node-red-contrib-officedocs 0.3.0
Node-RED nodes to create and manipulate Office documents: Excel (.xlsx), Word (.docx) and PowerPoint (.pptx)
npm install node-red-contrib-officedocs
npm version npm downloads Node.js ≥16 Node-RED ≥2 License: MIT
Ko-fi
Node-RED nodes to create and manipulate Office documents: Excel (.xlsx), Word (.docx) and PowerPoint (.pptx) — without Microsoft Office.
Node Library Format
exceljs ExcelJS .xlsx
docx docx .docx
pptx PptxGenJS .pptx
# from the Node-RED user directory (usually ~/.node-red)
Or via the Node-RED Manage Palette UI → search node-red-contrib-officedocs.
Requirements
  • Node.js ≥ 16
  • Node-RED ≥ 2.0
Concepts
Document travels in msg.payload
Nodes are designed to be chained: the output of one node is the input of the next.
[inject]
  → [exceljs: create]
  → [exceljs: addSheet]
  → [exceljs: addRows]
  → [exceljs: write]      ← msg.payload = Buffer / path / base64
  → [http response]
Two outputs — success and error
Every node has two output ports:
  • Port 1 — success: msg.payload contains the updated document.
  • Port 2 — error: msg.error = { message, operation, params, stack }.
Panel fields vs msg.params
Every parameter can be configured in two ways (evaluated in priority order):
  1. msg.params.fieldName — passed at runtime, highest priority.
  2. Panel field — fixed value, TypedInput (str / num / bool / msg / env / JSONata), configured in the node editor.
Style and position parameters that consist of multiple sub-fields (color, bold, size, x, y, w, h…) are decomposed into individual panel fields. You can still pass the full object at runtime via msg.params to bypass all individual fields at once:
// panel fields are ignored when the full object is passed at runtime
msg.params = {
  style:     { bold: true, color: "2E75B6", size: 32 },   // docx heading
  position:  { x: 0.5, y: 0.5, w: 9, h: 1.5 },           // pptx
  textStyle: { fontSize: 36, bold: true, color: "FFFFFF" } // pptx
Runtime operation override
msg.operation = "addRow";          // overrides the operation dropdown
msg.params = { sheet: "Sales", rowValues: ["Q1", 48500] };
Flow context (shared document between parallel branches)
msg.contextKey = "myReport";  // all branches share the same workbook
The document is stored/retrieved from flow context rather than msg.payload. Clean up after use:
flow.set("myReport", null);
Write formats
format msg.payload after write
buffer Node.js Buffer
base64 Base64 string
file Absolute path of the written file
Unit reference
Unit Used in Conversion
DXA (twips) docx page size, margins, column widths, spacing 1 inch = 1440 DXA · 1 cm ≈ 567 DXA
Half-points docx font size 24 = 12 pt · 28 = 14 pt · 32 = 16 pt
Points (pt) ExcelJS font size, pptx font size, pptx line width —
Inches pptx positions (x, y, w, h) —
Pixels docx image width/height (at 96 dpi) —
ARGB hex ExcelJS colors 8 digits, no # — first 2 = alpha (FF = opaque)
RGB hex docx and pptx colors 6 digits, no #
Common docx page sizes in DXA:
Format Width Height
US Letter (portrait) 12240 15840
A4 (portrait) 11906 16838
A4 (landscape) 16838 11906
ExcelJS Node
Creates and manipulates Excel workbooks.
Operations
create
Creates a new empty workbook.
msg.params = {
  creator:        "Node-RED",
  lastModifiedBy: "Node-RED"
read
Loads an existing .xlsx from disk or Buffer.
msg.params = {
  source: "/path/to/file.xlsx"  // string path or Buffer
addSheet
Adds a new worksheet.
msg.params = {
  sheetName: "Sales 2024",   // required — error if already exists
  tabColor:  "FF0000",       // optional — ARGB hex, no #
  sheetState: "visible"      // "visible" | "hidden" | "veryHidden"
addRow
Appends a single row.
msg.params = {
  sheet:     "Sales 2024",
  rowValues: ["Q1", "Rossi", 48500]   // array or { colName: value } object
addRows
Appends multiple rows in one call (more efficient than repeated addRow).
msg.params = {
  rowsData: [
    ["Q1", "Rossi",   48500],
    ["Q2", "Bianchi", 52000]
setCell
Sets the value and/or style of a single cell.
msg.params = {
  cell:      "B3",       // A1 notation or { row: 3, col: 2 }
  cellValue: 48500,      // prefix "=" for formulas: "=SUM(B1:B2)"
  // individual panel style fields: styleFontBold, styleFontSize, styleFontColor,
  // styleFillColor, styleNumFmt, styleAlignment
  // OR pass the full object to override all of them at once:
  style: {
    font:      { bold: true, size: 12, color: { argb: "FF0000FF" } },
    fill:      { type: "pattern", pattern: "solid", fgColor: { argb: "FFFFFF00" } },
    alignment: { horizontal: "center" },
    numFmt:    "#,##0.00"
Color format: ExcelJS uses ARGB (8 hex digits, no #). FF000000 = opaque black, FFFF0000 = opaque red, FFFFFF00 = opaque yellow.
styleRange
Applies a style to a cell range (same style fields as setCell).
msg.params = {
  range: "A1:D1",        // A1:B2 notation
  style: { font: { bold: true, size: 12 } }
addTable
Inserts a structured Excel table.
msg.params = {
  tableName:      "SalesTable",   // unique within the workbook
  tableRef:       "A1",
  tableStyle:     "TableStyleMedium9",
  showRowStripes: true,
  columns: [
    { name: "Quarter", filterButton: true },
    { name: "Agent",   filterButton: true },
    { name: "Amount",  filterButton: true, totalsRowFunction: "sum" }
  tableRows: [
conditionalFormat
Adds conditional formatting rules to a range.
msg.params = {
  range:   "C2:C100",
  cfRules: [
      type: "cellIs", operator: "greaterThan", formulae: [50000],
      style: { fill: { type: "pattern", pattern: "solid", fgColor: { argb: "FF00FF00" } } }
Common rule types: cellIs, expression, colorScale, dataBar, iconSet, top10.
mergeCell
Merges a range of cells. Merged cells display only the top-left cell's value.
msg.params = {
  range: "A1:D1"   // A1 notation range
Merging a range that already contains data preserves only the top-left value; all other cell values in the range are discarded.
setColumnWidth
Sets width and optionally hides a column.
msg.params = {
  colRef:    "B",    // column letter or 1-based number
  colWidth:  20,     // character-width units (ExcelJS default ≈ 8.38)
  colHidden: false
setRowHeight
Sets height and optionally hides a row.
msg.params = {
  rowNumber: 1,     // 1-based row number
  rowHeight: 30,    // points
  rowHidden: false
freezePanes
Freezes rows and/or columns so they stay visible when scrolling.
msg.params = {
  freezeRow: 1,   // number of rows to freeze from the top (0 = none)
  freezeCol: 0    // number of columns to freeze from the left (0 = none)
// Freeze first row only: freezeRow=1, freezeCol=0
// Freeze first column only: freezeRow=0, freezeCol=1
// Freeze both: freezeRow=1, freezeCol=1
readCell
Reads the value and metadata of a single cell. The workbook is preserved in msg._doc.
msg.params = {
  cell:  "B3"      // A1 notation
// msg.payload → { address, value, text, type, formula }
// msg._doc    → original Workbook (chain continues via msg._doc)
readRange
Reads a rectangular range into a 2-D array of { value, text, type, formula } objects.
msg.params = {
  range: "A1:D10"
// msg.payload → 2-D array [ [ { value, text, type, formula }, … ], … ]
After readCell / readRange, pass msg._doc back into msg.payload in a function node if you want to continue modifying the workbook.
protect
Protects a worksheet with an optional password.
msg.params = {
  protectTarget: "sheet",          // "sheet" | "workbook"*
  password:      "secret",         // optional — leave empty for no password
  // individual panel protection fields: protectSelectLocked, protectSelectUnlocked,
  // protectFormatCells, protectFormatColumns, protectFormatRows,
  // protectInsertRows, protectDeleteRows, protectSort, protectAutoFilter
  // OR pass the full object:
  options: {
    selectLockedCells:   true,
    selectUnlockedCells: true,
    formatCells:         false
* target: "workbook" logs a warning and falls back to protecting all sheets — ExcelJS has limited workbook-level protection support.
write
Serializes the workbook.
msg.params = {
  format:   "buffer",             // "file" | "buffer" | "base64"
  filePath: "/reports/file.xlsx"  // required only when format = "file"
// msg._doc     → original Workbook (available after write)
// msg.payload  → serialized output
Docx Node
Creates Word documents from scratch.
Note: The document is assembled as an in-memory tree throughout the chain. The actual .docx file is built only at write time. Editing existing .docx files is not supported by the underlying library.
Operations
create
msg.params = {
  title:       "Q1 Report",
  author:      "Node-RED",
  pageSize:    { width: 12240, height: 15840 },           // DXA — US Letter
  margins:     { top: 1440, right: 1440, bottom: 1440, left: 1440 },  // DXA
  defaultFont: { name: "Arial", size: 24 }                // size in half-points
addHeading
msg.params = {
  headingText:  "Quarterly Results",
  headingLevel: 1,          // 1–6
  // individual panel style fields: headingBold, headingColor, headingFontSize
  // OR pass the full object to override all:
  style: { color: "2E75B6", bold: true, size: 32 }
Color is a 6-digit RGB hex without #. Font size is in half-points.
addParagraph
// Simple text with style
msg.params = {
  paraText:      "Hello world.",
  paraAlignment: "left",  // "left" | "center" | "right" | "justified" | "both"
  // individual panel style fields: paraBold, paraItalic, paraUnderline,
  // paraColor, paraFontSize, paraFont
  style: { bold: false, italic: false, color: "333333", size: 24 }
// Mixed inline styles via runs (takes precedence over text and style fields)
msg.params = {
  paraRuns: [
    { text: "Normal " },
    { text: "bold",   bold: true },
    { text: " and " },
    { text: "italic", italic: true, color: "CC0000" }
  paraAlignment: "justified",
  paraSpacing:   { before: 120, after: 120 }  // twips
Run object shape: { text, bold, italic, underline, color, size, font, hyperlink }.
To add a clickable hyperlink inside a paragraph, include a hyperlink URL on any run:
msg.params = {
  paraRuns: [
    { text: "See the " },
    { text: "full report", hyperlink: "https://example.com/report", color: "1657F4" },
    { text: " for details." }
addList
msg.params = {
  listType:  "bullet",   // "bullet" | "number"
  listItems: [
    "First item",
    "Second item",
    { text: "Nested item", level: 1 },   // level 0–4
    "Third item"
addTable
msg.params = {
  tableRows:      [
    ["Quarter", "Agent",   "Amount"],
    ["Q1",      "Rossi",   "€48,500"],
    ["Q2",      "Bianchi", "€52,000"]
  tableHeaderRow: true,
  columnWidths:   [2500, 4000, 2500],   // DXA per column
  tableBorders:   true,
  // individual header style fields: tableHeaderBold, tableHeaderFill, tableHeaderColor
  headerStyle: { bold: true, fill: "2E75B6", color: "FFFFFF" }
addImage
Width and height are in pixels (rendered at 96 dpi).
msg.params = {
  imageSource:  "/path/to/chart.png",  // path | Buffer | base64 data URI
  imageWidth:   400,
  imageHeight:  250,
  imageAltText: "Sales chart"
Supported image formats: PNG, JPG, GIF, BMP, SVG.
addHeader
Registers a page header. Call once per header type before write.
msg.params = {
  headerText:      "Confidential — Q1 Report",
  headerType:      "default",   // "default" | "first" | "even"
  headerAlignment: "right"      // "left" | "center" | "right"
headerType When it appears
default All pages (unless overridden by first / even)
first First page only
even Even-numbered pages (requires Even & Odd Headers in Word)
addFooter
Registers a page footer. Supports static text and automatic page numbers.
// Static text footer
msg.params = {
  footerText:        "Generated by Node-RED",
  footerType:        "default",
  footerAlignment:   "center",
  footerShowPageNum: false
// Footer with automatic page numbers ("Generated by Node-RED   Page 1 of 5")
msg.params = {
  footerText:        "Generated by Node-RED   ",
  footerShowPageNum: true
When footerShowPageNum is true, Word field codes for Page X of Y are appended after the static text.
pageBreak
Inserts a page break. No params needed.
write
msg.params = {
  format:   "file",
  filePath: "/reports/report.docx"
PptxGenJS Node
Creates PowerPoint presentations.
The current slide is tracked internally (last added slide). Content operations target the current slide unless slideIndex (0-based) is specified.
Operations
create
msg.params = {
  layout:  "LAYOUT_16x9",   // "LAYOUT_16x9" | "LAYOUT_4x3" | "LAYOUT_WIDE"
                             // or custom via: { width: 12, height: 6.75 } (inches)
  author:  "Node-RED",
  company: "Acme Corp",
  theme:   { headFontFace: "Calibri", bodyFontFace: "Calibri" }
Layout Dimensions
LAYOUT_16x9 10″ × 5.625″
LAYOUT_4x3 10″ × 7.5″
LAYOUT_WIDE 13.33″ × 7.5″
addSlide
msg.params = {
  masterName: null,      // optional — registered master slide name
  bgColor:    "003366"   // optional — 6-digit hex background color
// The new slide becomes the current slide
For image backgrounds pass msg.params.bgColor = { path: "/img/bg.png" } — an object is forwarded directly to PptxGenJS.
addText
Position and style can be set as individual panel fields or passed as full objects via msg.params:
// Individual fields approach (can be set in the panel)
msg.params = {
  text:        "Slide title",
  slideIndex:  null,         // null = current slide
  posX: 0.5,  posY: 0.5,   // inches
  posW: 9,    posH: 1.5,
  textFontSize: 36,
  textBold:     true,
  textColor:    "FFFFFF",    // 6-digit hex, no #
  textAlign:    "left",      // "left" | "center" | "right" | "justify"
  textFontFace: "Calibri",
  textValign:   "middle",    // "top" | "middle" | "bottom"
  textWrap:     true
// Full-object approach (overrides all individual fields)
msg.params = {
  textStyle: { fontSize: 36, bold: true, color: "FFFFFF", align: "left", fontFace: "Calibri" }
addShape
msg.params = {
  shapeType:      "rect",   // rect | ellipse | triangle | roundRect | …
  posX: 1, posY: 1, posW: 4, posH: 2,
  shapeFillColor: "4472C4",
  shapeLineColor: "002060",
  shapeLineWidth: 1
msg.params = {
  shapeType:  "rect",
  position:   { x: 1, y: 1, w: 4, h: 2 },
  shapeStyle: { fill: { color: "4472C4" }, line: { color: "002060", width: 1 } }
addImage
msg.params = {
  imageSource: "/path/to/logo.png",   // path | HTTP(S) URL | Buffer | base64 data URI
  imageType:   "png",                 // required when source is a Buffer
  posX: 0.5, posY: 1.5, posW: 4, posH: 3,
  sizing:    { type: "contain" },
  hyperlink: { url: "https://example.com", tooltip: "Visit site" }
addChart
msg.params = {
  chartType: "bar",   // "bar" | "line" | "pie" | "area" | "scatter" | "bubble" | "donut"
  posX: 0.5, posY: 1.5, posW: 8, posH: 4.5,
  chartData: [
      labels: ["Q1", "Q2", "Q3", "Q4"],
      values: [48500, 52000, 61000, 58000]
  chartOptions: {
    showLegend: true, legendPos: "b",
    showTitle:  true, title: "Sales 2024"
Multiple series: add more objects to the chartData array.
addTable
msg.params = {
  tableRows: [
      { text: "Quarter", options: { bold: true, fill: "003366", color: "FFFFFF" } },
      { text: "Amount",  options: { bold: true, fill: "003366", color: "FFFFFF" } }
    [{ text: "Q1" }, { text: "€48,500" }]
  posX: 0.5, posY: 2, posW: 8,
  tableOptions: { colW: [3, 3], fontSize: 14 }
addNotes
Adds plain-text speaker notes to a slide. Notes appear in PowerPoint Presenter View but are not rendered on the slide itself.
msg.params = {
  notes:      "Remind the audience about the Q3 dip — supply chain disruption.",
  slideIndex: null   // null = current slide; 0-based index to target a specific slide
defineMaster
Defines a named slide master (background color or image, fixed objects on every slide). Must be called before any addSlide that references the master by name.
msg.params = {
  masterTitle:   "CORP_MASTER",   // unique name — referenced in addSlide.masterName
  masterBkg:     "1F3864",        // 6-digit hex solid background
  // OR an image background via msg.params at runtime:
  // masterBkg: { path: "/assets/bg.png" }
  masterObjects: [
      type: "text",
      text: "CONFIDENTIAL",
      options: { x: 0.1, y: 5.3, w: 2, h: 0.3, fontSize: 10, color: "AAAAAA" }
After defining the master, reference it in addSlide:
msg.params = { masterName: "CORP_MASTER" };
setLayout
msg.params = { layout: "LAYOUT_4x3" };
write
msg.params = {
  format:   "base64",              // "file" | "buffer" | "base64"
  filePath: "/reports/deck.pptx"   // required only when format = "file"
msg contract
Input
Property Type Required Description
msg.payload Workbook / doc object / null Yes (except create) Document to operate on.
msg.operation string No Runtime override of the panel operation.
msg.params object Depends Operation parameters — override individual panel fields. Full style/position objects bypass individual fields entirely.
msg.contextKey string No Flow-context key for shared documents across parallel branches.
Output — port 1 (success)
Property Type Description
msg.payload document / Buffer / string Updated document, or serialized output after write.
msg._doc document Original document before write — useful for post-save processing.
Output — port 2 (error)
msg.error object { message, operation, params, stack }
msg.payload any Original payload preserved for debugging.
Flow examples
Excel — HTTP endpoint returning a .xlsx
[http in: GET /report]
  → [exceljs: create]
  → [function: set params]
  → [exceljs: write]         format: buffer
  → [function: set headers]  Content-Type: application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
  → [http response]
Word — generate from JSON body
[http in: POST /generate-doc]
  → [docx: create]
  → [docx: addHeading]    headingText = msg.payload.title
  → [docx: addParagraph]  paraText = msg.payload.body
  → [docx: addTable]      msg.params.tableRows = msg.payload.tableData
  → [docx: write]         format: base64
  → [http response]
PowerPoint — live KPI presentation
[inject / http in]
  → [http request: fetch KPIs]
  → [pptx: create]     layout: LAYOUT_16x9
  → [pptx: addSlide]   bgColor: 003366
  → [pptx: addText]    title with data
  → [pptx: addSlide]
  → [pptx: addChart]   time series data
  → [pptx: write]      format: file, filePath: /reports/kpi.pptx
  → [email: send attachment]
Import ready-to-use example flows from the examples/ folder in this package.
Compatibility
Component Version
Node.js ≥ 16.x
Node-RED ≥ 2.x
ExcelJS ^4.4.0
docx ^8.5.0
PptxGenJS ^3.12.0
Generated file compatibility
Node Compatible with
exceljs Excel 2010+, LibreOffice Calc 6+, Google Sheets
docx Word 2013+, LibreOffice Writer 6+, Google Docs
pptx PowerPoint 2016+, LibreOffice Impress 6+, Google Slides
Known limitations
Node Limitation
docx Reading / editing existing .docx files is not supported — the docx library is write-only.
pptx Reading existing .pptx files is not supported — PptxGenJS is write-only.
exceljs protect: workbook has limited support in ExcelJS; the node warns and falls back to protecting all sheets individually.
exceljs Auto-fit column widths is not natively supported by ExcelJS — column widths must be set explicitly.
pptx Animated slide transitions are not supported by PptxGenJS.
Known issues
  • pptx / addSlide background image: the bgColor panel field only accepts a hex color string. To use an image background, pass the full object at runtime: msg.params.bgColor = { path: "/img/bg.png" }.
  • exceljs / setCell dates: pass Date objects via msg.params.cellValue — the panel's TypedInput field returns a string, which ExcelJS stores as text rather than a date.
Roadmap
The following features are candidates for future releases, roughly ordered by implementation effort.
Completed ✅
  • ExcelJS: mergeCell — merge a range of cells
  • ExcelJS: setColumnWidth / setRowHeight — column/row sizing and visibility
  • ExcelJS: freezePanes — freeze rows and columns
  • ExcelJS: readCell / readRange — extract cell values from a loaded workbook
  • ExcelJS: setActiveSheet — set a default sheet, avoids repeating sheet on every node
  • ExcelJS: getInfo — workbook metadata (sheet names, row counts, used ranges)
  • PptxGenJS: addNotes — speaker notes per slide
  • PptxGenJS: defineMaster — named slide master with background and objects
  • PptxGenJS: getSlideCount — slide count without modifying the presentation
  • Docx: addHeader / addFooter — page headers and footers with optional page numbers
  • Docx: hyperlinks inside paragraph runs (ExternalHyperlink)
  • All nodes: node.status() visual indicator and msg.info contextual metadata on every output
Low effort
  • ExcelJS: deleteSheet / renameSheet — remove or rename a worksheet; useful when working from .xlsx templates
  • ExcelJS: autoFilter — add dropdown filter buttons to a range
  • ExcelJS: addImage — embed an image into a worksheet (logos, charts exported as PNG)
  • PptxGenJS: deleteSlide / reorderSlide — remove or move slides; needed for template-based generation
  • Docx: addSection — section break with independent properties (e.g. a landscape page inside a portrait document)
Medium effort
  • All nodes: batch mode — accept an array of operations in msg.payload and execute them in sequence inside a single node, reducing flow complexity for straightforward pipelines:
    msg.payload = [
      { op: 'addSheet', sheetName: 'Sales' },
      { op: 'addRows',  rowsData: [...] },
      { op: 'write',    format: 'buffer' }
  • ExcelJS: template mode — open an existing .xlsx as base and only fill in data, preserving branding (borders, logos, styles)
  • Docx: addTOC — automatic table of contents built from heading levels
Higher effort / library limitations
  • ExcelJS: chart support (complex API, many chart types)
  • Docx: table of contents with page numbers (requires Word field codes)
  • All nodes: automated test suite (Jest/Mocha) covering the full create → add → write chain — prerequisite for 1.0.0
  • All nodes: GitHub Actions CI running tests on Node.js 18 / 20 / 22
MIT © Davide Travaglini
Version: 0.3.0
Updated 6 months, 2 weeks ago
28 in the last week
  • exceljs
  • docx
  • pptx
  • excel
  • xlsx
  • docx
  • pptx
  • word
  • powerpoint
  • office
  • exceljs
  • document
  • report
  • spreadsheet
  • presentation
