node-red-contrib-panasonicprojector 2.0.2
Panasonic Projector Control For Node Red
npm install node-red-contrib-panasonicprojector
Panasonic Network Control For Node Red
How To Use:
Simply pass the following into the module:
Basic Commands
msg.payload.command: The command to be processed
msg.payload.parameter: The parameters(s) of the command, not required if there is none
Using Sub Commands
msg.payload.subcommand: The sub command to be processed
msg.payload.parameter: The parameter(s) of the command, not required if there is none
Error Codes:
ERR1: Undefined control command
ERR2: Out of parameter range
ERR3: Busy state
ERR4: Timeout
ERR5: Wrong data length
ERRA: Password mismatch
ER401: Command cannot be executed
ER402: Invalid parameter
The module will also pass network connection errors on the output
Commands
Panasonic Projector Commands
Version: 2.0.2
Updated 8 years, 7 months ago
20 in the last week
  • panasonicprojector-panasonicprojector
  • panasonic
  • projector
  • panasonic projector
