node-red-contrib-originalpid 0.3.1
A simple and direct PID controller node for Node-RED, following the original Arduino-style PID implementation with Kp, Ki, Kd, and sampleTime.
npm install node-red-contrib-originalpid
Node-RED Original PID
A simple, “original” PID controller node for Node-RED — modeled after the classic Arduino PID implementation. Unlike other derived versions, this node exposes Kp, Ki, Kd, and sampleTime directly, giving you full control and predictable behavior.
  • True PID — directly uses Kp, Ki, Kd, and sampleTime
  • Derivative on input to avoid setpoint kick
  • Anti-windup for stable integral term
  • Noisy input filtering for filtering of noisy sensors
  • Persistent state between restarts (using Node-RED context)
  • Manual reset via { "reset": true } or { "restart": true }
  • Status indicators:
    • Yellow → state reset / restored
    • Green → normal operation with live output and error
  • No dependencies, minimal overhead
Example
Input:
{ "payload": 23.5 }
Output:
{ "payload": 0.62 }
Reset:
{ "reset": true }
When persistent context, called file, is enabled in settings.js:
contextStorage: {
    file: { module: "localfilesystem", config: { dir: "/data/context" } },
    default: { module: "memory" }
the node automatically restores its state (outputSum, lastInput, lastTime) after restart of nodered or after change of parameters, to avoid calculating it from clean slate.
Version history
  • v0.3.1 - Filtering of noisy input capability. Changed the label and status message.
  • v0.2.0 - Changing setpoint by input.
  • v0.1.0 – Initial version published to github.
Version: 0.3.1
Updated 1 year ago
118 in the last week
  • originalpid
  • pid
  • controller
  • control
  • process
  • automation
