node-red-contrib-opcua-config 1.10.7
Node-RED nodes for OPC UA tag mapping and topic snapshot tables
npm install node-red-contrib-opcua-config
Node-RED nodes for OPC UA tag ID-to-name mapping, topic snapshot tables, type-based routing, and table-format mapping. Designed to work with node-red-contrib-opcua.
opcua-mapping
An editable table that maps OPC UA NodeIds to human-readable names with data type classification. Stores mappings in both file system (persistence) and Node-RED context (runtime lookup).
  • Input: Any message triggers subscription output (output 4). msg.payload = "clear" clears all mappings.
  • Output 1: One message per row — {topic: nodeId, payload: nodeId}
  • Output 2: One message per row — {topic: nodeId, payload: uns}
  • Output 3: One message per row — {topic: nodeId, payload: {id, uns, tagType}}
  • Output 4: Aggregated subscription format for OpcUa-Client — {topic: "multiple", payload: [{nodeId}], interval: 3000}
  • Popup Editor: Bulk edit mappings in a resizable window with per-column filters, Excel-compatible copy/paste (TSV format), and auto-save.
  • Context Store: Mappings stored in global or flow context as forward (id → {uns, tagType}) and reverse (uns → {id, tagType}) dictionaries.
  • Persistence: Data saved automatically to <userDir>/opcua-mapping-data/<nodeId>.json on every change. Survives restarts.
opcua-snapshot
A live snapshot viewer that stores the most recent message per msg.topic. Provides a popup viewer with auto-refresh, row filtering, and missing-topic detection.
  • Input: Stores each message by msg.topic (overwrites previous). msg.payload = "get" sends snapshot to output. msg.payload = "clear" clears all stored data.
  • Columns: Configurable comma-separated list of message property paths (e.g., topic,payload.value.value,payload.value.dataType). Supports dot notation for nested properties.
  • Missing Topic Detection: When configured with a mapping context key, topics in the dictionary that haven't received data yet are shown in orange with a MISSING badge — lets you see which configured tags are silent.
  • Output: Array of objects — one per topic with the configured column values.
  • Popup Viewer: Resizable window with Refresh, Auto-Refresh (2s), row filter, and Copy for Excel.
opcua-type-router
Validates OPC UA messages against a context lookup map, enriches them with tag metadata, applies type coercion, and routes to typed outputs.
  • Input: OPC UA messages with msg.topic matching context map entries. Case-insensitive lookup fallback.
  • Output 1 (rejected): Messages failing validation or coercion with a reason field (unknown_topic, empty_payload, null_value, bad_quality, coerce_failed).
  • Output 2-5 (typed): Validated and coerced messages enriched with msg.uns, msg.tagType, msg.value, msg.timestamp, msg.statusCode.
    • Output 2: bool/boolean/digital/bit
    • Output 3: long/int/integer/dword/word
    • Output 4: string/str/text/char
    • Output 5: float/double/real/number
  • Type Coercion: Value type is automatically converted to match tagType. Boolean ↔ number (0/1), number ↔ string (via Number()/String()), string ↔ bool ("true"/"false"/"1"/"0"). If conversion is not possible the message routes to output 1 with reason: coerce_failed.
  • Context Map: Reads from flow/global context — populated by opcua-mapping node, each entry has {uns, tagType}.
opcua-table-mapper
Maps message fields to a structured table row format with symbols (string tags) and typed columns. Useful for preparing data for database writes.
  • Input: Messages with fields to map.
  • Symbol Mappings: Map msg fields to string symbol columns.
  • Column Mappings: Map msg fields to typed columns with type conversion (auto, float, double, integer, long, boolean, string, timestamp).
  • Timestamp Field: Configurable field path for the row timestamp.
  • Output: {topic, payload: {symbols: {}, columns: {}, timestamp: ...}}
  • Field Path Syntax: Dot notation (payload.sensor.value) and array access (payload.readings[0]).
  • Source Types: msg, flow, global, str (literal), jsonata expressions.
Or for local development:
git clone <repo-url>
cd node-red-contrib-opcua-config
npm link
npm link node-red-contrib-opcua-config
Requirements
  • Node-RED >= 2.0.0
  • Node.js >= 18.0.0
MIT
Version: 1.10.7
Updated 5 months, 3 weeks ago
463 in the last week
  • opcua-mapping
  • opcua-snapshot
  • opcua-type-router
  • opcua-table-mapper
  • opcua
  • opc-ua
  • mapping
  • snapshot
  • table
  • mapper
  • table-mapper
  • type-router
