node-red-contrib-opcda-client-dynamic 0.2.0
Node-RED OPC DA dynamic Reading and Writing Node
npm install node-red-contrib-opcda-client-dynamic
This node can be used in order to read and write to OPC DA servers.
This node is based on emrebekar/node-red-contrib-opcda-client, modified opcda-read.js.
  • only valid tags is read for opcda-read when msg.payload tags is vaild.
msg.payload = { tags: ["dev1.wendu","dev1.yali"]
opcda-tags
  • for normal read( no payload tags ), only value changed tags will ouput when data change is checked. For example,devl.wendu and devl.yali were set,only devl.wendu value changed, opcda-read will only output devl .wendu
  • for dynamic read ( payload tags valid ), data change check is useless , all payload tags will output.
  • opcda-server
  • opcda-read
  • opcda-write
Input Parameters
opcda-server
Name (Optional)
Name of the OPC DA Server to be shown in node.
Address
Address of the OPC DA Server
Domain(Optional)
Domain of account if necessary.
Username(Optional)
Username of account if necessary.
Password(Optional)
Password of account if necessary.
ClsId
Class ID of the OPC DA Server.
Timeout(Optional)
Timeout of server connection.
opcda-read
Server
OPC DA server which is wanted to connect.
Group Name(Optional)
Node name to be shown in node-red.
Cache Read (Optinal)
Check if wanted to read tags from cache.
Data Change (Optional)
Check if wanted to output msg.payload when value of tag changes.
OPC DA Tags
Add OPC DA tags wanted to read.
opcda-write
Server
Name (Optional)
set msg.payload parameter with the following;
    {"itemID":"<ItemID want to set>","type":"<type of the value>","value": <value want to set>},
Accepted Data Types
  • double
  • short
  • integer
  • float
  • byte
  • long
  • boolean
  • uuid
  • string
  • char
  • date
  • currency
  • array
Screenshots
opcda-server
opcda-server
opcda-read
opcda-read
opcda-write
opcda-write
Version: 0.2.0
Updated 1 year, 6 months ago
60 in the last week
  • opcda-read
  • opcda-write
  • opcda-server
  • opcda
  • plc
  • industry4.0
  • dcom
  • opc-da
  • automation
  • i4.0
