node-red-contrib-opcua-suite 0.2.0
A modern OPC UA suite for Node-RED — Client/Server plus OPC UA PubSub (UDP-UADP / MQTT) with shared connections, batch operations, drag-and-drop certificates, and a clean msg-driven API
npm install node-red-contrib-opcua-suite
Sponsor
An OPC UA suite for Node-RED.
  • Shared connections — All nodes referencing the same endpoint share one TCP connection (ref-counted)
  • Batch read/write — Single OPC UA service call via msg.items or payload object
  • Item collector — Chain opcua-item nodes visually for batch operations
  • Drag & drop certificates — Upload certs directly in the editor UI
  • Reconnect handling — keepSessionAlive + session recovery + connection fallback
  • All-in-one client — Read, write, subscribe, browse, method, history in one node
  • ExtensionObject support — Read/write structured types with automatic serialization
  • Discovery — getendpoints, registernodes, translatebrowsepath
  • Status propagation — Shared endpoint broadcasts connection state to all nodes
  • OPC UA PubSub — opcua-publisher / opcua-subscriber worker nodes over UDP-UADP multicast or MQTT (UADP or JSON), with cyclic/KeepAlive and msg-driven publishing — see OPC UA PubSub
Quick Start
1. Read a variable
[inject] → [OPC UA Client] → [debug]
Set msg.topic to a NodeId (e.g. ns=2;s=Temperature) in the inject node. Set the client's default operation to Read. Done.
2. Batch read multiple variables
[inject] → [Item: Temp] → [Item: Pressure] → [OPC UA Client] → [debug]
Each OPC UA Item node adds its variables to msg.items. The client reads them all in one OPC UA service call. No function node needed.
3. Write a value
Set msg.payload to the value (e.g. 25.5) and msg.topic to the NodeId in the inject node. Set the client's default operation to Write. DataType is auto-detected from the JS type.
4. Subscribe to live changes
Set msg.topic to the NodeId and the client's default operation to Subscribe. Click inject once — every value change on the server produces a new message.
Import ready-to-use flows from Menu → Import → Examples → node-red-contrib-opcua-suite.
opcua-endpoint (Config Node)
Shared connection configuration. All nodes referencing the same endpoint share one TCP connection (ref-counted: connected on first node, disconnected when the last node closes).
flowchart LR
    R["Client: Read"] --> EP
    W["Client: Write"] --> EP
    S["Client: Subscribe"] --> EP
    B["Browser"] --> EP
    M["Method"] --> EP
    E["Event"] --> EP
    EP{{"opcua-endpoint<br/>(1 shared connection,<br/>ref-counted)"}} -->|"opc.tcp"| SRV[("OPC UA Server")]
With Session Pool > 1 the endpoint holds N sessions instead of one — see Session pool routing.
Field Description
Endpoint URL opc.tcp://localhost:4840
Security Mode None, Sign, SignAndEncrypt
Security Policy None, Basic128Rsa15, Basic256, Basic256Sha256, Aes128/Aes256
Username / Password Optional credentials
Certificates Drag & drop upload for client cert, private key, CA cert, X509 user token
Session Pool Number of sessions (default 1 = single shared session). >1 round-robins stateless reads/writes/browse across N sessions; subscriptions & registered nodes stay on the primary. Only helps when a single session is the bottleneck — see Benchmark.
Op. Timeout Per-operation timeout in ms (default 10000). Raise it for slow PLCs — an operation that overruns marks the connection dead and forces a reconnect on the next message.
Authentication priority: X509 User Token > Username/Password > Anonymous.
opcua-client (All-in-One)
Single node for all OPC UA operations. Set via msg.operation or the default operation in the node config.
Operation msg.topic / msg.nodeId msg.payload Description
read NodeId — Read a single variable
readmultiple — — Read all items in msg.items
write NodeId Value to write Write a single variable
writemultiple — — Write all items in msg.items
subscribe NodeId — Subscribe to value changes
unsubscribe NodeId — Stop subscription
browse NodeId (default: RootFolder) — Browse address space
method — Input arguments Call a method (needs msg.objectNodeId + msg.methodNodeId)
history NodeId — Read historical values (needs msg.startTime + msg.endTime)
getendpoints — — Discover server endpoints
readattribute NodeId — Read BrowseName, DisplayName, etc.
registernodes — — Register nodes for fast access
translatebrowsepath — Browse path Translate browse path to NodeId
When msg.items is present, the client automatically switches to batch mode — even if the operation is set to read or write.
Every output (including the error output) carries the resolved operation in msg.operation — "read", "write", "browse", … (lower-cased), or the more specific "readmultiple" / "writemultiple" when a batch ran — so a downstream switch node can branch on it.
Advanced settings (resilience): the client connects on deploy (Connect on deploy, default on) so its status reflects the real connection immediately. On a connection-lost error each message is retried up to Operation Retries times (default 3) with exponential Retry Backoff (default 100 ms, capped at 2 s) — see Resilience hardening.
opcua-item (Item Collector)
Defines OPC UA items (variables) for batch operations. Each item needs a NodeId and optionally a Name and DataType.
Chain pattern — multiple Item nodes in series, each adds to msg.items:
[inject] → [Item: Temp] → [Item: Pressure] → [Item: Speed] → [Client]
List pattern — all items in a single node:
[inject] → [Item: Temp, Pressure, Speed] → [Client]
In Collector Mode (default), items are appended to msg.items for batch operations. In Legacy Mode (collector off), only the first item is set on msg.topic / msg.datatype for single operations.
DataType (per item, write-only) covers the full OPC UA type set: booleans/integers (Boolean, SByte/Byte, Int16–Int64, UInt16–UInt64), floating point (Float, Double), text/time (String, DateTime, LocalizedText, QualifiedName, XmlElement), binary/identifier types (ByteString, Guid, NodeId, ExpandedNodeId, StatusCode), the structured ExtensionObject, and an Advanced (rarely writable) group (DataValue, Variant, DiagnosticInfo, offered for completeness — incompatible values surface a server write error). The DataType is only used for writes — reads always return the server's type. Leave it on Auto to let node-opcua infer the type from the JS value.
Array ([]) — tick the per-item [] box to write the value as an array (ValueRank); the payload must be a JS array (e.g. [1, 2, 3]). Sets arrayType: "Array" on the item (or msg.arrayType for a single write).
ExtensionObject — selecting ExtensionObject reveals a DataType NodeId field (e.g. ns=2;i=3003); the payload is a plain JSON object of the struct fields. See ExtensionObjects.
Operation (optional) sets msg.operation (Read / Write / Subscribe / Unsubscribe) so the downstream client knows what to do without a separate config — leave on don't set to keep the client's default or an existing msg.operation.
Unwrap single value sets msg.unwrapSingle = true. When a read resolves to exactly one item, the client delivers the scalar value in msg.payload (e.g. false) instead of a one-element array ([{value:false, …}]). The same option also exists on the client node; see Single-value reads.
opcua-browser
Browses the OPC UA address space. Send a NodeId via msg.topic to browse from that node, or leave empty to start from RootFolder.
Input Description
msg.topic / msg.nodeId Starting NodeId (default: RootFolder)
msg.recursive Set to true for recursive browsing
Output: msg.payload contains an array of references with browseName, nodeId, nodeClass, and typeDefinition.
opcua-browse-client
Interactive address space browser with an editor tree view. Select variables visually in the editor, then read or subscribe to them at runtime. No NodeIds to type — just click.
Modes:
  • Read — trigger via inject to read all selected items
  • Subscribe — automatically subscribes on deploy, emits a message per value change
opcua-method
Calls an OPC UA method. Configure the Object NodeId and Method NodeId in the node or pass them via msg.objectNodeId / msg.methodNodeId.
Input arguments via msg.payload as an array:
[{"dataType": "Double", "value": 3.14}, {"dataType": "String", "value": "hello"}]
Or simple values (datatype auto-detected): [3.14, "hello", true]
Output: msg.payload = array of return values, msg.statusCode = method status.
opcua-event
Subscribes to OPC UA events and alarms.
Config Description
Source NodeId Node to monitor (default: i=2253 — Server node)
Event Type e.g. BaseEventType, AlarmConditionType
Send msg.action = "subscribe" to start, msg.action = "unsubscribe" to stop. Each event produces a message with eventType, severity, message, time, and sourceName.
opcua-server
Embedded OPC UA server. Starts automatically on deploy. Build the address space at runtime via msg.command:
Command Required fields Description
addFolder msg.folderName Create a folder in the address space
addVariable msg.variableName, msg.datatype Add a variable (optional: msg.initialValue)
addObject msg.objectName Add an object node
addMethod msg.methodName, msg.parentNodeId Add a callable method under an object node (optional: msg.inputArguments, msg.outputArguments, msg.func — see the security note below)
setValue msg.nodeId, msg.payload Update a variable's value. msg.datatype is optional — the variable's own declared DataType is used when it is absent
setWritable msg.nodeId Make a variable writable by clients
deleteNode msg.nodeId Remove a node
raiseEvent msg.sourceNodeId, msg.message Raise an event
getServerInfo — Get session count, endpoint URL, server state
Security — msg.func: addMethod can bind a method handler from a JavaScript body carried in msg.func, which the server evaluates with new Function(). Unlike a Function node that body arrives with the message, so any upstream node fed from outside (http in, MQTT, …) can execute arbitrary code in the Node-RED process. Since 0.2.0 it is off by default — enable Allow method code from msg.func under Security in the node configuration when every path into the node is trusted.
opcua-pubsub-connection (Config Node)
Shared PubSub transport configuration. Picks the transport (UDP multicast or MQTT), the PublisherId, and (for MQTT) the broker URL / topic prefix / QoS. The opcua-publisher and opcua-subscriber nodes reference it and share one ref-counted transport. See OPC UA PubSub for the full configuration hierarchy.
opcua-publisher
Publishes a DataSet over the referenced opcua-pubsub-connection. Declares a WriterGroup with one or more DataSetWriters. Acyclic (default): each input msg.payload field map becomes one NetworkMessage. Cyclic: publishes at PublishingInterval, sending a KeepAlive when no value changed. See OPC UA PubSub.
opcua-subscriber
Receives DataSets over the referenced opcua-pubsub-connection. Declares a DataSetReader filtering on PublisherId / WriterGroupId / DataSetWriterId, decodes each NetworkMessage, and emits one msg per matched DataSetMessage. A ConfigurationVersion mismatch raises a visible node.error(). See OPC UA PubSub for the full msg shape.
OPC UA PubSub
PubSub adds broker-less (UDP-UADP multicast) and broker-mediated (MQTT, UADP or JSON) publish/subscribe alongside the Client/Server nodes. The three shipped combinations are UDP-UADP, MQTT-UADP, and MQTT-JSON — there is no UDP-JSON combination. Configuration lives on the opcua-pubsub-connection config node (transport, multicast group / broker URL, PublisherId); the opcua-publisher and opcua-subscriber worker nodes reference it.
Configuration hierarchy
flowchart TD
    subgraph PUB["Publisher side"]
        C1["opcua-pubsub-connection<br/>(transport, PublisherId)"] --> WG["WriterGroup<br/>(writerGroupId, publishingInterval)"]
        WG --> DW1["DataSetWriter"]
        WG --> DW2["DataSetWriter …"]
        DW1 --> PDS1["PublishedDataSet<br/>fields[]: {name, dataType}"]
        DW2 --> PDS2["PublishedDataSet"]
    end
    subgraph SUB["Subscriber side"]
        C2["opcua-pubsub-connection"] --> DR["DataSetReader<br/>filter: PublisherId /<br/>WriterGroupId / DataSetWriterId"]
    end
    PDS1 -.->|"NetworkMessage<br/>(UDP-UADP / MQTT-UADP / MQTT-JSON)"| DR
Publisher — opcua-pubsub-connection → WriterGroup → DataSetWriter → PublishedDataSet:
  • One WriterGroup per publisher (writerGroupId, publishingInterval, priority, maxNetworkMessageSize).
  • One or more DataSetWriters (edited as a JSON array in the writers field), each bound to one PublishedDataSet.
  • The PublishedDataSet fields[] of { name, dataType } (e.g. { "name": "Temperature", "dataType": "Double" }) type the outgoing values.
Subscriber — opcua-pubsub-connection → DataSetReader:
  • The DataSetReader filters on PublisherId / WriterGroupId / DataSetWriterId — at least one is required.
  • For MQTT-JSON filter on publisherId (and optionally dataSetWriterId): JSON NetworkMessages carry no groupHeader, so writerGroupId is unavailable.
Publisher input
msg.payload is an object keyed by field name — { <fieldName>: <rawValue> }. Each declared PublishedDataSet field present in the payload becomes a Variant in one keyframe; missing fields are omitted, never fabricated. One inbound msg produces one outbound NetworkMessage.
  • Acyclic (default): publishes once per inbound msg.
  • Cyclic: publishes every publishingInterval ms, sending a keyframe when values changed and a KeepAlive NetworkMessage when nothing changed since the last tick.
Subscriber output (msg shape)
Per matched DataSetMessage the subscriber emits one msg:
Field Description
msg.payload { [fieldName]: value } — Variant/DataValue wrappers removed
msg.publisherId PublisherId of the source connection
msg.writerGroupId WriterGroup id (undefined for JSON encoding — no groupHeader)
msg.dataSetWriterId DataSetWriter id
msg.sequenceNumber NetworkMessage sequence number (DataSetMessage fallback for JSON)
msg.timestamp Date of the DataSetMessage
msg.statusCode 16-bit DataSetMessage status summary (0 = Good), i.e. the Part 14 §7.2.4.5.2 Good/Bad/Uncertain summary — not a full 32-bit OPC UA StatusCode
msg.encoding "uadp" or "json"
msg.transport "udp" or "mqtt"
msg.topic MQTT only — omitted entirely for UDP
A matched DataSetMessage whose ConfigurationVersion differs from the optional expectedConfigVersion raises a visible node.error() and is dropped — it is never silently swallowed.
Encoding rules
The UDP transport carries UADP binary NetworkMessages only — selecting JSON over a UDP connection is rejected at startup. MQTT allows either UADP or JSON. UDP-JSON is not a shipped combination. JSON is the cloud-friendly, self-describing choice (each message carries its own field names and types, no metadata pre-exchange).
UDP multicast NIC selection
The UDP socket always binds to 0.0.0.0. Leave multicastInterface at 0.0.0.0 to let the OS choose the outgoing NIC. On a multi-NIC host the OS may pick the wrong interface for multicast — set multicastInterface to the host's IP on the PubSub LAN if datagrams are not received. This field only pins the interface used to join the group and send.
PubSub examples
See example flows 10 - PubSub UDP-UADP Loopback (self-contained, no external infra), 11 - PubSub MQTT-UADP, and 12 - PubSub MQTT-JSON. Flows 11 and 12 require a local MQTT broker at mqtt://localhost:1883 (e.g. docker run -p 1883:1883 eclipse-mosquitto, or docker compose -f docker-compose.dev.yml up -d, which publishes one on 1883).
Reference
See docs/MSG-SCHEMA.md for the full message field reference.
NodeId Formats
Format Example
String ns=2;s=MyVariable
Numeric ns=2;i=1234
GUID ns=2;g=550e8400-e29b-...
Short i=84, s=MyVar (ns=0)
Well-known RootFolder, ObjectsFolder, TypesFolder, Server
DataType Auto-Detection
JS Type OPC UA DataType
boolean Boolean
integer number Int32
float number Double
string String
Date DateTime
Explicit override: msg.datatype = "UInt16" or in item config. The item node's DataType dropdown offers the full OPC UA scalar set (see opcua-item); the override applies to writes only.
Single-value reads
A read that resolves to exactly one item — one Item node, or a single-entry msg.items — returns a one-element array in msg.payload by default ([{value:false, …}]), because the client treats msg.items as a batch read.
Enable Unwrap single value on the client node (or set msg.unwrapSingle = true, e.g. via the item node's checkbox) to receive the scalar value directly in msg.payload, with its metadata (dataType, statusCode, nodeId, sourceTimestamp, serverTimestamp) flattened onto msg. msg.unwrapSingle overrides the node setting per message; reads of two or more items are never unwrapped.
ExtensionObjects (Structured Types)
Reading: ExtensionObjects are automatically serialized to plain JSON in msg.payload. The msg.dataType will be "ExtensionObject" with a _typeName field.
Writing: Set msg.datatype = "ExtensionObject" and msg.dataTypeNodeId to the DataType definition NodeId:
    "topic": "ns=2;s=MyStructVar",
    "datatype": "ExtensionObject",
    "dataTypeNodeId": "ns=2;i=3003",
    "payload": { "temperature": 25.5, "unit": "Celsius" }
Examples
Import ready-to-use flows in the Node-RED editor: Menu → Import → Examples → node-red-contrib-opcua-suite.
Available examples:
  1. Read Single Variable — inject → client → debug
  2. Batch Read with Item Collector — inject → item → item → client → debug
  3. Write a Value — inject → client → debug
  4. Subscribe to Changes — inject → client → debug
  5. Browse Address Space — inject → browser → debug
  6. Event Subscription — inject → event → debug
  7. Call a Method — inject → method → debug
  8. Server with Variables — inject → server → debug
  9. Session Retry Test — inject → client → debug
  10. PubSub UDP-UADP Loopback — self-contained, no external infra
  11. PubSub MQTT-UADP — requires a local MQTT broker
  12. PubSub MQTT-JSON — requires a local MQTT broker
All examples work without function nodes.
Two comprehensive, self-asserting validation flows also live in the GitHub repo (not shipped in the npm package — they target the bundled Docker test stack): 13 - PubSub Full Validation (9 PubSub scenarios: every transport × encoding, multi-writer, cyclic/KeepAlive, chunking, filtering, ConfigurationVersion mismatch) and 14 - Full Suite Validation (24 tabs exercising every node — client read/write/subscribe/browse/method, item collector, browser, browse-client, method, event, embedded server, authentication, plus all PubSub scenarios). Each tab emits a [VALIDATE] … PASS/FAIL line.
Run them against the dev stack, which provides everything both flows address — the OPC UA test server as opcua-server:4840 and an anonymous MQTT broker as val-mosquitto:1883:
# import the flow, deploy, then click every inject node
Two tabs are two-step by design: T5 (cyclic/KeepAlive), T8 (filtering) and T9 (ConfigurationVersion) each have a reset+publish inject and a check inject. Leave the documented ~2 s gap between them — a KeepAlive cannot arrive before the next publishing interval elapses, and firing the check immediately reports FAIL - no keepalive for what is only impatience.
Docker
docker compose up -d          # Start Node-RED + OPC UA test server
# Node-RED: http://localhost:1881
# Test server: opc.tcp://localhost:4841
docker compose build --no-cache && docker compose up -d --force-recreate  # Rebuild
Testing
npm test                       # 767 unit tests (8 pending)
npm run lint                   # ESLint
npm run format:check           # Prettier
node test/live-integration.js  # 36 live integration tests (requires Docker)
live-integration.js drives a running Node-RED over its admin API and the /comms websocket on port 1880, so run it against the dev stack (docker compose -f docker-compose.dev.yml up -d), which publishes that port. The plain stack maps Node-RED to 1881 and the script will not reach it.
Benchmark & Stress Test
Drives the real OpcUaClientManager (the engine behind opcua-client) against the bundled test server and reports throughput, latency percentiles (p50/p95/p99), and error counts under sustained concurrent load. The test server is started automatically. Phases:
  • Throughput/latency — read (sequential + concurrent), readMultiple, write
  • Resilience — connect/disconnect churn (lifecycle leaks) and reconnect under load (forced session loss mid-stream, measures recovery rate)
  • Subscribe stress — N monitored items @100 ms, counts notifications + item/teardown errors
npm run bench             # full run  (5s/phase, 50 concurrent, 200 sub items)
npm run bench:quick       # short run (1.5s/phase) — CI-friendly
Tunable via env vars / flags:
BENCH_DURATION_MS=10000 BENCH_CONCURRENCY=100 BENCH_SUB_ITEMS=500 npm run bench
BENCH_POOL_SIZE=4 npm run bench   # exercise the opt-in session pool
node test-server/benchmark.js --no-spawn --endpoint opc.tcp://host:4840/UA/TestServer
Steady-state phases must be error-free or the run exits non-zero (so it doubles as a load-soak smoke test). The reconnect phase is a deliberate fault-injection storm — it passes on recovery rate (≥99%) + final connected state. After the resilience hardening below it now recovers 100% of ops from forced session drops in typical runs.
Indicative numbers on an 8-core dev box (node 20):
Phase Throughput Latency
read (sequential) ~1,100 ops/s p50 ≈ 0.7 ms
read (×50 concurrent) ~6,500 ops/s p50 ≈ 6 ms, p99 ≈ 20 ms
readMultiple (7/call) ~5,000 ops/s ≈ 35k values/s
write (×50 concurrent) ~5,500 ops/s p50 ≈ 7 ms
connect/disconnect churn — ~60 ms/cycle
reconnect under load (4 forced drops) recovers 100% ops ok, 0 errors
subscribe (200 items) 127 notif/s 0 errors
Resilience hardening (implemented)
The reconnect-under-load benchmark originally surfaced ~0.2% unrecovered ops during a forced session-loss storm. The operation path now retries cleanly:
flowchart TD
    IN["msg in"] --> ENS["ensureConnected()"]
    ENS --> OP["run operation<br/>(read / write / browse / ...)"]
    OP --> OK{"success?"}
    OK -->|yes| SEND["status: connected<br/>send msg"]
    OK -->|error| LOST{"connection-lost?<br/>(_isConnectionLostError)"}
    LOST -->|"no (e.g. BadNodeId)"| FAIL["status: error<br/>node.error + msg.error"]
    LOST -->|yes| BUDG{"attempts left?<br/>(< maxOperationRetries)"}
    BUDG -->|no| FAIL
    BUDG -->|yes| RC["reconnect()<br/>(cool-down coalesced)"]
    RC --> BACK["exponential backoff<br/>(retryBackoffMs, cap 2s)"]
    BACK --> ENS
Three fixes:
  • Bounded operation retry (opcua-client node). A connection-lost operation is now retried up to maxOperationRetries times (default 3) with exponential backoff (retryBackoffMs, capped at 2 s) instead of exactly once — so a second drop landing during the first reconnect no longer fails the message.
  • Reconnect cool-down (OpcUaClientManager). After a successful reconnect, a redundant reconnect() arriving within reconnectCooldownMs (default 250 ms) while still connected is a no-op, removing the race where a burst of callers each forced another teardown+connect that briefly flipped isConnected to false under other in-flight operations.
  • Wider connection-lost classification. _isConnectionLostError() now also recognises the channel-teardown abort ("Transaction has been canceled because client channel is being closed") and BadSessionClosed / BadSessionIdInvalid / BadConnectionClosed / BadSecureChannelClosed status errors, so those are retried rather than surfaced as failures.
  • Optional session pool (implemented, opt-in). The endpoint config node has a Session Pool field (default 1 = single shared session, unchanged). With poolSize > 1, stateless operations (read/write/browse/...) round-robin across N sessions; session-bound operations (subscriptions, registered nodes) stay on the primary member. A pool only raises throughput when a single session/channel is genuinely the bottleneck (high-latency links, servers that serialize per session) — on a local low-latency server the server/CPU is the limit, so a pool shows no gain there. Default behaviour is byte-for-byte unchanged at poolSize 1.
flowchart TD
    OP["operation"] --> KIND{"operation kind?"}
    KIND -->|"session-bound<br/>subscribe · registerNodes ·<br/>constructExtensionObject"| PRIM["primary member<br/>(members[0])"]
    KIND -->|"stateless<br/>read · write · browse ·<br/>callMethod · history"| RR["round-robin<br/>next connected member"]
    RR --> M0["session 0 (primary)"]
    RR --> M1["session 1"]
    RR --> M2["session N…"]
    PRIM --> M0
Session-bound work keeps its session affinity on the primary; stateless work spreads across all connected sessions. If no member is connected, the call falls through to the primary so the retry/reconnect path above kicks in.
Further ideas
  • readMultiple is the throughput win. One batch call returns ~7× the values of a single read at similar latency — prefer it (or subscriptions) over many single read ops in hot flows.
Sponsor this project
This package is developed and maintained in my own time. If it saves you some, consider supporting it:
Sponsor on GitHub Buy Me a Coffee
Apache License 2.0 — see LICENSE and NOTICE.
Copyright 2026 blanpa
Contributing and forks
Pull requests are welcome, including large ones. If you are planning a bigger change — a dependency migration, a restructure, new nodes — please open an issue first. We are happy to discuss it and to land substantial work here; that is usually less effort than maintaining a parallel package, and it keeps a single place for users to report bugs.
If you do publish a fork under its own package name, please also rename the Node-RED node type IDs (for example myprefix-opcua-suite-*) and use your own palette category. Node-RED refuses to register a node type that is already claimed, so identical type IDs make it impossible to install both packages side by side.
Version: 0.2.0
Updated 2 months, 2 weeks ago
Rating: 3.9 7
367 in the last week
  • opcua-client
  • opcua-server
  • opcua-item
  • opcua-endpoint
  • opcua-pubsub-connection
  • opcua-publisher
  • opcua-subscriber
  • opcua-event
  • opcua-method
  • opcua-browser
  • opcua-browse-client
  • opcua
  • opc-ua
  • opcua-pubsub
  • pubsub
  • uadp
  • mqtt
  • industrial
  • automation
  • iot
