node-red-contrib-octocore 0.0.22
OctoCore implementation for node-red
npm install node-red-contrib-octocore
NPM version Node-RED License: MIT Node.js Website
A Node-RED module to communicate with the OctoCore platform from Octotronic.
Overview
This Node-RED module provides nodes to publish and subscribe to messages on the OctoCore platform using NATS. It includes the following nodes:
Core Nodes:
  • uns-publish: Publish messages to the OctoCore platform with advanced features (buffering, batching, rate limiting, request/reply mode).
  • uns-subscribe: Subscribe to messages from the OctoCore platform with automatic JSON parsing.
  • uns-server: Configure the NATS server connection with enhanced security (TLS, JWT, NKey authentication).
Note: The uns-request node has been integrated into uns-publish as "Request/Reply Mode". Enable it in the node configuration to send requests and receive responses.
To install the module, run the following command in your Node-RED user directory (typically ~/.node-red):
Development Setup
For development, clone the repository and install dependencies:
git clone https://git.octotronic.com/manufacturinghub/node-red-contrib-octocore.git
cd node-red-contrib-octocore
npm install
Available Scripts
  • npm test - Run tests with Jest
  • npm run lint - Run ESLint for code quality checks
  • npm run lint:fix - Fix ESLint issues automatically
  • npm run format - Format code with Prettier
Makefile Commands
For convenience, you can also use the provided Makefile:
make help          # Show all available commands
make dev-setup     # Setup development environment
make dev-cycle     # Run development cycle (format, lint, test)
make docker-up     # Start Node-RED with Docker
make docker-logs   # Show Docker logs
See docs/makefile-usage.md for complete documentation.
NATS Server Configuration
uns-server
This node is used to configure the connection to the NATS server with comprehensive security features.
🔐 Enhanced Security & Authentication:
  • Authentication Methods (Dropdown Selection):
    • No Authentication: For local development or unsecured servers
    • Username/Password: Traditional authentication (default, backward compatible)
    • Token Authentication: Single authentication token for NATS server
    • JWT Authentication: NATS 2.x JSON Web Token with NKey seed
    • NKey Authentication: Cryptographic authentication using NKey seed
  • TLS/SSL Encryption Support:
    • Enable/disable TLS encryption with checkbox
    • CA Certificate: Server verification with custom CA certificate file
    • Client Certificate: Mutual TLS (mTLS) with client certificate
    • Client Key: Client private key for mTLS authentication
    • Verify Server Certificate: Optional certificate verification (enabled by default)
  • Security Features:
    • All credentials stored encrypted in Node-RED's secure credentials system
    • Automatic security warnings for production connections without TLS
    • JWT validation ensures both JWT token and NKey seed are provided
    • File-based certificate loading with path validation
    • Debug logging shows auth method and TLS status (with masked credentials)
Connection Settings:
  • Server: The URL of the NATS server.
  • Max Reconnect Attempts: Maximum number of reconnection attempts (default: 10).
  • Reconnect Wait Time: Time to wait between reconnection attempts in milliseconds (default: 1000).
  • Connection Timeout: Connection timeout in milliseconds (default: 10000).
  • Ping Interval: Interval between ping messages in milliseconds (default: 30000).
  • Max Ping Outs: Maximum number of ping timeouts before disconnect (default: 3).
Connection Status:
  • Connected: Shows connection status
  • Disconnected: Shows reconnect attempts
  • Connecting: Shows current attempt
  • Failed: Shows when connection fails
Environment Variable Configuration:
All server settings can be configured via environment variables (useful for Docker/Kubernetes deployments):
Variable Description Default
NATS_URL Server URL. Use tls:// for SSL nats://localhost:4222
NATS_USERNAME Username for authentication -
NATS_PASSWORD Password for authentication -
NATS_AUTH_METHOD Auth method: none, userpass, token, jwt, nkey userpass
TLS_ALLOW_INSECURE Allow self-signed certificates false
TLS_CA_FILE Path to custom Root CA certificate -
Datapoint Environment Variables:
The datapoint/subject field in uns-publish and uns-subscribe nodes also supports environment variables:
# Docker Compose example
environment:
  - MY_DATAPOINT_ID=sensor-temperature-001
In the Node-RED editor, select "env" from the TypedInput dropdown and enter the variable name (e.g., MY_DATAPOINT_ID).
TLS via URL Scheme:
# Without TLS:
NATS_URL=nats://server:4222
# With TLS (auto-detected):
NATS_URL=tls://server:4222
TLS_ALLOW_INSECURE=true  # for self-signed certs
Security Best Practices:
  • Always use TLS/SSL for production environments
  • Use JWT or NKey authentication for enhanced security
  • Keep "Verify Server Certificate" enabled in production
  • All credentials are encrypted and never visible in flow exports
Publish Node
uns-publish
This node is used to publish messages to the OctoCore platform with advanced features.
Core Features:
  • Name: The name of the node.
  • Server: The NATS server configuration to use.
  • Dataformat: The format of the data to publish (UNS Value, UNS Event, UNS Reply, Specific Topic).
  • Datapoint / Subject: The datapoint or subject to publish to. Supports environment variables via TypedInput selector.
  • Debug: Optional debug logging (enable via checkbox)
🔧 Advanced Features:
  • Message Buffering: Queue messages when connection is lost
    • Buffer Limit Types: Message count (max: 10,000) or buffer size in bytes (max: 100 MB)
    • Buffer Modes: Drop oldest (FIFO), drop newest, or reject on full
    • Buffer Persistence: None (RAM), Context Storage, File System, or Both
    • Auto-Save: Automatic periodic saving (5-300 seconds, default: 30s)
    • Timestamp Preservation: Original timestamps preserved when buffered messages are flushed
    • Parallel Transmission: All buffered messages sent simultaneously when connection is restored (~10x faster)
  • Manual UNS Datatype Override: Force specific datatype (Integer, Float, Boolean, String, Object) with strict validation
  • Batch Publishing: Group multiple messages for efficient transmission
    • Batch Size: Number of messages per batch (default: 100, range: 1-1000)
    • Batch Interval: Time window in milliseconds (default: 1000ms, range: 100-60000ms)
    • Batch Modes:
      • Size Only: Publish only when batch is full (recommended for high-throughput scenarios)
      • Hybrid: Publish when batch is full OR interval expires (whichever comes first)
      • Time Only: Publish at regular intervals regardless of batch size
    • Status Display: Shows current queue state batching (X/Y) where X = queued messages, Y = batch size
    • Timestamp Preservation: Original message creation timestamps are preserved when batching
    • Parallel Transmission: All batch messages sent simultaneously (~10x faster than sequential)
  • Request/Reply Mode: Send requests and wait for responses (replaces the old uns-request node)
    • Enable via "Request/Reply Mode" checkbox
    • Configurable timeout (100-60,000 ms, default: 1,000 ms)
    • Option to handle timeout as message instead of error
    • Output port appears only when enabled
    • Node label changes to "uns-request" when enabled
  • Rate Limiting: Token bucket algorithm to prevent message flooding (configurable rate, burst, actions: drop, delay)
  • Connection Pooling: Shared connections for resource efficiency
Output Properties (only available when Request/Reply Mode is enabled):
  • msg.payload: The message payload
  • msg.topic: The NATS subject used
  • msg._buffered: Indicates if message was buffered during disconnect
  • msg._batched: Indicates if message was part of a batch
  • msg._rateLimited: Indicates if message was rate limited
  • msg._originalTimestamp: Original timestamp when message was buffered (preserved during flush)
The payload of the message to publish can be set via the msg.payload property.
Subscribe Node
uns-subscribe
This node is used to subscribe to messages from the OctoCore platform with automatic parsing and connection pooling.
Core Features:
  • Dataformat: The format of the data to subscribe to (UNS Value, UNS Command, UNS Event, Specific Subject).
  • Datapoint / Subject: The datapoint or subject to subscribe to. Supports environment variables via TypedInput selector.
  • Topic Field: Select what value to use for msg.topic (NATS Subject, Datapoint ID, Datapoint Name, Data Type).
  • Automatic JSON Parsing: For Specific Subject format, automatically attempts JSON parsing with fallback to string
  • Format Detection: Adds _format property ('json' or 'string') for downstream processing
Output Properties:
  • msg.payload: Only the value of the datapoint (for UNS Value format)
  • msg.topic: The topic field value based on configuration
  • msg.datatype: Data type of the UNS value (only for UNS Value format)
  • msg.id: Datapoint ID (only for UNS Value format)
  • msg.name: Datapoint name (only for UNS Value format)
  • msg.timestamp: Timestamp of the message (only for UNS Value format)
  • msg._format: Format indicator ('json' or 'string') for Specific Subject
UNS Event Properties:
  • msg.id: Event ID (only for UNS Event format)
  • msg.type: Event type (only for UNS Event format)
  • msg.startTime: Event start time (only for UNS Event format)
  • msg.endTime: Event end time (only for UNS Event format)
Data Type Handling:
  • datatype 1 (Integer): String converted to Integer
  • datatype 2 (Float): String converted to Float
  • datatype 3 (Boolean): String converted to Boolean
  • datatype 4 (String): Remains as String
  • datatype 5 (Unix Timestamp): Unix timestamp in milliseconds
  • datatype 6 (Object): String parsed to JSON object
Request/Reply Mode (in uns-publish)
The request/reply functionality is now integrated into the uns-publish node. Enable "Request/Reply Mode" in the Advanced Features section.
Configuration:
  • Enable Request/Reply Mode: Checkbox to enable request mode
  • Timeout: Timeout in milliseconds for the request (default: 1,000 ms)
  • Timeout as Message: Send timeout as message instead of error
Behavior:
  • When enabled, the node gets an output port labeled "response"
  • The node label changes from "uns-publish" to "uns-request"
  • Messages are sent as NATS requests instead of publishes
  • Responses are forwarded to the output port
Output Properties:
  • msg.payload: The response data (or error object if timeout)
  • msg._timeout: Set to true if request timed out (when timeout-as-message is enabled)
Node Status Indicators:
  • 🟢 Green "connected": Ready for requests
  • 🟡 Yellow "requesting...": Request in progress
  • 🟠 Orange "timeout": Request timed out
  • 🔴 Red "disconnected": Server connection problem
Security
🔐 Enhanced Security Features
The OctoCore module includes comprehensive security features for production environments:
Authentication Methods:
  • Username/Password: Traditional authentication (backward compatible)
TLS/SSL Encryption:
  • CA certificate verification
  • Mutual TLS (mTLS) with client certificates
  • Certificate verification options
  • Debug logging with masked credentials
For detailed security documentation, see SECURITY.md.
Examples
Comprehensive Example Flow
A complete example flow is included in the examples/ directory. The flow demonstrates all OctoCore nodes with real-world use cases.
To use the example flow:
  1. Import examples/flows.json into Node-RED
  2. Or view it in the repository: examples/flows.json
See examples/README.md for detailed documentation.
Testing
Run the test suite:
npm test
For coverage reports:
npm test -- --coverage
Links
Basic Example Flow
Here is a basic example flow that demonstrates how to use the uns-publish and uns-subscribe nodes:
        "id": "publish-node",
        "type": "uns-publish",
        "z": "0b30cc47ed4855ca",
        "name": "Publish to OctoCore",
        "server": "uns-server-config",
        "dataformat": "uns_value",
        "datapointid": "example.datapoint",
        "x": 1900,
        "y": 1100,
        "id": "subscribe-node",
        "type": "uns-subscribe",
        "name": "Subscribe from OctoCore",
        "x": 1890,
        "y": 1140,
                "debug-node"
        "id": "request-node",
        "name": "Request from OctoCore",
        "dataformat": "specific_topic",
        "datapointid": "example.subject",
        "enableRequest": true,
        "requestTimeout": 1000,
        "handleRequestTimeout": true,
        "x": 1890,
        "y": 1200,
                "debug-node"
        "id": "debug-node",
        "type": "debug",
        "name": "Debug",
        "active": true,
        "console": "false",
        "complete": "false",
        "x": 2210,
        "y": 1160,
        "id": "fc641d9a3139e434",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "testtring",
        "payloadType": "str",
        "x": 1650,
        "y": 1100,
                "publish-node"
        "id": "6da3165904b618b3",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "10",
        "payloadType": "num",
        "x": 1650,
        "y": 1200,
                "request-node"
        "id": "uns-server-config",
        "type": "uns-server",
        "server": "nats://localhost:4222",
        "user": "username",
        "pass": "password"
        "id": "4a72a6bb1c07bac1",
        "type": "global-config",
        "env": [],
        "modules": {
            "node-red-contrib-octocore": "0.0.18"
Version: 0.0.22
Updated 2 months, 3 weeks ago
Rating: 5.0 6
12 in the last week
  • uns-publish
  • uns-subscribe
  • uns-server
  • octocore
  • uns
  • unified-namespace
  • nats
  • iot
  • manufacturing
