node-red-contrib-open-food-facts 0.3.0
A Node-RED node that provides easy integration with the Open Food Facts API. Search for products, retrieve product information, add products, and manage product images.
npm install node-red-contrib-open-food-facts
Node-RED Open Food Facts
License: MIT Node.js CI npm version
A Node-RED integration for the Open Food Facts API, providing easy access to food product information, nutrition facts, and ingredient details from the world's largest open food database.
  • Product Lookup: Retrieve detailed product information by barcode
  • Product Search: Search for products using various criteria (name, brand, category, etc.)
  • Taxonomy Access: Access categorized data for additives, allergens, brands, and more
  • Product Management: Add new products and upload product photos (requires authentication)
  • Insights Access: Get random insights from Robotoff for product improvement
  • Asynchronous Operations: All API calls are non-blocking
  • Error Handling: Comprehensive error handling with custom error types
  • Type Safety: Built with modern JavaScript features
Install using the Node-RED palette manager or via npm:
Basic Nodes
OpenFoodFacts Get Product
Retrieve product information by barcode.
Inputs:
  • msg.payload: Barcode string (if not configured in node)
Outputs:
  • msg.payload: Product object with details like name, brand, ingredients, nutrition facts
OpenFoodFacts Search Products
Search for products using various filters.
Inputs:
  • msg.payload: Search parameters object
Example search parameters:
  "search_terms": "chocolate",
  "brands": "Nestle",
  "categories": "snacks",
  "page": 1,
  "pageSize": 20
Outputs:
  • msg.payload: Search results including count, page information, and products array
OpenFoodFacts Get Taxonomy
Access categorized data (additives, allergens, brands, etc.).
Inputs:
  • msg.payload: Taxonomy type (e.g., "additives", "allergens", "brands")
Outputs:
  • msg.payload: Taxonomy data object
Extended Nodes
OpenFoodFacts Add Product
Add a new product to the OpenFoodFacts database (requires authentication).
Configuration:
  • Username and password credentials required
Inputs:
  • msg.payload: Product data object with code, brands (optional), labels (optional)
Outputs:
  • msg.payload: API response
OpenFoodFacts Upload Photo
Upload a photo for a product (requires authentication).
Configuration:
Inputs:
  • msg.payload: Object containing:
    • barcode: Product barcode
    • image: Image file
    • type: Object with field (front/ingredients/nutrition) and languageCode
Outputs:
OpenFoodFacts Get Additives
Retrieve the additives taxonomy.
Outputs:
  • msg.payload: Additives taxonomy data
OpenFoodFacts Get Allergens
Retrieve the allergens taxonomy.
Outputs:
  • msg.payload: Allergens taxonomy data
OpenFoodFacts Get Brands
Retrieve the brands taxonomy.
Outputs:
  • msg.payload: Brands taxonomy data
OpenFoodFacts Get Random Insight
Get random insights from OpenFoodFacts Robotoff.
Configuration:
  • count: Number of insights to retrieve (default: 1)
  • lang: Language code for filtering (optional)
Outputs:
  • msg.payload: Random insights from Robotoff
Example Flows
Basic Product Lookup
        "id": "inject-barcode",
        "type": "inject",
        "payload": "3017620422003",
        "payloadType": "str",
        "topic": "",
        "name": "Inject Barcode",
        "wires": [["get-product"]]
        "id": "get-product",
        "type": "openfoodfacts-get-product",
        "wires": [["debug"]]
        "id": "debug",
        "type": "debug",
        "active": true,
Search by Category
        "id": "search-inject",
        "type": "inject",
        "payload": "{\"categories\": \"beverages\", \"page\": 1}",
        "payloadType": "json",
        "topic": "",
        "name": "Search Beverages",
        "wires": [["search-products"]]
        "id": "search-products",
        "type": "openfoodfacts-search-products",
        "id": "debug",
        "type": "debug",
        "active": true,
API Reference
Product Object Structure
  "code": "3017620422003",
  "product_name": "Nutella",
  "brands": "Ferrero",
  "categories": "Spreads, Sweet spreads, Chocolate spreads",
  "ingredients_text": "Sugar, Palm oil, Hazelnuts...",
  "nutriments": {
    "energy_100g": 2252,
    "fat_100g": 30.9,
    "carbohydrates_100g": 57.5,
    "proteins_100g": 6.3
  // ... more fields
Search Parameters
Parameter Type Description
search_terms string General search query
brands string Filter by brand
categories string Filter by category
code string Filter by barcode
countries string Filter by country
page number Page number (default: 1)
pageSize number Results per page (default: 20)
Error Handling
The nodes emit errors that can be caught using a catch node. Common errors include:
  • Product not found
  • Invalid barcode format
  • Network connectivity issues
  • API rate limiting
Testing
Run the test suite:
npm test
Automated PR Reviews
This repository uses automated PR reviews powered by Amazon Bedrock and Claude AI via GitHub Actions. When you create a pull request, the workflow will automatically:
  • Analyze your code changes
  • Provide intelligent feedback and suggestions
  • Check for potential issues and improvements
Setup Requirements
To enable automated PR reviews, repository administrators need to configure the following secrets in Settings → Secrets and variables → Actions → Repository secrets:
  • AWS_ACCESS_KEY_ID: Your AWS access key with Bedrock permissions
  • AWS_SECRET_ACCESS_KEY: Your AWS secret access key
The workflow uses Claude 3 Haiku via Amazon Bedrock for fast, intelligent code analysis and provides comprehensive reviews including performance and security feedback.
Contributing
Contributions are welcome! Please see our Contributing Guidelines for details.
Credits
This node uses the Open Food Facts API. Open Food Facts is a collaborative project with contributors from around the world.
Support
Acknowledgments
  • Open Food Facts team for maintaining the amazing food products database
  • Node-RED community for the excellent IoT platform
Version: 0.3.0
Updated 1 year, 6 months ago
133 in the last week
  • openfoodfacts-get-product
  • openfoodfacts-search-products
  • openfoodfacts-get-taxonomy
  • openfoodfacts-add-product
  • openfoodfacts-upload-photo
  • openfoodfacts-get-additives
  • openfoodfacts-get-allergens
  • openfoodfacts-get-brands
  • openfoodfacts-get-random-insight
  • openfoodfacts
  • open-food-facts
  • food
  • nutrition
  • ingredients
  • barcode
  • api
  • client
  • wrapper
