node-red-contrib-opcua-connector-manager 1.0.1
Node-RED sidebar panel to bulk-reassign any config node references across all flows — ideal when promoting from dev to prod.
npm install node-red-contrib-opcua-connector-manager
A Node-RED sidebar panel that lists every config node reference across all flow tabs and lets you bulk-reassign them in one shot — useful when promoting flows from dev to prod.
Despite the name it works with any config node type: OPCUA connectors, MQTT brokers, HTTP request configs, database connections, whatever.
  • Sidebar panel — always accessible via the ⇄ icon, no node placement needed
  • Config-type selector — pick any type that actually exists in the workspace
  • Per-instance cards, each showing:
    • Name and detail line (endpoint URL, broker address, host…)
    • Flow-tab pills with per-flow node counts
    • Replace with dropdown
  • Bulk apply — one click to reassign all referencing nodes, then Deploy to save
  • Stale-reference detection — highlights nodes pointing to deleted config nodes
Requirements
  • Node-RED ≥ 3.0.0
  • Node.js ≥ 18.0.0
npm
Docker
COPY nodes/ /opt/nr-local-nodes/
RUN npm install /opt/nr-local-nodes/node-red-contrib-opcua-connector-manager
Open the ⇄ tab in the Node-RED right sidebar. That's it.
  1. Pick a config node type from the dropdown at the top.
  2. Each card is one config node instance. The flow pills show you exactly where it's used.
  3. Set Replace with on the cards you want to change.
  4. Click Apply Changes, then Deploy.
You can also drop the Config Node Mgr node from the Connector Manager palette onto any flow — double-clicking it opens the sidebar automatically.
Dev → Prod example
Say you have two OPCUA connectors:
Config node Endpoint
OPC Server – Dev opc.tcp://dev-plc:4840
OPC Server – Prod opc.tcp://10.0.1.5:4840
Open the panel, select OPCUA-IIoT-Connector, set Replace with to OPC Server – Prod on the dev card, click Apply, Deploy. Done.
Example flow
Import examples/config-node-manager.json via ☰ → Import.
Apache 2.0 — OWT Swiss
Version: 1.0.1
Updated 8 months, 3 weeks ago
  • opcua-connector-manager
  • opcua
  • iiot
  • config
  • connector
  • manager
  • migration
  • bulk
  • dev-to-prod
  • Arthur Cousin
