node-red-contrib-opensky-network 0.1.0
Node-RED node for OpenSky Network
npm install node-red-contrib-opensky-network
Node-RED node to retrieve flight data from OpenSky Network API.
To install the stable version, use the Menu - Manage palette - Install option and search for node-red-contrib-opensky-network, or run the following command in your Node-RED user directory, typically ~/.node-red
(1) Place the OpenSky Network node to the workspace on the Node-RED flow editor
(2) Add and connect to the worldmap node in node-red-contrib-web-worldmap module
(3) Input 4 values (southern latitude, western longitude, north latitude, and eastern longitude) to the property of the OpenSky Network node
(4) Deploy the flow and open the worldmap UI via http://localhost:1880/worldmap/.
After opening the worldmap UI, you can see flight data on the UI in real-time.
Demonstration
The demonstration slides and video in Japanese are available on the following URL.
Version: 0.1.0
Updated 5 years, 9 months ago
15 in the last week
  • opensky-network
  • opensky network
  • node-red-nodegen
