node-red-contrib-ontime4ibm 0.0.5
This collection of Node-RED nodes is for Ontime Group Calendar on domino server.
npm install node-red-contrib-ontime4ibm
Version: 0.0.5
Overview
This collection of Node-RED nodes is for OnTime Group Calendar on domino server.
Description
This package is created by modifying the http request Node. This package is support to OnTime Group Calendar API on domino server. It is possible to access easy to OnTime Group Calendar by use by the node that is included in this package.
Node
OnTime uses the Token API to obtain the Token. It is necessary to request operation by using that Token. The nodes of this package stores Token in msg.ontime.parameters. If necessary, obtain or update the Token. Users do not need to manage Token.
Token
  • token
    • This node requires that the user is authenticated and is used to obtain an OnTime Group Calendar token for use in subsequent requests to the apihttp endpoint.
  • core login
    • Used to verify the token.
  • core logout
    • Tell the API that we're logging out. Not critical, more as good behavior and for logging.
  • core version
    • Return some version information of API and running server.
  • core usersall
    • List of all users and their information.
  • core usersinfo
    • Information of specific users.
  • core calendars
    • Alle calendar entries for specific users for a given time range.
Extended
  • extended
    • Set the operation and parameters in this node ahead.
    • This node automatically sets ApplID, ApplVer, APIVer, CustomID, Token.
Example: FreeRooms: Search for available rooms
Screenshot Flow
msg.payload = {
  FreeRooms: {
    StartDT: "2017-12-06T18:00:00Z",
    EndDT: "2017-12-06T19:00:00Z",
    Site: "Tokyo",
    Capacity: 4
  • Note: All dates shouldbeencodedas stringsin ISO8601 format usingthe UTC timezone. {YYYY}-{MM}-{dd}T{HH}:{mm}:{ss}Z
Run the following command in the root directory of your Node-RED install.
Licence
Apache License Version 2.0
This software includes the work that is distributed in the Apache License 2.0
Author
Takeshi Yoshida
Releace
2017/12/25 v0.0.5 Specification change
  • Attention: The output destination of the response from the OnTime API has been changed from msg.payload to msg.ontime.response.
    • If you were using version 0.0.4 or earlier, update the node config.
    • If you need to include the response in msg.payload, please check the checkbox of "Include the response in msg.payload".
  • The key name was changed from msg.OGCParameters to msg.ontime.parameters.
  • Added msg.ontime.response: This is the response from the OnTime API.
  • Added msg.ontime.request: This is the content required for the OnTime API. However, it is the state before encoding Unicode.
  • Added msg.ontime.requestEncoded: This is the content actually requested by the OnTime API after encoding Unicode.
  • Deleted msg.headers and msg.statusCode from output msg.
2017/12/02 v0.0.4 hotfix
2017/11/22 v0.0.3 hotfix
2017/11/22 v0.0.2 fix
2017/05/07 v0.0.1 Initial
Version: 0.0.5
Updated 5 months ago
Rating:
0 in the last day
2 in the last week
31 in the last month
  • token
  • core login
  • core logout
  • core version
  • core usersall
  • core usersinfo
  • core calendars
  • extened
  • tyoshida
