node-red-contrib-opcua-client 0.0.10
A better OPC Ua client for Node-Red
npm install node-red-contrib-opcua-client
A Node-RED node set for connecting to OPC UA servers, reading and writing node values, and supporting multiple authentication modes (anonymous, username/password, certificate).
  • OPC UA Client Node: Read and write single or multiple node values.
  • Authentication: Supports anonymous, username/password, and certificate-based authentication.
  • Configurable Security: Choose security policy and mode.
  • Session Management: Automatic session creation, keep-alive, and reconnection handling.
  • Error Handling: Node status and error reporting for all actions.
OPC UA Client
  • Actions:
    • read: Read a single node value.
    • write: Write a value to a single node.
    • read-multiple: Read multiple node values.
    • write-multiple: Write values to multiple nodes.
  • Inputs:
    • topic: NodeId for single read/write.
    • payload: Value for write, or array of nodes for multiple actions.
    • dataType: (Optional) Data type for single write actions.
    • action: (Optional) Override node action.
  • Outputs:
    • First output: Result of the OPC UA operation.
    • Second output: Status and error messages.
OPC UA Config
  • Endpoint: OPC UA server endpoint URL.
  • Security Policy & Mode: Select from supported OPC UA security options.
  • Authentication: Configure anonymous, username/password, or certificate credentials.
  1. Add an opcua-config node and configure your server endpoint, security, and credentials.
  2. Add an opcua-client node, link it to your config, and select the desired action.
  3. Inject messages with the required properties (topic, payload, dataType, etc.) to perform OPC UA operations.
OPC Ua Enum Data Type
enum DataType {
  Null = 0,
  Boolean = 1,
  SByte = 2,// signed Byte = Int8
  Byte = 3,// unsigned Byte = UInt8
  Int16 = 4,
  UInt16 = 5,
  Int32 = 6,
  UInt32 = 7,
  Int64 = 8,
  UInt64 = 9,
  Float = 10,
  Double = 11,
  String = 12,
  DateTime = 13,
  Guid = 14,
  ByteString = 15,
  XmlElement = 16,
  NodeId = 17,
  ExpandedNodeId = 18,
  StatusCode = 19,
  QualifiedName = 20,
  LocalizedText = 21,
  ExtensionObject = 22,
  DataValue = 23,
  Variant = 24,
  DiagnosticInfo = 25
Version: 0.0.10
Updated 11 months, 1 week ago
37 in the last week
  • opcua-client
  • opcua-config
  • opcua
  • node-red-contrib-opcua
