node-red-contrib-openid 1.1.0
Node-RED node to integrate OpenID Connect in flows
npm install node-red-contrib-openid
Node-RED node to use OpenID Connect with HTTP request nodes.
This node uses the certified OpenID client library: node-openid-client
Screenshot
Once authenticated with the OpenID provider, each message passing through this node obtains a fresh access token.
This access token is stored into this message property: msg.access_token
In order to be usable with the HTTP node, the access token is also added to HTTP headers: msg.headers['Authorization']
Version: 1.1.0
Updated 7 years, 8 months ago
58 in the last week
  • openid-credentials
  • openid
  • openid
  • oidc
