node-red-contrib-oled-i2c 1.1.7
Node-Red node for controlling OLED displays with SSD1306 and SH1106 drivers
npm install node-red-contrib-oled-i2c
Forked from https://www.npmjs.com/package/node-red-contrib-oled
Image text
Node-Red node to talk to OLED displays, connected by i2c.
Configure the OLED as shown:
Oled Config
Note that Raspberry Pi allows you to enable software I2C which is useful for device that requires I2C clock stretching. SH1106 might give Error: RemoteIO error in some cases. This can be solved by using software I2C.
To enable software I2C:
  • Edit /boot/config.txt
  • Add the following directive anywhere in the file:
dtoverlay=i2c-gpio,bus=3
  • The SDA is on pin GPIO 23 / BCM 16
  • The SCK in on pin GPIO 24 / BCM 18
  • The software I2C is on Bus 3
  • Perfectly compatible with Raspberry Pi 4B/3B+/3B.
  • In the examples/Example1 directory there is a flow that you can use for testing.
  • Support OLED display, which can display the running status of Raspberry Pi in real-time or anything you want.
    • SSD1306
      • all features
    • SH1106
      • Scroll feature is not available (no native support)
  • Support various font from oled-font-pack package.
Please Contact Us
If you have any problem when using our package, please contact us..
Version: 1.1.7
Updated 3 years, 9 months ago
Rating: 1.0 1
24 in the last week
  • oled-config
  • Battery
  • Bluetooth
  • Clear
  • Dimmed
  • FillRectangle
  • Invertion
  • Image
  • Line
  • Pixel
  • Scroll
  • String
  • Turn-on
  • Turn-off
  • Wifi
  • oled
  • ADS1x15
