node-red-contrib-padavan 2.2.1
Node-RED nodes for managing routers with Padavan firmware.
npm install node-red-contrib-padavan
[RU] | [EN]
A set of Node-RED nodes for managing routers running Padavan firmware.
This package uses the padavan library to interact with the router via its web interface (HTTP). It provides tools for monitoring, configuration, diagnostics, and firmware management.
  • Full Control: Manage NVRAM settings, services, and power state via HTTP.
  • Monitoring: Get real-time traffic history (daily/monthly) and system status (CPU/RAM/Uptime).
  • Device Tracking: Retrieve connected clients with smart filtering for "ghost" connections (ARP caching).
  • Diagnostics: Built-in Wi-Fi Scanner and "Wi-Fi Doctor" for analyzing interference and finding the best channel.
  • Firmware Management: Check for updates, trigger builds in GitHub Actions, and flash the router directly from Node-RED.
Install via the Node-RED Manage Palette or run the following command in your Node-RED user directory:
⚙️ Configuration (padavan-config)
Configures the connection to the router (IP, Login, Password) and optionally to GitHub (for firmware updates). Supports secure credential storage.
🖥️ System (padavan-system)
Performs system operations and diagnostics.
  • Get Status: CPU load, RAM usage, Uptime.
  • Get Log: Fetch system logs.
  • Reboot: Restart the router.
  • Scan Wi-Fi: Perform a Site Survey (2.4GHz / 5GHz).
  • Wi-Fi Doctor: Analyze the environment and recommend the optimal channel.
📱 Devices (padavan-devices)
Lists connected clients.
  • Returns IP, MAC, Hostname, Connection Type, and RSSI.
  • Calculates changes (added/removed/changed devices) since the last check.
  • Filters out temporary Ethernet "ghosts" when devices switch from Wi-Fi.
📊 History (padavan-history)
Retrieves traffic usage statistics.
  • Prioritizes Monthly stats for billing cycles.
  • Falls back to Daily stats if monthly data is missing.
  • Provides pre-calculated networkUsageMB for easy integration with voice assistants (e.g., Google Home).
🔧 Params (padavan-params)
Low-level access to router settings (NVRAM).
  • List: Dump all NVRAM variables.
  • Get: Read specific variables.
  • Set: Change variables with support for sid_list (service restart) and custom action modes.
☁️ Upgrade (padavan-upgrade)
Manages the firmware lifecycle via GitHub Actions.
  • Check Updates: Compare current version with the latest artifact.
  • Build: Trigger a new build workflow in your repository.
  • Flash: Download the artifact and upgrade the router.
Migration
Upgrading from v1? Check the Migration Guide for details on breaking changes and removed features (like SpeedTest).
Version: 2.2.1
Updated 2 weeks, 3 days ago
5 in the last week
  • padavan-config
  • padavan-system
  • padavan-devices
  • padavan-history
  • padavan-params
  • padavan-upgrade
  • padavan
  • router
  • firmware
  • iot
  • smarthome
  • home-automation
  • node-red-contrib
