\n  Take Picture\n</md-button>\n\n<md-button ng-click=\"send({payload: 'get-video-stream'})\">\n  Get Video Stream\n</md-button>\n\n","storeOutMessages":true,"fwdInMessages":true,"x":87,"y":529,"wires":[["7747f1b8.aadc6"]]},{"id":"c1e2cbff.a51ca8","type":"drone-config","z":"","ip":"192.168.2.1","droneType":"Jumping Drone"},{"id":"aec1e0f8.c48b4","type":"ui_tab","z":"","name":"Drone","icon":"dashboard","order":"1"}]
And the below flow will show how to see all the drone data using the "drone-data" node:
[{"id":"1a312d3.7f9ead3","type":"drone-data","z":"c560f4ff.b48658","name":"Drone Data","settings":"c1e2cbff.a51ca8","x":124,"y":254,"wires":[["40d7160b.ec11b8","df9a2af4.9817d8"]]},{"id":"40d7160b.ec11b8","type":"debug","z":"c560f4ff.b48658","name":"","active":true,"console":"false","complete":"true","x":226.5,"y":405,"wires":[]},{"id":"d48ed1a5.b6436","type":"ui_text","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"Posture Status","group":"Data","order":1,"format":"{{msg.payload.posture}}","x":747,"y":238,"wires":[]},{"id":"63758a61.c32d54","type":"ui_text","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"Drone Status","group":"Data","order":1,"format":"{{msg.payload.status}}","x":734.5,"y":289,"wires":[]},{"id":"e8dc38cc.64e188","type":"ui_text","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"Jump Load Status","group":"Data","order":1,"format":"{{msg.payload.jumpLoad}}","x":759.5,"y":343,"wires":[]},{"id":"9310d160.4c77d","type":"ui_text","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"Jump Motor Status","group":"Data","order":1,"format":"{{msg.payload.jumpMotor}}","x":752.5,"y":402,"wires":[]},{"id":"d5ee8c50.8f28b","type":"ui_text","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"Messages","group":"Data","order":1,"format":"{{msg.payload.message}}","x":730.5,"y":458,"wires":[]},{"id":"3742a1ee.5b2ebe","type":"ui_text","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"Battery Status","group":"Data","order":1,"format":"{{msg.payload.batteryStatus}}","x":740.5,"y":185,"wires":[]},{"id":"df9a2af4.9817d8","type":"switch","z":"c560f4ff.b48658","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"batteryPercentage","vt":"str"},{"t":"eq","v":"batteryStatus","vt":"str"},{"t":"eq","v":"posture","vt":"str"},{"t":"eq","v":"status","vt":"str"},{"t":"eq","v":"jumpLoad","vt":"str"},{"t":"eq","v":"jumpMotor","vt":"str"},{"t":"eq","v":"message","vt":"str"}],"checkall":"true","outputs":7,"x":344,"y":255,"wires":[["8209fbee.1afdb8"],["3742a1ee.5b2ebe"],["d48ed1a5.b6436"],["63758a61.c32d54"],["e8dc38cc.64e188"],["9310d160.4c77d"],["d5ee8c50.8f28b","eb5f127c.3ed38","1ba3b1fb.5c0bce"]]},{"id":"eb5f127c.3ed38","type":"switch","z":"c560f4ff.b48658","name":"","property":"payload.buf","propertyType":"msg","rules":[{"t":"nnull"}],"checkall":"true","outputs":1,"x":368,"y":513,"wires":[["7e79f4c2.bfd0ec"]]},{"id":"c8897980.48bd18","type":"debug","z":"c560f4ff.b48658","name":"","active":true,"console":"false","complete":"true","x":719.5,"y":660,"wires":[]},{"id":"7e79f4c2.bfd0ec","type":"function","z":"c560f4ff.b48658","name":"","func":"var originalBuf = msg.payload.buf;\nvar buf = new Buffer(originalBuf);\nmsg.payload = buf;\nmsg.payload.image = true;\nreturn msg;\n","outputs":1,"noerr":0,"x":515,"y":521,"wires":[["da8b21cb.331d2","c8897980.48bd18"]]},{"id":"b7c91a07.d30a18","type":"ui_template","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"","group":"Image","order":1,"format":"<img width=\"250\" height=\"250\" alt=\"image\" src=\"data:image/jpg;base64,{{msg.payload}}\"/>","storeOutMessages":true,"fwdInMessages":true,"x":1002,"y":616,"wires":[[]]},{"id":"da8b21cb.331d2","type":"switch","z":"c560f4ff.b48658","name":"","property":"payload.image","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","outputs":1,"x":671,"y":521,"wires":[["86a6069c.3b2b18"]]},{"id":"1ba3b1fb.5c0bce","type":"debug","z":"c560f4ff.b48658","name":"","active":true,"console":"false","complete":"true","x":177.5,"y":579,"wires":[]},{"id":"86a6069c.3b2b18","type":"base64","z":"c560f4ff.b48658","name":"","x":861,"y":542,"wires":[["b7c91a07.d30a18"]]},{"id":"8209fbee.1afdb8","type":"ui_text","z":"c560f4ff.b48658","tab":"aec1e0f8.c48b4","name":"Battery Percentage","group":"Data","order":1,"format":"{{msg.payload.batteryPercentage}}","x":742.5,"y":126,"wires":[]},{"id":"c1e2cbff.a51ca8","type":"drone-config","z":"","ip":"192.168.2.1","droneType":"Jumping Drone"},{"id":"aec1e0f8.c48b4","type":"ui_tab","z":"","name":"Drone","icon":"dashboard","order":"1"}]
The flows will generate a UI that can be accessed using http://127.0.0.1:1880/ui which shown in the screen shot below:
Example Control Dashboard
Version: 0.0.4
Updated 10 years, 6 months ago
4 in the last week
  • drone-config
  • drone-data
  • drone-control
  • parrot
  • jumping race
  • drone
  • Bebop
  • SkyController
  • Night
  • Race
  • AR Drone
  • sumo
  • max
  • night
  • mini drone
  • parrot drones
  • Bilal Al-Saeedi
