node-red-contrib-opc-rw-pulse 1.0.2
OPC UA nodes for Node-RED: read, write, and pulse a tag TRUE then back to FALSE after a configurable delay, sharing a common connection manager.
node-red-contrib-dcu-opc
Node-RED nodes for talking to an OPC UA server: pulse a tag, subscribe to a tag's changes, or write an arbitrary value.
All three nodes share one connection manager (opc-shared.js), are
configured at runtime via a Config message (no redeploy needed to point at a
different server/tag), and report connection state on a dedicated status output.
From the project directory:
npm install
Then restart Node-RED, or point your Node-RED ~/.node-red install at this
package (npm install /path/to/this/repo) to pick up the three node types.
opc-pulse
Writes an OPC UA boolean tag TRUE, then back to FALSE after a configurable
delay.
msg.topic = "Config"—msg.payload = { server, tag, duration, username?, password?, securityMode?, securityPolicy? }. Saves the settings and opens (or keeps) a connection until the next Config message.msg.topic = "Pulse"— fires the pulse using the currently configured settings. On completion, sends{ endpoint, tag, pulsed: true }on output 1.
opc-input
Subscribes to an OPC UA tag and outputs a message every time its value changes.
msg.topic = "Config"—msg.payload = { server, tag, username?, password?, securityMode?, securityPolicy? }. Opens (or keeps) a subscription until the next Config message. Changing just the tag re-subscribes on the existing connection; changing the server, credentials, or security settings reconnects.- Output 1: on every tag change,
{ topic: tag, payload: value, endpoint, sourceTimestamp }. - If the connection drops, the node automatically retries the subscription every 5 seconds until it succeeds or the node is closed/redeployed.
opc-write
Writes a value to an OPC UA tag on demand.
msg.topic = "Config"—msg.payload = { server, tag, dataType?, username?, password?, securityMode?, securityPolicy? }.dataTypedefaults to"Auto": the node reads the tag'sDataTypeattribute from the server and uses that for the write, falling back to guessing from the JS type of the written value if that read fails. Set it explicitly (Boolean,String,SByte,Byte,Int16,UInt16,Int32,UInt32,Float,Double,DateTime) to override.msg.topic = "Write"— writesmsg.payload(coerced to the resolved data type) to the configured tag. On completion, sends{ endpoint, tag, value, dataType, written: true }on output 1.
Status output (output 2, all nodes)
Every state change — connecting, connected, connection lost, a failed connect/write/subscribe — is reported on output 2:
{ "topic": "status", "payload": { "state": "connected", "connected": true } }
payload.error is present (the error message) when the state reflects a
failure. If a connect attempt fails because the server doesn't offer the
requested security mode/policy at that endpoint, the error lists what the
server actually offers, e.g.:
End point must exist opc.tcp://host:4840 ... | server offers: opc.tcp://host:4840 [SignAndEncrypt/Basic256Sha256]
Security & credentials
securityMode/securityPolicydefault to"None"/"None". If the server requiresSignorSignAndEncrypt, node-opcua auto-generates a self-signed client certificate on first use (stored in a localPKIfolder) — no setup needed on your end, but the server may need to be told to trust that new certificate on its first connection attempt.- Username/password are stored as Node-RED credentials (encrypted at rest), set in the node's edit panel or overridden per Config message. Leave both unset for an anonymous connection.
UNLICENSED — internal project use.
