node-red-contrib-nuasense 0.1.2
Node-RED nodes for NuaSense: send weather-station readings to NuaSense and read back the station intelligence (tonight's low, the next spray window, ET0, leaf wetness, disease risk).
NuaSense for Node-RED
Two nodes that connect a Node-RED flow to NuaSense:
- station → NuaSense sends a reading to NuaSense exactly as an Ecowitt console would. Any station you already have in Node-RED — a Davis through weewx, a LoRaWAN sensor, a Modbus logger — becomes a NuaSense station.
- NuaSense intelligence reads back what NuaSense computes for a station: tonight's low and whether it is a frost night, the next calm dry daylight window for spraying, how the latest reading compares with the model, and the hourly values (ET0, leaf wetness, spray quality, VPD, delta T).
The first three stations on a NuaSense account connect free.
In Node-RED: Manage palette → Install → node-red-contrib-nuasense. Or:
cd ~/.node-red && npm install node-red-contrib-nuasense
Needs Node.js 18 or newer (the nodes use the built-in fetch).
Sending readings
- In the NuaSense console open External stations → Add a station, pick Home Assistant / weewx / Meteobridge / Node-RED, give it a name and a position. The last screen shows a path like
/station/kw7n-4hpd-x2vt. The part after/station/is the token. - Put the token into a station → NuaSense node.
- Feed it a message every 60 s whose
msg.payloadcarries the reading in metric units:
| key | unit | note |
temperature |
°C | |
humidity |
pressure |
hPa | station level (not reduced to sea level) |
wind_speed, wind_gusts |
m/s | |
wind_direction |
rain_total_mm |
mm | a counter that only grows; NuaSense turns it into increments |
solar_wm2 or light_lux |
W/m² or lux | |
uv |
index | |
time |
ISO 8601 | optional; now when absent |
Missing keys are simply not sent. The receiver keeps one reading per station per minute, so sending faster gains nothing.
The node's output carries the receiver's answer (status, body) and the form it sent, so a debug node shows exactly what went out.
Reading the intelligence
Make an API key in the console (API Keys, scope ingest:write — it covers reading your own stations) and put it into a NuaSense intelligence node. Choose what to ask for:
- First look —
tonight(low_c,at,frost:none/watch/frost),spray(window.from,window.to,wind_max_ms, or areasonwhen there is no window),station_check(verdict:plausible/check/off, withreading_candmodel_c). - Computed hourly values —
data[]withet0_hour,lwd_hour,lwd_consecutive_hours,spray_quality_index,spray_quality_label,spray_limiting_factor,vpd,delta_t,dew_point,inversion_riskand the hourly means. - Stations — the stations on the account, with their position and last upload.
Trigger it with an inject node every 15–60 minutes.
Your data
When you connect a station, NuaSense stores its readings and computes your forecast, spray windows and risks from them. The readings are used aggregated and anonymised to improve forecasts and models for everyone; they are never passed on individually without your opt-in. You can disconnect the station in the console at any time and have all its data deleted.
Development
npm test
MIT licence. Issues and pull requests: https://github.com/nuasense/node-red-contrib-nuasense
