node-red-contrib-openhab2-helper 0.2.4
Node-RED openhab2 helper nodes
npm install node-red-contrib-openhab2-helper
NODE-RED-CONTRIB-OPENHAB2-HELPER
Install via the pallet manager or by running the following in the Node-RED user directory (usually ~/.node-red):
This node converts between different color representations, it can convert between the following systems.
  • RGB - Red, Green, Blue
  • HSL - Hue, Saturation, Level
  • HSV - Hue, Saturation, Value (brightnes)
  • CSS - CSS color names
Inputs
For the first 3 input modes the node will attempt to determine the input format of msg.payload from the 3 following:
  • a string with defined separator.
  • a 3 segment array with values between 0-255 for RGB.
  • a 3 segment array for HSL and HSV with Hue is between 0-360 and Saturation, Level, values 0-100.
  • a object with keys red,green,blue with values between 0-255.
  • a object with keys hue,saturation,lightness or value,brightness with values between 0-360 for hue and 0-100 for the others.
For the CSS input mode the msg.payload should be a string containing the name of a CSS color.
Outputs
Output type can be configured to be either a 3 element array, an object or a string. The 3 element array will contian the aproprate values in the same order as expected. Objects will have matching keys and the string will be the values from the array joined with a separator.
If the CSS output mode is selected then the output type will be forced to be a string.
Version: 0.2.4
Updated 7 years, 3 months ago
27 in the last week
  • openhab2-helper-color-convert
  • openhab
  • homekit
  • color
