node-red-contrib-ot-to-status 0.0.5
To display set key from msg in status of node
npm install node-red-contrib-ot-to-status
More is comming ...
Set key name in properties of node to what you want to display in status of the node from
  • msg[ string ] to node status
this is a in progress ...
install it
For now installation is by entering node-red home directory then installing locally to Node-RED. So user starting node-red home director ./.node-red
npm i node-red-contrib-ot-to-status
then restart Node-RED and start your oiyshTerminal thing
example flow set
.json example to import
It's as a example node set or use link to ... ./examples/exampleNodeSet.json*
[    {        "id": "c1561e195e281007",        "type": "inject",        "z": "6e119010f87bea35",        "name": "",        "props": [            {                "p": "payload"            },            {                "p": "topic",                "vt": "str"            }        ],        "repeat": "1",        "crontab": "",        "once": false,        "onceDelay": 0.1,        "topic": "Is a test !",        "payloadType": "date",        "x": 1440,        "y": 1440,        "wires": [            [                "4bfc7380648f6708"            ]        ]    },    {        "id": "4bfc7380648f6708",        "type": "link out",        "z": "6e119010f87bea35",        "name": "",        "mode": "link",        "links": [            "353db5c6bafa5de4"        ],        "x": 1595,        "y": 1480,        "wires": []    },    {        "id": "353db5c6bafa5de4",        "type": "link in",        "z": "6e119010f87bea35",        "name": "",        "links": [            "4bfc7380648f6708"        ],        "x": 1715,        "y": 1500,        "wires": [            [                "a4855d84e35f2139",                "312b575a095adf53",                "a5d36c69da489dde"            ]        ]    },    {        "id": "312b575a095adf53",        "type": "ot-to-status",        "z": "6e119010f87bea35",        "name": "",        "vKey": "payload",        "x": 1950,        "y": 1580,        "wires": []    },    {        "id": "a5d36c69da489dde",        "type": "ot-to-status",        "z": "6e119010f87bea35",        "name": "inst 2 ... ",        "vKey": "topic",        "x": 1940,        "y": 1640,        "wires": []    }]
If you see that this makes sense send me a ☕ | Master repository | About SvOiysh
Version: 0.0.5
License: GPL-3.0
2 in the last week
  • oiyshTerminal
  • ot-sf2n
