node-red-contrib-openfaas-gateway 1.4.1
Call your OpenFaaS function from Node RED, with standard gateway defined as http://gateway:8080
npm install node-red-contrib-openfaas-gateway
Node Red OpenFaaS Gateway
this is fork of Node Red Openfaas that has another default gateway set to http://gateway:8080
Node Red OpenFaaS
  • Setup OpenFaas as described on https://www.openfaas.com
  • add the node to your node-red installation, for example using node-red-admin CLI
    node-red-admin install openfaas
Add the openfaas node and set your function name as in OpenFaas
Example: Markdown live viewer
This example will watch a file on your disk and render it with the func_markdown to a webpage at http://127.0.0.1:1880/markdown
Example
editor result
  • Change the Watch README.md filepath to a *.md file you want to edit and hit Deploy
  • Go to http://127.0.0.1:1880/markdown
  • Open the file you specified at first step and start editing, the webpage will show you the rendered output as you save
Flow source
Use the import tool in node-red to use the flow
[{"id":"c5875ece.dcc13","type":"openfaas","z":"825d97d4.f5a6b","name":"func_markdown","x":540,"y":240,"wires":[["7f9d2e99.7d416"]]},{"id":"d19c27de.ad9ee8","type":"http in","z":"825d97d4.f5a6b","name":"","url":"/markdown","method":"get","upload":false,"swaggerDoc":"","x":300,"y":60,"wires":[["581c020d.c68bac"]]},{"id":"3fd9cf17.fc844","type":"http response","z":"825d97d4.f5a6b","name":"","x":630,"y":60,"wires":[]},{"id":"9a0d4cd0.99fb7","type":"file in","z":"825d97d4.f5a6b","name":"Read file","filename":"","format":"utf8","chunk":false,"sendError":false,"x":400,"y":180,"wires":[["c5875ece.dcc13"]]},{"id":"8a8e7c4a.bb2ee","type":"watch","z":"825d97d4.f5a6b","name":"Watch README.md","files":"./node_modules/openfaas/README.md","recursive":"","x":130,"y":180,"wires":[["5c35876e.e82de8"]]},{"id":"7f9d2e99.7d416","type":"websocket out","z":"825d97d4.f5a6b","name":"","server":"a20f695c.ac4078","client":"","x":740,"y":180,"wires":[]},{"id":"581c020d.c68bac","type":"template","z":"825d97d4.f5a6b","name":"web page","field":"payload","fieldType":"msg","format":"html","syntax":"plain","template":"<html>\n <head>\n <title>Markdown live viewer</title>\n <link rel=\"stylesheet\" href=\"https://cdnjs.cloudflare.com/ajax/libs/github-markdown-css/2.9.0/github-markdown.min.css\" />\n </head>\n <body class=\"markdown-body\">\n <div id=\"markdown\">\n <h1>Waiting for updates</h1>\n <p>Start editing your file to see the changes</p>\n </div>\n <div><pre id=\"updated\"></pre></div>\n \n <script>\n var ws = new WebSocket(\"ws://127.0.0.1:1880/watchfile\");\n \n ws.onmessage = function(event) {\n \n var markdown = document.getElementById(\"markdown\");\n var updated = document.getElementById(\"updated\");\n \n var html = event.data;\n var updatedstr = \"Last update: \" + new Date().toLocaleTimeString();\n \n markdown.innerHTML = html\n updated.innerHTML = updatedstr\n \n };\n \n </script>\n </body>\n</html>","output":"str","x":480,"y":60,"wires":[["3fd9cf17.fc844"]]},{"id":"5c35876e.e82de8","type":"function","z":"825d97d4.f5a6b","name":"get filename","func":"\nmsg.filename = msg.payload\n\nreturn msg;","outputs":1,"noerr":0,"x":270,"y":240,"wires":[["9a0d4cd0.99fb7"]]},{"id":"a20f695c.ac4078","type":"websocket-listener","z":"","path":"/watchfile","wholemsg":"false"}]
TODO
  • Add URL and authentication as a config node
  • Use node-openfaas
  • Add a write & fire node to directly spawn function from nodered (implies build & deploy from CLI)
See LICENSE file
Version: 1.4.1
Updated 7 years, 9 months ago
7 in the last week
  • openfaas
  • gateway
  • openfaas
  • function-as-a-service
