node-red-contrib-nuki 1.2.0
Interact with your nuki bridge locally
npm install node-red-contrib-nuki
Greenkeeper badge
Build and Publish
This node can control Nuki Smart Locks with the help of Nuki Bridges. Also Nuki Bridges can be handled by the node. It uses nuki-bridge-api based on the Nuki Bridge API documentation.
It enables you to connecto to your Nuki Smart Lock over a Nuki Bridge and control it directly from node-red. It also enables you to monitor the states and control the bridge itself.
Nuki Bridge API
How to get your hardware bridge token, which is a requirement for this node:
  • Call http://:/auth from any browser in your network. The bridge turns on its LED.
  • Press the button of the bridge within 30 seconds.
  • Result of the browser call should be something like this:
         "token":"token123",
         "success":true
  • Use the generated token in the nuki-brige Configuration property token
Nuki Web API
Do the following, to use the Nuki Web API - this is optional for this node!
  • Retrieve a token at https://web.nuki.io/de/#/admin/web-api
  • Use this token in the nuki-bridge Configuration on property WEB API Token
  • Make sure your nuki devices are published on the Nuki Web API (use the Smartphone App via Settings Activate Nuki Web)
Bridge Configuration
Configure a Nuki Bridge connection used by other nodes to communicate with the actual Nuki Bridge or Nuki Locks
Config Item Description
Bridge IP or Hostname of your actual Bridge
Port Default the bridge listens to 8080
Token your Token of the Bridge API Access
Bridge Callback Host The actual node-red installation access - must be http, https is not supported
WEB API Token Api Token to access the Nuki Web API ( web.nuki.io )
WEB API Fetch Interval The actual interval that is used to fetch data from web.nuki.io
Common Control on the Nodes
clearCallbacks
Removes all registered callbacks - if this option was configured
setupCallback
Registers the callback for the actual node ( bridge or nuki )
getCallbacks
Lists all registered callbacks - this is usefull if you get the error message that there are to many callbacks registered.
Control In
Send commands and queries to a Nuki Smart Lock. At the moment 2 actions are available which can be set as topic
lockStatus
query the lockStatus of the current lock. Possible states can be reviewd at state of nuki-bridge-api. Those are at the moment
UNCALIBRATED
LOCKED
UNLOCKING
UNLOCKED
LOCKING
UNLATCHED
UNLOCKED_LOCK_N_GO
UNLATCHING
MOTOR_BLOCKED
UNDEFINED
lockAction
Performs an action on the current lock. Actions are not validated within the node if they are valid - e.g. the lock is already unlocked and you send an unlock again. In this case the bridge itself manages this and does not try to unlock again. Available actions are directly mapped to the actions of nuki-bridge-api. At the moment those actions are:
UNLOCK
LOCK
UNLATCH
LOCK_N_GO
LOCK_N_GO_WITH_UNLATCH
webInfo
Query the information available from the WebAPI - if configured. Otherwise you just get no payload in the response
Bridge Control
Send commands and queries to a Nuki Bridge.
The nuki bridge supports various commands. At the moment the responses are directly forwarded as output payload and are not parsed. They are only enriched with the original topic and bridge information ( host and port ).
reboot
Of course this action reboots the bridge itself
fwupdate
Update the firmware of the nuki bridge. It is not possible right now if there is an update available!
info
Retrieve information about the bridge. The payload looks like following example
{"topic":"info","bridge":"192.168.1.100:8080","payload":{"bridgeType":1,"ids":{"hardwareId":234189529,"serverId":291317518},"versions":{"firmwareVersion":"1.12.6","wifiFirmwareVersion":"1.2.0"},"uptime":75492,"currentTime":"2019-05-09T08:09:20+00:00","serverConnected":true,"scanResults":[]},"_msgid":"e3cab797.caec98"}
log
Retrieve the current log from the bridge. Right now only the last 100 lines are reported even the api is available to page through the available logs
clearlog
Clear all logs on the bridge
Todo
  • Paging of Nuki Bridge logs
  • Nuki Smart Lock Door sensor support ( missing in nuki-bridge-api )
  • Nuki 3.0 Pro
Caveats
At the moment the door sensor is not support within nuki-bridge-api.
Version: 1.2.0
Updated 4 years, 9 months ago
Rating: 5.0 2
53 in the last week
  • nuki-lock-control
  • nuki-bridge-control
  • nuki-bridge
  • nuki
  • nuki-bridge
  • smarthome
