node-red-contrib-odbc-with-pooling 2.0.0-beta.0
Node-RED node for making ODBC connections
npm install node-red-contrib-odbc-with-pooling
A Node-RED node for making queries and calling procedures through an ODBC connection. Uses the odbc package as the database connector.
There are two ways to download this package:
  1. From the Node-RED ediot menu, select Manage pallete, then click the Install tab and search for this package.
  2. In your Node-RED user directory (usually ~/.node-red/), download through the npm utility:
For the odbc connector requirements, please see the documentation for that package.
node-red-contrib-odbc provides three nodes:
  • ODBC pool: A configuration node for defining your connection string and managing your connections
  • ODBC query: A node for running queries with or without parameters
  • ODBC procedure: A node for calling procedures and functions
ODBC pool
A configuration node that manages connections in an odbc.Pool object. Can take any configuration property recognized by odbc.pool(). The connection pool will initialize the first time a ODBC query node or ODBC pool node runs.
Properties
  • (required) connectionString: <string>
    An ODBC connection string that defines your DSN and/or connection string options
    Example:
    DSN=MyDSN;DFT=2;
  • (optional) initialSize: <number>
    The number of connections created in the Pool when it is initialized
  • (optional) incrementSize: <number>
    The number of connections that are created when the pool is exhausted
  • (optional) maxSize: <number>
    The maximum number of connections allowed in the pool before it won't create any more
  • (optional) shrinkPool: <boolean>
    Whether the number of connections should be reduced to initialSize when they are returned to the pool
  • (optional) connectionTimeout: <number>
    The number of seconds for a connection to remain idle before closing
  • (optional) loginTimeout: <number>
    The number of seconds for an attempt to create a connection before returning to the application
ODBC query
A node that runs a query when input is received. This node can define its own query string and/or parameters, as well as take a query and/or parameters as input. Input values will override any node properties.
Properties
  • (required) connection: <ODBC pool>
    The ODBC pool node that defines the connection settings and manages the connection pool used by this node
  • (optional) query: <string>
    A query string that can optionally contain parameter markers
  • (optional) parameters: <array<any>>
    The parameters to bind to the query string, passed as a JavaScript array. If this property is set with the Node-RED editor, it is a valid JSON string that will be converted to JavaScript.
Inputs
The ODBC query node accepts a payload input that is either a valid JSON string or a JavaScript object with "query" and/or "parameters" properties. These values, when passed on the payload, override node properties.
  • (optional) payload.query <string>:
  • (optional) payload.parameters: <array<any>>
    The parameters to bind to the query string. This is either an array in a JSON string, or a JavaScript array.
Outputs
Sends a message with a payload that is the results from the query
ODBC procedure
A node that calls a procedure when input is received. This node can define its own set of catalog, schema, procedure, and parameters to pass to the procedure, as well as take these values as input. Input values will override any node properties.
Properties
  • (optional) catalog: <string>
    The catalog that contains the procedure
  • (optional) schema: <string>
    The schema that contains the procedure
  • (optional) procedure: <string>
    The name of the procedure
    The parameters to send and/or return from the procedure, passed as a JavaScript array. If this property is set with the Node-RED editor, it is a valid JSON string that will be converted to JavaScript.
Inputs
The ODBC procedure node accepts a payload input that is either a valid JSON string or a JavaScript object with "catalog", "schema", "procedure" and/or "parameters" properties. These values, when passed on the payload, override node properties.
  • (optional) payload.catalog <string>:
  • (optional) payload.schema <string>:
  • (optional) payload.procedure <string>:
Examples:
  • JSON string:
    "{"catalog": null, "schema": "MY_SCHEMA", "procedure": "MYPROC", "parameters": [null, 123, "value"]}"
  • JavaScript object:
    { catalog: null, schema: "MY_SCHEMA", procedure: "MYPROC", parameters: [null, 123, "value] }
Outputs
Sends a message with a payload that is the results of the procedure call
Version: 2.0.0-beta.0
Updated 1 year, 1 month ago
License: Apache 2
66 in the last week
  • ODBC pool
  • ODBC query
  • ODBC procedure
  • odbc
