node-red-contrib-opcda-client 0.0.7
Node-RED OPC DA Reading and Writing Node
npm install node-red-contrib-opcda-client
This node can be used in order to read and write to OPC DA servers.
  • opcda-server
  • opcda-read
  • opcda-write
Input Parameters
opcda-server
Name (Optional)
Name of the OPC DA Server to be shown in node.
Address
Address of the OPC DA Server
Domain(Optional)
Domain of account if necessary.
Username(Optional)
Username of account if necessary.
Password(Optional)
Password of account if necessary.
ClsId
Class ID of the OPC DA Server.
Timeout(Optional)
Timeout of server connection.
opcda-read
Server
OPC DA server which is wanted to connect.
Group Name(Optional)
Node name to be shown in node-red.
Cache Read (Optinal)
Check if wanted to read tags from cache.
Data Change (Optional)
Check if wanted to output msg.payload when value of tag changes.
OPC DA Tags
Add OPC DA tags wanted to read.
opcda-write
Server
Name (Optional)
set msg.payload parameter with the following;
    {"itemID":"<ItemID want to set>","type":"<type of the value>","value": <value want to set>},
Accepted Data Types
  • double
  • short
  • integer
  • float
  • byte
  • long
  • boolean
  • uuid
  • string
  • char
  • date
  • currency
  • array
Screenshots
opcda-server
opcda-server
opcda-read
opcda-read
opcda-write
opcda-write
Version: 0.0.7
Updated 6 years, 2 months ago
Rating: 2.8 5
54 in the last week
  • opcda-read
  • opcda-write
  • opcda-server
  • opcda
  • plc
  • industry4.0
  • dcom
  • opc-da
  • automation
  • i4.0
