node-red-contrib-openbeken-subflow 1.3.2
Optimized OpenBeken support for Node-RED with Dashboard 2.0 dynamic UI updates
npm install node-red-contrib-openbeken-subflow
A high-performance Node-RED subflow designed specifically for OpenBeken flashed hardware. This node simplifies the integration of devices using Flag 10 and Flag 2 (immediate MQTT state feedback), provides built-in watchdog monitoring, and supports Cross-Device Synchronization for 3-way switch configurations.
  • Closed-Loop Feedback: Automatically synchronizes with the device state using the .../1/get topic.
  • Watchdog Timer: Monitors device activity and updates the node status to "Offline" if no heartbeat is detected within 5 minutes.
  • State-Sync Groups: Support for multi-way (3-way/4-way) switching. Link multiple devices via a Global context to ensure states match even if UDP packets are dropped or firewalled.
  • Smart Sanitization: Accepts Booleans (true/false), Strings ("on"/"off"), or Numbers (1/0) and converts them to the correct format for OpenBeken.
  • Dashboard 2.0 Ready: Native support for UI updates including icon/color changes based on device connectivity.
Hardware Requirements
For the best experience, ensure your OpenBeken device has Flag 10 and Flag 2 enabled. Open your device's web console and run:Backlog Flag 10 1; Flag 2 1; restart
  1. Broker: Select your MQTT Broker configuration node.
  2. Topic Base: Enter the base MQTT topic of your device (e.g., KitchenLights). Do not include trailing slashes.
  3. Sync Group (Optional): Enter a unique string (e.g., Kitchen3Way) to link multiple nodes together. Nodes sharing the same group name will stay synchronized automatically.
Anti-Chatter & Hybrid Sync (3-Way Switching)
This subflow uses a State-Locking mechanism to prevent "Relay Chattering" (rapid oscillations) often caused by the race condition between OpenBeken UDP Groups and MQTT feedback loops.
How it Works:
  1. Physical Trigger: When a physical switch is flipped, the hardware sends a 1/get message.
  2. Lockout Window: Upon receiving a hardware state change, the subflow "locks" the Sync Group for 400ms.
  3. Loop Prevention: The subflow tags the outgoing synchronization message with source: "from_hw".
  4. Logic Gate: Any node receiving a message tagged from_hw will update its local relay but will not echo that change back out to the network. This breaks the infinite loop.
Recommended Wiring for UDP Backup:
If you want MQTT to act as a fail-safe for dropped UDP packets:
  • Wire Output 1 of Node A to Input 1 of Node B.
  • Wire Output 1 of Node B to Input 1 of Node A.
  • Connect your Dashboard UI switch to the inputs of both nodes.
Input/Output
  • Input: Send a boolean true/false or string "on"/"off" to toggle the device.
  • Output 1: Returns a clean boolean true/false based on the hardware's actual state. Perfect for updating Dashboard switches.
  • Output 2: MQTT output (Internal use, wire to MQTT Out node).
  • Output 3: Status output for custom logging or dashboard indicators.
Tips for Success
  • Dashboard 2.0: Wire a Dashboard "Switch" node to the input of any node in a Sync Group. To ensure the UI reflects changes from all physical switches, wire Output 1 of all grouped nodes back to the Dashboard Switch input.
  • LWT: This node relies on the device being "connected" to show online status. Ensure your MQTT Broker is configured to handle the device's Last Will and Testament (LWT).
Version: 1.3.2
Updated 9 months, 1 week ago
316 in the last week
  • openbeken
  • tuya
  • dashboard-2.0
  • mqtt
