node-red-contrib-openai 1.0.3
Node-RED node for openai
npm install node-red-contrib-openai
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-openai, or run the following command in your Node-RED user directory, typically ~/.node-red
Wrapper openai API
Sample parameters
msg.api = 'chat/completions';
msg.params = {
    "model": "gpt-3.5-turbo",
    "messages": [
            "role": "system",
            "content": "You are a helpful assistant."
            "role": "user",
            "content": "Hello!"
    "max_tokens": 7,
    "temperature": 0
Sample Flow
You can make this json string into a flow by using the node-red flow import function.
alt
alt
Version: 1.0.3
Updated 2 years, 9 months ago
Rating: 3.9 11
131 in the last week
  • openai
  • openaiApiKey
  • node-red-contrib-contribgen
  • openai
  • chatbot
  • AI
  • search api
  • AI 검색
  • Completion
  • image generation
  • Text Embeddings
  • Fine tunes
  • Moderations
  • nodejs
