node-red-contrib-openbci-eegmetrics 0.0.3
input params for eeg metrics from open bci devices
npm install node-red-contrib-openbci-eegmetrics
node-red-contrib-openbci-EEGmetrics
Node-RED
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-openbci-EEGmetrics, or run the following command in your Node-RED user directory, typically ~/.node-red
    npm i node-red-contrib-openbci-eegmetrics
During install there may be multiple messages about optional compilation. These may look like failures... as they report as failure to compile errors - but often are warnings and the node will continue to install and, assuming nothing else failed, you should be able to use it. Occasionally some platforms will require you to install the full set of tools in order to compile the underlying package.
Allows users to monitor the levels of focus on the object connected to the EEG device.
Input
Reads data from node-red-contrib-openbci-EEGmetrics
Output
The msg.payload is sent.
Version: 0.0.3
Updated 3 years ago
  • openBCI-EEGmetrics
