node-red-contrib-ntfy-nodes 1.0.0
Node-RED nodes for publishing and subscribing to ntfy notification topics — AI generated, provided as-is without ongoing maintenance
npm install node-red-contrib-ntfy-nodes
⚠️ AI-GENERATED — NOT MAINTAINED
This package was generated by an AI assistant (Claude by Anthropic) as part of a home-server automation project. It is provided as-is with no warranty, no active maintenance, and no guarantee of correctness or security.
Use at your own risk. Review the source code before deploying on any system you care about. Pull requests and forks are welcome but there is no commitment to respond to issues.
Node-RED nodes for publishing and subscribing to ntfy notification topics. Supports self-hosted and cloud ntfy instances, all ntfy publish features, and runtime configuration via msg.ntfyOptions.
Node Description
ntfy-config Shared configuration — server URL and credentials
ntfy-send Publish a notification to a topic
Via Node-RED Palette Manager
Search for node-red-contrib-ntfy in the Manage Palette dialog.
Via npm (in your Node-RED user directory)
Local install for development
npm install /path/to/node-red-contrib-ntfy
Requirements
  • Node-RED 3.0 or later
  • Node.js 18 or later
  • A running ntfy server (self-hosted via Docker or ntfy.sh)
Quick start
  1. Add an ntfy-config node (via the Server dropdown in any ntfy node)
  2. Set the server URL — e.g. http://ntfy:80 for a local Docker instance
  3. Choose an auth type and fill in credentials if required
  4. Drop an ntfy-send node, set a topic and connect msg.payload as the body
  5. Drop an ntfy-in node, set the same topic, and wire its output to a debug node
ntfy-config
Shared configuration node. Not placed on the canvas — referenced by ntfy-send and ntfy-in via a Server dropdown.
Auth types
Type Description
None No authentication. Suitable for local instances with open topics.
Username & password HTTP Basic auth.
Access token Bearer token. Create tokens in the ntfy web UI or CLI.
Custom headers Supply arbitrary Key: Value headers one per line. Useful for reverse-proxy auth.
ntfy-send
Publish a notification. The message body comes from msg.payload unless overridden.
All string fields in the node editor support Mustache templates resolved against the incoming message. For example, set Topic to {{payload.topic}} to use a dynamic topic from the message.
Node editor fields
Field ntfy header Description
Topic URL path Target topic name. Required.
Title Title Notification title. Defaults to topic URL if blank.
Priority Priority 1 (min) to 5 (urgent/max). Default 3.
Tags Tags Comma-separated emoji shortcodes or plain tags.
Click URL Click URL opened when the notification is tapped.
Icon URL Icon URL of a notification icon image.
Attach URL Attach Attach an image or file from a URL.
Filename Filename Override the filename for the attachment.
Actions Actions Action button definitions (see ntfy docs).
Forward email Email Forward the notification to this email address.
Delay Delay Schedule delivery e.g. 30min, tomorrow, 9am.
Markdown Markdown Enable Markdown rendering in the notification body.
Cache Cache Override server caching: yes or no.
Firebase Firebase Override Firebase delivery: yes or no.
Runtime override — msg.ntfyOptions
Set msg.ntfyOptions to override any field at runtime. All fields optional.
msg.ntfyOptions = {
    // Core
    topic:    "alerts",
    message:  "Custom body",   // overrides msg.payload
    title:    "Alert",
    priority: 4,               // 1–5 or "min"/"low"/"default"/"high"/"urgent"/"max"
    tags:     ["warning"],     // array or comma-separated string
    // Formatting
    markdown: true,
    // Actions
    click:    "https://example.com",
    icon:     "https://example.com/icon.png",
    actions:  "view, Open dashboard, https://example.com",
    // Attachment
    attach:   "https://example.com/photo.jpg",
    filename: "photo.jpg",
    // Scheduling
    delay:    "30min",
    // Forwarding
    email:    "[email protected]",
    // Advanced
    cache:    "no",
    firebase: "no",
    id:       "msg-abc123"     // for updating/deleting existing messages
Output
On success the original message passes through with msg.ntfyResponse set to the parsed JSON response from the ntfy server.
Status
Colour Shape Meaning
Blue Dot Sending
Green Dot Sent successfully
Red Dot Error — check debug panel
Action buttons
ntfy supports up to 3 action buttons on a notification. Pass them as a string in ntfy's pipe-delimited format, or set msg.ntfyOptions.actions to a JSON array.
String format (node editor or Mustache):
view, Open dashboard, https://dashboard.example.com
Multiple actions (comma-separated in the Actions header):
view, Open, https://example.com; http, Restart, https://api.example.com/restart, method=POST
JSON array (via msg.ntfyOptions):
msg.ntfyOptions = {
    actions: [
        { action: "view",  label: "Open dashboard", url: "https://example.com" },
        { action: "http",  label: "Restart",         url: "https://api.example.com/restart", method: "POST", clear: true }
Examples
Simple alert
[Inject] → [ntfy-send: topic=alerts, title=Test]
msg.payload = "Hello from Node-RED" → sends a notification to the alerts topic.
Dynamic topic from message
Set the Topic field to {{payload.topic}} and send:
msg.payload = { topic: "user-sam", body: "Your report is ready" };
msg.ntfyOptions = { message: msg.payload.body };
Priority alert on error
[loki-watch: errors] → [Function: set priority] → [ntfy-send]
// Function node
msg.ntfyOptions = {
    topic:    "home-alerts",
    title:    "Container error detected",
    priority: 5,
    tags:     ["warning"],
Subscribe and forward to email
[ntfy-in: topic=alerts] → [email node]
// Function node between them
msg.topic   = msg.ntfyTitle || "ntfy notification";
msg.payload = `${msg.ntfyTitle}\n\n${msg.payload}`;
Runtime topic switch
[Inject] → [Function] → [ntfy-in]
// Switch the subscription to a new topic
msg.ntfyOptions = { topic: "production-alerts" };
Self-hosted ntfy with Docker
services:
  ntfy:
    image: binwiederhier/ntfy
    container_name: ntfy
    command: serve
    restart: unless-stopped
    volumes:
      - /mnt/user/appdata/ntfy/cache:/var/cache/ntfy
      - /mnt/user/appdata/ntfy/config:/etc/ntfy
    ports:
      - "80:80"
The Node-RED ntfy-config server URL for this setup would be http://ntfy:80 (assuming both containers share a Docker network).
Known limitations
  • File attachments (uploading a local file as binary) are not supported in ntfy-send. Use the Attach URL field to attach files from a URL instead.
  • The ntfy-in node uses the JSON HTTP stream endpoint rather than WebSockets. This is more reliable for long-running Node-RED deployments.
  • Scheduled message delivery (delay) is supported for publishing but ntfy-in will not receive scheduled messages unless scheduled=1 is added manually via a custom filter (not currently exposed in the node editor).
MIT — see LICENSE file.
This package was generated by Claude (Anthropic) and is not actively maintained. Use in production at your own risk.
Version: 1.0.0
Updated 7 months, 3 weeks ago
  • ntfy-config
  • ntfy-send
  • ntfy-watch
  • ntfy
  • notifications
  • push
  • alerts
  • no-maintenance-intended
