node-red-contrib-oracledb-mod 1.0.0
Node-RED oracle database nodes
npm install node-red-contrib-oracledb-mod
CI Node.js Package
Robust, modern, and easy-to-use Node-RED nodes for interacting with Oracle Database.
This module provides a stable connection to Oracle, supporting queries, DML, stored procedures, and advanced data binding, all handled through a resilient connection pool.
What's new in 1.0.0
  • Optional Dual Output Ports (Success vs. Error) — toggle separate error output on the node. Port 1 emits successful query results while Port 2 emits query errors with msg.error, allowing direct routing to retry, fallback, or alerting flows without requiring a separate Catch node.
  • Sequential Multi-Statement Queries — pass an array of SQL statements in msg.query to execute multiple queries sequentially within a single round-trip, returning an array of results in msg.payload.
  • Live SQL Bind Auto-Detection — real-time bind parameter badge in the query editor displays detected :param names as you type.
  • Multi-Node Transaction Management — atomic transactions across multiple flow nodes (Begin, Continue, Commit, Rollback) with auto-rollback safety timeout.
  • Oracle 23ai / 26ai Native Vector Search — automatic binding of JavaScript Float32Array / Float64Array as native DB_TYPE_VECTOR for AI similarity search.
  • Interactive Schema & Field Explorer — database hierarchy browser (Database → Schema → Object Type → Table/View → Columns) with smart SELECT *, SELECT cols, and INSERT template SQL generators.
    Schema Explorer
What's new in 0.9.0
  • oracledb 7.0.1 — upgraded the core Oracle driver to version 7, verified with Oracle Database 26ai and OCI Autonomous Database (Thin mode).
  • TypeScript 7 Native Port — modern build pipeline compiling directly with TypeScript 7 native CLI, dropping build times from 7.5s to ~1.3s (80% speedup).
  • Modernized Dev Toolchain — ESLint 10 with flat configuration (eslint.config.mjs), Mocha 12, Chai 6, and modern @types/jquery.
  • Zero Package Vulnerabilities — retired legacy gulp build streaming packages (gulp-typescript, gulp-sourcemaps, gulp-spawn-mocha), eliminating all 13 package security advisories.
  • Continuous Integration — automated GitHub Actions CI matrix running build, linting, and unit tests on Node 20 and Node 22 for all pull requests and pushes.
  • Node Engine — engines updated to Node ≥ 20.
What's new in 0.8.0
  • Thin mode is now the default — no Oracle Instant Client install required for most users (Oracle 12.1+, Autonomous Database, wallets all work). Existing configs that had an Instant Client path keep running in thick mode for backwards compatibility, with a one-time migration warning.
  • First-class wallet / Autonomous Database support — Wallet / TNS_ADMIN, Wallet Location, Wallet Password are now config fields. TNS_ADMIN env var is auto-detected and pre-fills the dialog.
  • TNS Name dropdown — aliases are parsed from your wallet's tnsnames.ora and offered as a combo box.
  • Test Connection button — one-click verification with rich output (server host, service, database, user, current schema, accessible schemas, wallet aliases, connect + total timing).
  • Pool Stats panel — live connectionsInUse / connectionsOpen, queue length, peak in-use and peak queued high-water marks since the pool started. Refreshes every 2 s while open and surfaces sizing hints (e.g. "consider raising Max Connections" when peak hits poolMax).
  • Pool-pressure visibility — query nodes show waiting for pool slot... (4/4) when getConnection() blocks; NJS-040 errors now read pool exhausted: 4/4 in use, 3 queued, waited 60000ms instead of the bare timeout.
  • executeMany batch mode — insert thousands of rows per round-trip via a new "Batch mode" checkbox or msg.executeMany = true.
  • Automatic retry on transient errors — NJS-003/040, ORA-03113/03114/12170/12541/12537/12514 are retried with exponential backoff. Tunable per server config.
  • Richer pool tuning — poolIncrement, queueTimeout, stmtCacheSize exposed in the UI.
  • msg.oracle stats sidecar — every result message carries { durationMs, mode, rows, rowsAffected }. Streamed (multi) results also include chunkIndex / totalRowsSoFar.
  • Node status badges — successful queries briefly show N rows · 23ms; errors stay red for 5s.
  • Engines bumped to Node ≥ 18. CI now runs the full test suite on Node 18/20/22 before publish.
Driver Modes (Thin vs Thick)
Use case Mode
Oracle 12.1+, including Autonomous Database Thin (default) — no install needed
Oracle 11g servers Thick
Advanced Queuing (AQ), Continuous Query Notification (CQN), sharding Thick
Switch via the Driver Mode dropdown in the oracle-server config. Only one mode can be active per Node-RED process, and switching from thin → thick requires a process restart.
Wallet / Autonomous Database
For OCI Autonomous Database:
  1. Download the wallet zip from the OCI console.
  2. Unzip it on the host (e.g. /opt/oracle/network/admin).
  3. In the config node, set TNS_ADMIN to that directory — or just set the TNS_ADMIN environment variable and leave the field blank; the dialog auto-detects it.
  4. The TNS Name dropdown will populate from the wallet's tnsnames.ora. Pick one (e.g. mydb_high).
  5. Fill User + Password on the Security tab. If your wallet is the standard ADB wallet with an SSO file, leave Wallet Password blank.
Click Test Connection to verify before deploying.
Connection Pool Tuning
All settings are on the Connection tab of the oracle-server config:
Field Default What it does
Min / Max Connections 0 / 4 Pool bounds
Pool Increment 1 New connections opened when pool grows
Idle Timeout (s) 60 Idle connection lifetime
Queue Timeout (ms) 60000 How long a query waits for a free connection before failing with NJS-040
Stmt Cache Size 30 Prepared statements cached per connection
Retry on Transient Errors
The node automatically retries failed getConnection / execute calls when the error is transient (network blip, ADB warming up, listener restart). Configurable per server config:
  • Max Retries (default 3, set 0 to disable)
  • Initial Delay (ms) (default 1000) — doubled each attempt, capped at 10s
Errors that are not retried (syntax, permissions, ORA-01017, etc.) surface immediately.
Batch Mode (executeMany)
For high-volume inserts/updates, enable Batch mode on the oracledb (query) node and send an array payload:
msg.payload = [
  { id: 1, name: "alice" },
  { id: 2, name: "bob" },
  // ... thousands of rows
// query: INSERT INTO t (id, name) VALUES (:id, :name)
The node returns one message with msg.payload = { rowsAffected, outBinds, batchErrors }. You can also enable batch mode dynamically via msg.executeMany = true.
Every successful result message carries a metadata sidecar that doesn't disturb msg.payload:
msg.oracle = {
  durationMs: 23,
  mode: "single",            // or "multi" | "single-meta" | "batch" | "none"
  statementKind: "query",    // "query" | "ddl" | "plsql" | "insert" | "update" | "delete" | ...
  rows: 1,                   // when applicable
  rowsAffected: 5            // when applicable (DML, executeMany)
For streamed multi results, each chunk message also gets chunkIndex and totalRowsSoFar so downstream nodes can detect "last chunk". DDL statements (CREATE/DROP/ALTER/...) produce a <verb> ok · Xms status badge instead of the ambiguous 0 affected.
Prerequisites
Thin mode users (most people): no prerequisites — npm install is enough. Skip to the Configuration section.
The rest of this section applies only if you need Thick mode (Oracle 11g, AQ, CQN, sharding). You must have the Oracle Instant Client libraries installed on the same machine that is running Node-RED.
  1. Download: Get the Instant Client "Basic" or "Basic Light" package for your operating system from the Oracle Instant Client Downloads Page.
  2. Install: Unzip the package to a permanent location on your system (e.g., /opt/oracle/instantclient_21_13 on Linux, C:\oracle\instantclient_21_13 on Windows).
  3. Configure Environment: Node.js needs to know where to find these libraries.
  • Linux: Add the path to the LD_LIBRARY_PATH environment variable.
  • Windows: Add the path to the PATH system environment variable.
  • macOS: Add the path to the DYLD_LIBRARY_PATH environment variable.
  1. In the node's configuration, you must provide the path to this directory in the Instant Client Path field. This directly addresses GitHub issue #52.
Install via the Node-RED Palette Manager or run the following command in your Node-RED user directory (typically ~/.node-red):
  • Resilient Connection Pooling: Automatically manages a pool of connections to handle idle timeouts, network disconnects, and database restarts, ensuring your flows are always ready.
  • Execute SQL and PL/SQL: Run SELECT, INSERT, UPDATE, DELETE, and anonymous PL/SQL blocks.
  • Stored Procedures & Functions: Full support for calling stored procedures and functions with IN, OUT, and INOUT parameters using msg.bindVars.
  • Flexible Result Handling: Choose whether to get all rows at once, stream large result sets, or get metadata like the number of rows affected by a DML statement.
  • Configurable Connections: Connect using Classic (host:port/db) or TNS Name, with configurable connection pool settings.
  • Built-in Examples: Comes with an importable example flow for calling stored procedures.
Node Usage
1. oracle-server (Configuration Node)
This node configures the connection to your database. Using the Connection Pool is highly recommended for all use cases.
  • Connection Type: Choose "Classic" for host/port/db or "TNS Name" for using a tnsnames.ora entry.
  • Instant Client Path: The local filesystem path to your Oracle Instant Client installation.
  • Connection Pool:
  • Min/Max Connections: Control the size of the connection pool.
  • Idle Timeout (s): How long an idle connection can live in the pool before being terminated. This is key to preventing errors from firewalls closing idle connections.
2. oracledb (Query Node)
This node executes the query and sends the results.
Common Use Cases
Use Case 1: Simple SELECT Query
  • Set msg.query to SELECT * FROM employees WHERE department_id = :1.
  • Set msg.payload to [50].
  • Set the Action to send single query result message.
  • Output: msg.payload will be an array of employee objects.
Use Case 2: INSERT or UPDATE and Get Rows Affected
  • Set msg.query to UPDATE employees SET salary = salary * 1.1 WHERE department_id = :1.
  • Set the Action to send single message with metadata.
  • Output: msg.payload will be an object like { rowsAffected: 10, ... }. This addresses GitHub issues #3, #53, and #35.
Use Case 3: Calling a Stored Procedure with an OUT Parameter
  • Set msg.query to BEGIN get_employee_name(:emp_id, :emp_name); END;.
  • Set msg.bindVars as shown below.
  • Output: msg.payload.outBinds.emp_name will contain the returned name. This addresses GitHub issue #6 and #34.
// Example for msg.bindVars
msg.bindVars = {
emp_id: { dir:  "BIND_IN", val:  101, type:  "NUMBER" },
emp_name: { dir:  "BIND_OUT", type:  "STRING" }
For a full list of bind parameter types and directions, see the official node-oracledb documentation.
Executing Multiple Statements (Scripts)
The Oracle driver executes one SQL statement or one PL/SQL block at a time. You cannot send a script with multiple statements separated by semicolons (;) in a single query. This will result in an ORA-00933 error.
There are two recommended ways to run multiple commands:
1. For Transactional Scripts (INSERT, UPDATE, DELETE)
The best practice is to wrap your statements in a single PL/SQL BEGIN...END; block. This ensures all commands are executed together as a single, atomic transaction.
Example:
BEGIN
UPDATE inventory SET quantity = quantity - 1  WHERE product_id = :p_id;
INSERT INTO order_log (product_id, log_date) VALUES (:p_id, SYSDATE);
END;
2. For Sequential Queries
If you need to run multiple independent queries, especially SELECT statements, the standard Node-RED approach is to chain multiple oracledb nodes in your flow.
Example Flow:
Inject → [ oracledb (SELECT from table A) ] → [ oracledb (SELECT from table B) ] → ...
Troubleshooting
ORA-06550 Error with BEGIN/END Blocks
Problem: ORA-06550: line 1, column X: PLS-00103: Encountered the symbol "END" when expecting...
Solution: Fixed in version 0.7.6+. The module now intelligently detects PL/SQL blocks and preserves their required semicolons.
Examples that now work correctly:
-- ✅ Simple anonymous PL/SQL block
BEGIN
    DBMS_OUTPUT.PUT_LINE('Hello World');
END;
-- ✅ PL/SQL block with variables
DECLARE
    v_count NUMBER;
BEGIN
    SELECT COUNT(*) INTO v_count FROM dual;
    DBMS_OUTPUT.PUT_LINE('Count: ' || v_count);
END;
-- ✅ PL/SQL block with bind variables
BEGIN
    :result := 'Success';
END;
Best Practices:
  • Always include semicolons with PL/SQL blocks: BEGIN...END;
  • Use "single-meta" result action for blocks with OUT parameters
  • Ensure proper bind variable configuration for IN/OUT parameters
Other Common Issues
ORA-00933: SQL command not properly ended
  • This affects regular SQL statements, not PL/SQL blocks
  • The module automatically handles this for SQL statements
ORA-01036: Illegal variable name/number
  • Check your bind variable names match those in your query
  • Ensure bind variables are properly formatted in msg.bindVars
Connection Issues
  • Verify Oracle Instant Client is properly installed and configured
  • Check connection pool settings in the oracle-server node
  • Ensure your Oracle user has necessary privileges
What's New
Version 1.0.0
  • Feature: Optional Dual Output Ports (splitoutputs) for direct separation of Success vs Error messages without a Catch node.
  • Feature: Sequential multi-query execution via msg.query array with unified results.
  • Feature: Real-time SQL bind parameter auto-detection in the editor.
  • Feature: Multi-node atomic transaction management (Begin, Continue, Commit, Rollback) with auto-rollback safety timer.
  • Feature: Native Vector & Embedding binding (DB_TYPE_VECTOR) for Oracle AI Database 23ai / 26ai vector similarity search.
  • Feature: Dynamic session tracing (action, module, clientInfo) into Oracle V$SESSION / SYS_CONTEXT and msg.oracle stats.
  • Feature: In-dialog Interactive Database, Schema, and Field Explorer with smart SQL template generation.
Version 0.9.0
  • Upgraded: oracledb bumped to ^7.0.1 with verified Thin mode and OCI ADB support.
  • Performance: Migrated build pipeline to TypeScript 7 native execution, improving build times by >80%.
  • Security: Resolved all 13 security vulnerabilities across dependencies (0 audit vulnerabilities).
  • Tooling: Migrated ESLint to v10 flat config (eslint.config.mjs) and test suite to Mocha 12 + Chai 6.
  • CI/CD: Added automated CI workflow across Node 20 and 22.
  • Engines: Node runtime requirements updated to Node ≥ 20.
Version 0.8.0
  • Feature: Thin mode set as default driver mode (no Instant Client needed for Oracle 12.1+ / ADB).
  • Feature: Native OCI Autonomous Database and wallet support (TNS_ADMIN).
  • Feature: In-dialog Connection Testing and live Connection Pool Statistics.
  • Feature: Batch mode execution via executeMany.
Version 0.7.6
  • Fixed: Resolved ORA-06550 errors when executing PL/SQL blocks with BEGIN...END; statements. The module now intelligently preserves semicolons for PL/SQL blocks while removing them for regular SQL statements. (Fixes #126).
  • Enhanced: Added comprehensive test coverage for PL/SQL block execution scenarios.
  • Documentation: Added detailed troubleshooting guide for PL/SQL-related issues.
Version 0.7.5
  • Fixed: Corrected a critical startup crash (NJS-007 error) that occurred when importing flows with a configured connection pool. Flows are now fully portable. (Fixes #90).
Version 0.7.4
  • Feature: Added Smart Named Binding to automatically handle msg.payload objects and prevent ORA-01036 errors.
  • Feature: Implemented more intelligent and persistent node status feedback for running queries and errors.
  • Fixed: Resolved an upgrade issue where existing oracle-server nodes would be marked as invalid.
  • Fixed: Corrected a type_already_registered startup error by overhauling the build process.
Version 0.7.3
This is a major stability and modernization release.
  • Resilient Connections: The node now uses a robust Connection Pool, which resolves numerous issues related to idle timeouts, network disconnects, and stale connections.
  • Added Metadata Result Option: The "single-meta" action has been re-introduced to get the number of rowsAffected from DML statements or outBinds from procedures.
  • Improved Error Handling: The entire backend has been refactored to use modern async/await, providing clearer error messages and preventing Node-RED crashes.
  • UI and Documentation Overhaul: The configuration UI and help text have been significantly improved for clarity and ease of use.
  • Modernized Tooling: The development toolchain has been upgraded to modern standards.
  • Added Examples: A built-in example flow for stored procedures is now included.
View more commits and changelog
Version: 1.0.0
Updated 2 months ago
Rating: 3.3 6
1451 in the last week
  • oracle-server
  • oracledb
  • oracle
  • sql
  • oracledb
  • thin
  • wallet
  • adb
  • autonomous-database
  • plsql
