node-red-contrib-nut 1.0.0
Node-RED nodes for Network UPS Tools (NUT) UPS monitoring
npm install node-red-contrib-nut
Node-RED nodes to integrate Network UPS Tools (NUT) UPS status and events into your flows.
✨ Features
  • Connects to any NUT server (TCP, default port 3493)
  • Username/password authentication and optional TLS
  • Separate config node for the NUT server
  • UPS node with two modes:
    • Polling: query UPS status in a fixed interval
    • Events (monitor): subscribe to NUT events/variable changes
  • Optional fetch on deploy and auto-refresh
  • Option to send messages only if payload changed
  • Normalised status flags: onBattery, lowBattery, online
  • Full NUT variable map (e.g. battery.charge, ups.load, …)
  • Fully i18n-enabled (English / German, including help text and status messages)
From your Node-RED user directory (typically ~/.node-red):
Or via the Node-RED Palette Manager:
  1. Open the Node-RED editor
  2. Menu → Manage palette
  3. Tab Install
  4. Search for node-red-contrib-nut
  5. Click Install
nut-server (config node)
Represents a single NUT server instance.
Multiple nut-ups nodes can share the same server configuration.
nut-ups
Queries or monitors a specific UPS connected to the configured NUT server and outputs structured status messages.
Common options
Name
Optional display name for the node.
If left empty, a default label is used.
nut-server options
Host
Hostname or IP address of the NUT server (e.g. 10.24.0.100).
Port
TCP port of the NUT server.
Default: 3493.
Username / Password
NUT user credentials, e.g. a dedicated user like nodered that has at least read permissions for the configured UPS.
Note: Credentials are stored by Node-RED’s credential mechanism and are not exported with flows.
Use TLS
If enabled, the node connects using TLS instead of plain TCP.
Make sure your NUT server is configured accordingly.
nut-ups options
NUT Server
Reference to a nut-server config node.
UPS Name
The UPS name as configured on the NUT server, e.g. apc-1.
You can list available UPS devices on the server with:
upsc -l <host>
Mode
  • Polling – actively queries the UPS in a fixed interval.
  • Events (monitor) – subscribes to events and variable changes from the NUT server.
Auto-refresh (sec)
Additional auto-refresh interval in seconds.
  • 0 → disabled
  • > 0 → in polling mode, this is the interval between two queries
    (in monitor mode it can be used as a safety refresh).
Fetch on deploy
If enabled, the node performs an initial fetch shortly after the flow is deployed.
Only send on change
If enabled, the node only emits a message when the payload differs from the last emitted payload.
Inputs
Any incoming message to the nut-ups node acts as a trigger:
  • In Polling mode, the node immediately queries the UPS status.
  • In Events mode, the node performs a refresh but will also emit messages on NUT events.
The content of the incoming message is not evaluated in this version.
Outputs
The node outputs a message with a structured payload.
A typical message looks like:
  "topic": "nut/apc-1/status",
  "payload": {
    "ups": "apc-1",
    "status": "OL",
    "onBattery": false,
    "lowBattery": false,
    "online": true,
    "variables": {
      "battery.charge": "100",
      "battery.charge.low": "10",
      "battery.runtime": "1068",
      "battery.type": "PbAc",
      "input.voltage": "234.0",
      "ups.load": "25",
      "ups.model": "Back-UPS BX950MI ",
      "ups.status": "OL",
    "event": null,
    "timestamp": "2025-12-01T17:34:30.887Z"
  • topic – by default set to nut/<ups-name>/status
  • payload.ups – UPS name
  • payload.status – raw NUT status string, e.g. OL, OB, LB
  • payload.onBattery – boolean flag
  • payload.lowBattery – boolean flag
  • payload.online – boolean flag
  • payload.variables – all NUT variables for this UPS as key/value pairs
  • payload.event – event name in monitor mode (if available), otherwise null
  • payload.timestamp – ISO-8601 timestamp when the data was fetched
Example flow
A basic example flow is included in:
examples/nut-basic.json
It demonstrates:
  • configuring a nut-server pointing to your NUT instance
  • a nut-ups node in polling mode
  • a manual Inject trigger
  • basic post-processing using Switch and Debug nodes for
    • “On battery?”
    • “Low battery?” messages
Import steps:
  1. In Node-RED, open the menu → Import
  2. Choose Clipboard
  3. Paste the contents of examples/nut-basic.json
  4. Click Import
Internationalisation (i18n)
All editor labels, tooltips, help content and runtime status messages are localised via the Node-RED i18n mechanism.
Translator files:
  • English:
    • nodes/locales/en-US/nut-server.json
    • nodes/locales/en-US/nut-server.html
    • nodes/locales/en-US/nut-ups.json
    • nodes/locales/en-US/nut-ups.html
  • German:
    • nodes/locales/de/nut-server.json
    • nodes/locales/de/nut-server.html
    • nodes/locales/de/nut-ups.json
    • nodes/locales/de/nut-ups.html
The Node-RED editor language (or browser language, depending on configuration) controls which texts are displayed.
⚖️ License
MIT © 2025 Gerd Rütten
Changelog
See CHANGELOG.md for a detailed list of changes.
Version: 1.0.0
Updated 1 year ago
  • nut-server
  • nut-ups
  • nut
  • ups
  • apc
  • network-ups-tools
