node-red-contrib-onvif-ng 0.9.0
Modernized ONVIF nodes for Node-RED 4.x
npm install node-red-contrib-onvif-ng
Modernized ONVIF nodes for Node-RED 4.x using the agsh/onvif library (ONVIF 4.7 compatible).
This project is a maintained continuation of
node-red-contrib-onvif-nodes by Bart Butenaers, updated for modern Node-RED runtimes and real-world camera behavior.
Legacy branch
The bart-original branch preserves the original upstream implementation by Bart Butenaers. It is retained for historical reference and is not merged into main.
✨ Key Features
  • ✅ Node-RED 4.x compatible
  • ✅ ONVIF 4.7 tested
  • ✅ Centralized profile cache (no repeated device queries)
  • ✅ Reliable media stream handling
  • ✅ Explicit capability discovery nodes
  • ✅ Clear status reporting
  • ❌ PTZ intentionally excluded (for now)
📦 Included Nodes
  • onvif-config
    Handles device connection, authentication, profile caching, and connection health.
Media
  • onvif-media-stream
    • Get Stream URI
    • Get Snapshot URI
    • Reconnect
    Uses cached profiles only — no live negotiation at runtime.
  • onvif-media-profile
    • Get profiles
    • Create / delete profiles
      (Profile tokens come from the device profile cache.)
Discovery / Capability Inspection
These nodes are discovery tools, not continuous event streams.
  • onvif-events
    Discovers supported ONVIF Events and topics via GetEventProperties.
  • onvif-recording
    Discovers recording capabilities and configuration.
ℹ️ These nodes intentionally return similar payloads for each invocation. Their purpose is capability inspection, not live subscriptions.
🚫 PTZ Status
PTZ support is not included in this release.
Reason:
  • Not used in production by the maintainers
  • High UI and device-specific complexity
  • Better handled as a future optional module
PTZ work done so far has been intentionally carved out and may return in a later release or as a community contribution.
🔐 Profile Cache Contract (Important)
  • Profiles are fetched once during device initialization
  • Cached centrally in onvif-config
  • All nodes consume profiles from the cache
  • No node performs live profile discovery during runtime
This ensures:
  • Predictable behavior
  • Faster execution
  • No UI deployment deadlocks
📡 Supported Cameras
Tested with:
  • Hanwha / Wisenet cameras
  • Other ONVIF-compliant devices (results may vary)
ONVIF implementations vary widely — this project favors robust behavior over strict spec assumptions.
📜 License
Apache License 2.0
Original work:
  • © 2018 Bart Butenaers
Modernization and maintenance:
  • © 2025–2026 Panther Computers
🤝 Contributing
Issues and PRs are welcome.
Please:
  • Target the main branch
  • Keep changes aligned with Node-RED 4.x
  • Avoid device-specific hacks unless clearly isolated
🧭 Project Status
Active maintenance
PTZ deferred
Stability prioritized
Version: 0.9.0
Updated 10 months, 2 weeks ago
8 in the last week
  • onvif-config
  • onvif-device
  • onvif-discovery
  • onvif-events
  • onvif-imaging
  • onvif-recording
  • onvif
  • camera
  • ip-camera
