node-red-contrib-numbertoascii 1.0.0
A Node-RED node to convert 16-bit, 32-bit, 64-bit, or 128-bit numbers into ASCII strings with endianness support.
npm install node-red-contrib-numbertoascii
Convert numbers into ASCII character sequences in Node-RED.
Overview
This Node-RED node takes a numeric input and converts it into:
  1. An ASCII character array (based on 3-digit and 2-digit ASCII encoding rules).
  2. A final ASCII string that represents the extracted characters.
To install this node, run:
Input
The node expects a numeric value (either as a number or a string).
Each 2-digit or 3-digit segment of the number is interpreted as an ASCII code.
Output
The node outputs an object with:
  • asciiArray: An array of ASCII character codes.
  • asciiString: The corresponding ASCII text.
Example Inputs & Outputs
Example 1
📥 Input: 6566676869
📤 Output:
    "asciiArray": [65, 66, 67, 68, 69],
    "asciiString": "ABCDE"
Example 2
📥 Input: 1106577110
📤 Output:
    "asciiArray": [110, 65, 77, 110],
    "asciiString": "nAMn"
Example 3
📥 Input: 123656667101120656667
📤 Output:
    "asciiArray": [123, 65, 66, 67, 101, 120, 65, 66, 67],
    "asciiString": "{ABCexABC"
How It Works
  1. Splitting the Number:
    • The node tries to extract 3-digit ASCII codes first (if valid).
    • If not, it falls back to 2-digit ASCII codes.
  2. Conversion to ASCII:
    • The extracted numbers are converted into their corresponding characters.
  3. Error Handling:
    • If an invalid ASCII sequence is found, an error message is displayed.
    • The input must be numeric (not raw text).
Node Properties
  • Name (optional): A custom name for the node.
Installation in Node-RED
  1. Open Node-RED.
  2. Go to Manage Palette → Install.
  3. Search for "node-red-contrib-numbertoascii" and install it.
Alternatively, install via command line:
Then restart Node-RED:
node-red-restart
📜 GPL-3.0 – Free to use, modify, and distribute.
Version: 1.0.0
Updated 1 year, 9 months ago
License: GPL-3.0
3 in the last week
  • numbertoascii
  • bufferstack10
  • ascii
  • modbus
  • register
  • binary
  • endian
  • 16bit
  • 32bit
  • 64bit
  • 128bit
  • string
  • converter
  • plc
  • automation
  • mqtt
  • number
