node-red-contrib-nunjucks-templating 1.0.10
Nunjucks is a full featured templating engine for javascript. It is heavily inspired by jinja2.
npm install node-red-contrib-nunjucks-templating
A rich and powerful templating language for JavaScript right in Node-RED. For all of the Nunjucks template features checkout the official Nunjucks documentation
Macro usage
Options
You can define any valid Nunjucks options in the Node-RED settings.js file. nunjucks.options
Loading templates
Templates can be defined with the Nunjucks template nodes or be loaded from the file system using preconfigured folders for lookup. Loading is done automatically in the following order:
  1. Defined templates as nodes within the project that matches the name
  2. Looking for files in one of the configures folders
nunjucks: {
    folders: ["./my-templates", "./templates"],
This means you don't have to worry about where the template is defined while including it in your templates.
Template inheritance
extends is used to specify template inheritance. The specified template is used as a base template. See Template Inheritance. Macro usage
Custom filters
You can register filters using the global function nj.addFilter
// Value will be whatever is piped to the filter
function myFilter(value) {
    return `Foo: ${value}!!`
global.get('nj.addFilter')('myFilter', myFilter)
Now you can use it in all of your templates like: {{ 'bar' | foo }}
Output: Foo: bar!!
Passing functions
Functions can be passed like any other variables as context.
// context
msg.payload = {
    foo: 'bar',
    reverse: value => value.split('').reverse().join('')
{# template #}
{{ reverse(foo) }}
Output: rab
Global context
You can add global variables in multiple ways:
  1. Add a section to settings.js like this:
nunjucks: {
    global: {
        foo: 'bar',
        app: {
            name: 'My Awesome App'
Now you can access it anywhere like so: {{ app.name }} and {{ foo }}.
  1. Add it within a function node: global.get('nj.addGlobal')('myVar', 'Some value') Access it anywhere in any template or macro: {{ myVar }}
Snippets
Nunjucks snippets are provided for the Monaco editor only. Press ctrl+spacebar to list the available snippets.
  • asyncAll
  • asyncEach
  • block
  • call
  • elif
  • else
  • end
  • extends
  • filter
  • for
  • from
  • if
  • ife
  • ifel
  • import
  • include
  • macro
  • njk
  • or
  • pipe
  • raw
  • set
  • super
  • var
  • v{}
Macros
"macro allows you to define reusable chunks of content. It is similar to a function in a programming language."
Simple place your macros in a Nunjucks template node or in a file. The macros can be imported simply by there node name or filename. You can have one or more macros in one or more Nunjuck template nodes or files.
Defining macros
Macro definitions
Using macros
Macro usage
Other global functions
  • global.get("nj.addFilter");
  • global.get("nj.getFilter");
  • global.get("nj.addExtension");
  • global.get("nj.getExtension");
  • global.get("nj.hasExtension");
  • global.get("nj.removeExtension");
  • global.get("nj.getTemplate");
  • global.get("nj.addGlobal");
  • global.get("nj.getGlobal");
  • global.get("nj.renderString");
Examples
[{"id":"79b0f31660687179","type":"http response","z":"e78f061152fe82f8","name":"","statusCode":"","headers":{},"x":890,"y":120,"wires":[]},{"id":"f39790b7c1b32cbb","type":"nunjucks_render","z":"e78f061152fe82f8","template":"{% extends \"base.html\" %}\n\n{% import \"cards.html\" as cards %}\n\n{% block body %}\n{% call cards.card(card) %}\n  <form>\n    <div class=\"row\">\n      <div class=\"col\">\n        <input type=\"text\" class=\"form-control\" id=\"firstname\" name=\"firstName\" placeholder=\"Firstname\" value=\"{{ request.query.firstName }}\">\n      </div>\n      <div class=\"col\">\n        <input type=\"text\" class=\"form-control\" id=\"firstname\" name=\"lastName\" placeholder=\"Lastname\" value=\"{{ request.query.lastName }}\">\n      </div>\n    </div>\n\n    {# How to call your custom filters #}\n    <div class=\"my-4\">\n    {{ 'Hello' | myFilter }}\n    </div> \n\n    \n    <button type=\"submit\" class=\"btn btn-dark mt-3\">Give me a joke!</button>\n  </form>\n{% endcall %}\n{% endblock %}","x":760,"y":120,"wires":[["79b0f31660687179"]]},{"id":"45ba6e37f1581888","type":"function","z":"e78f061152fe82f8","name":"","func":"msg.payload = {\n    card: {\n        title: 'A Random Joke',\n        text: msg.payload.value.joke,\n        image: {\n            src: 'https://cdn.dribbble.com/users/1774513/screenshots/3726127/media/ef86424ae75426acfa624dfadcabda14.jpg?compress=1&resize=400x300'\n        },\n        buttons: [{\n            label: 'Another Joke',\n            href: '#',\n            className: 'btn btn-dark'\n        }]\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":120,"wires":[["f39790b7c1b32cbb"]]},{"id":"fe5e86af251c9c02","type":"http request","z":"e78f061152fe82f8","name":"","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":470,"y":120,"wires":[["45ba6e37f1581888"]]},{"id":"f9cf633ec1b34528","type":"function","z":"e78f061152fe82f8","name":"payload","func":"global.get('nj.addGlobal')('request', msg.req)\n\nconst firstName = msg.req.query.firstName || 'Chuck'\nconst lastName = msg.req.query.lastName || 'Norris'\n\nmsg.method = 'GET'\nmsg.url = `http://api.icndb.com/jokes/random?firstName=${firstName}&lastName=${lastName}`\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":120,"wires":[["fe5e86af251c9c02"]]},{"id":"1fdca429c8c60b6f","type":"http in","z":"e78f061152fe82f8","name":"","url":"/example/joke","method":"get","upload":false,"swaggerDoc":"","x":150,"y":120,"wires":[["f9cf633ec1b34528"]]},{"id":"7c41b5ed52f53c40","type":"nunjucks","z":"e78f061152fe82f8","name":"cards.html","template":"{% macro card(card) %}\n<div class=\"card\">\n  {% if card.image %}\n    <img src=\"{{ card.image.src  }}\" class=\"card-img-top\" alt=\"{{ card.image.alt  }}\">\n  {% endif %}\n\n  <div class=\"card-body\">\n  {% if card.title %}\n    <h5 class=\"card-title\">{{ card.title }}</h5>\n  {% endif %}\n\n  {% if card.text %}\n    <p class=\"card-text\">{{ card.text }}</p>\n  {% endif %}\n\n  {{  caller() }}\n  </div>\n</div>\n{% endmacro %}","x":120,"y":320,"wires":[]},{"id":"3d4160d4d2e68eef","type":"nunjucks","z":"e78f061152fe82f8","name":"base.html","template":"<!doctype html>\n<html lang=\"en\">\n  <head>\n    <!-- Required meta tags -->\n    <meta charset=\"utf-8\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n\n    <!-- Bootstrap CSS -->\n    <link href=\"https://cdn.jsdelivr.net/npm/[email protected]/dist/css/bootstrap.min.css\" rel=\"stylesheet\" integrity=\"sha384-1BmE4kWBq78iYhFldvKuhfTAU6auU8tT94WrHftjDbrCEXSU1oBoqyl2QvZ6jIW3\" crossorigin=\"anonymous\">\n    \n    <title>{% block title %}Nunjucks Rocks!{% endblock %}</title>\n  </head>\n  <body>\n    {% include \"navbar.html\" %}\n    <div class=\"container\" style=\"margin-top: 80px;\">\n      {% block body %}\n        <h1>Hello, world!</h1>\n      {% endblock %}\n    </div>\n    <!-- Optional JavaScript; choose one of the two! -->\n\n    <script src=\"https://cdn.jsdelivr.net/npm/[email protected]/dist/js/bootstrap.bundle.min.js\" integrity=\"sha384-ka7Sk0Gln4gmtz2MlQnikT1wXgYsOg+OMhuP+IlRH9sENBO0LRn5q+8nbTov4+1p\" crossorigin=\"anonymous\"></script>\n    <script src=\"https://unpkg.com/[email protected]\" integrity=\"sha384-EzBXYPt0/T6gxNp0nuPtLkmRpmDBbjg6WmCUZRLXBBwYYmwAUxzlSGej0ARHX0Bo\" crossorigin=\"anonymous\" defer></script>\n\n    {% block footer %}{% endblock %}\n  </body>\n</html>","x":120,"y":280,"wires":[]},{"id":"754c717efb65ad56","type":"nunjucks","z":"e78f061152fe82f8","name":"navbar.html","template":"<nav class=\"navbar navbar-light bg-light fixed-top\">\n  <div class=\"container-fluid\">\n    <a class=\"navbar-brand\" href=\"#\">{{ app.name }}</a>\n    <button class=\"navbar-toggler\" type=\"button\" data-bs-toggle=\"offcanvas\" data-bs-target=\"#offcanvasNavbar\" aria-controls=\"offcanvasNavbar\">\n      <span class=\"navbar-toggler-icon\"></span>\n    </button>\n    <div class=\"offcanvas offcanvas-end\" tabindex=\"-1\" id=\"offcanvasNavbar\" aria-labelledby=\"offcanvasNavbarLabel\">\n      <div class=\"offcanvas-header\">\n        <h5 class=\"offcanvas-title\" id=\"offcanvasNavbarLabel\">{{ foo.bar.baz }}</h5>\n        <button type=\"button\" class=\"btn-close text-reset\" data-bs-dismiss=\"offcanvas\" aria-label=\"Close\"></button>\n      </div>\n      <div class=\"offcanvas-body\">\n        <ul class=\"navbar-nav justify-content-end flex-grow-1 pe-3\">\n          {% for link in links %}\n            <li class=\"nav-item\">\n              <a {{ link.attributes | attr | safe }}>{{ link.label }}</a>\n            </li>\n          {% endfor %}\n        </ul>\n        <form class=\"d-flex\" action=\"/example/search\">\n          <input class=\"form-control me-2\" name=\"q\" type=\"search\" placeholder=\"Search\" aria-label=\"Search\" value=\"{{ request.query.q }}\">\n          <button class=\"btn btn-outline-success\" type=\"submit\">Search</button>\n        </form>\n      </div>\n    </div>\n  </div>\n</nav>","x":130,"y":240,"wires":[]},{"id":"b9a2ff8d07d15421","type":"http response","z":"e78f061152fe82f8","name":"","statusCode":"","headers":{},"x":610,"y":80,"wires":[]},{"id":"b3f6875fd13c8c43","type":"nunjucks_render","z":"e78f061152fe82f8","template":"{% extends \"base.html\" %}\n\n{% import \"cards.html\" as cards %}\n\n{% block body %}\n{% call cards.card(card) %}\n  \n{% endcall %}\n{% endblock %}","x":480,"y":80,"wires":[["b9a2ff8d07d15421"]]},{"id":"f9ba36f6f0a1145a","type":"function","z":"e78f061152fe82f8","name":"payload","func":"global.get('nj.addGlobal')('request', msg.req)\n\nmsg.payload = {\n    card: {\n        title: 'Search results',\n        text: `Searching for ${msg.req.query.q || ''}`,\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":80,"wires":[["b3f6875fd13c8c43"]]},{"id":"599b7390c55080e2","type":"http in","z":"e78f061152fe82f8","name":"","url":"/example/search","method":"get","upload":false,"swaggerDoc":"","x":160,"y":80,"wires":[["f9ba36f6f0a1145a"]]},{"id":"4cf30c301712f9c8","type":"function","z":"e78f061152fe82f8","name":"Nunjucks Global Context","func":"const _context = {\n    app: {\n        name: 'Nunjucks for Node-RED'\n    },\n    links: [{\n        label: 'Random Joke',\n        attributes: {\n            'class': 'nav-link',\n            'href': '/example/joke'\n        }\n    }]\n}\n\nObject.entries(_context).forEach(([key, value]) => {\n    global.get('nj.addGlobal')(key, value)\n})\n\n","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":420,"wires":[]},{"id":"7f7ef0cd9623ebab","type":"inject","z":"e78f061152fe82f8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":420,"wires":[["4cf30c301712f9c8"]]},{"id":"2076215c31136a97","type":"function","z":"e78f061152fe82f8","name":"More Nunjucks Global Context","func":"const _context = {\n    foo: {\n        bar: {\n            baz: 'Hello Baz!'\n        }\n    }\n}\n\nObject.entries(_context).forEach(([key, value]) => {\n    global.get('nj.addGlobal')(key, value)\n})\n\n","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":460,"wires":[]},{"id":"ce4d3011a50a78ce","type":"inject","z":"e78f061152fe82f8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":460,"wires":[["2076215c31136a97"]]},{"id":"df10be42375fbc1e","type":"function","z":"e78f061152fe82f8","name":"Filters Example","func":"function myFilter(value) {\n    return `This is myFilter: ${value.toUpperCase()}!!!`\n}\n\nfunction attr(value) {\n    return Object.entries(value).reduce((prev, [key, value]) => {\n        prev.push(`${key}=\"${value}\"`)\n\n        return prev\n    }, []).join(' ')\n}\n\nglobal.get('nj.addFilter')('myFilter', myFilter)\nglobal.get('nj.addFilter')('attr', attr)","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":560,"wires":[]},{"id":"49bd7037b1599555","type":"inject","z":"e78f061152fe82f8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":560,"wires":[["df10be42375fbc1e"]]}]
Version: 1.0.10
Updated 4 years, 5 months ago
Rating: 5.0 2
1 in the last week
  • nunjucks
  • nunjucks_render
  • nunjucks
  • templating
