node-red-contrib-nsq 1.0.2
A NodeRED Node for Subscribing and Publishing to NSQ Topics
A NodeRED Node for Subscribing and Publishing to NSQ Topics.
Currently, each configuration node is only capable of connecting directly to an nsqd instance. Simply provide a host and port. Support for nsqlookupd may be added in the future.
Consuming Messages
Use the nsq-consumer node to subscribe to a topic channel. Optionally enable "Finish Immediately" to automatically "finish" the message. This node currently only supports one in-flight message at a time.
The node will reconnect automatically, and indicate "Ready" and the number of messages received since the last flow deployment.
If "Finish Immediately" is disabled, the message must reach an nsq-finish node before msg._nsq.timeout seconds (60 by default). You can optionally send the message to an nsq-touch node to extend the timeout by an additional msg._nsq.timeout seconds. Lastly, you can requeue your messages with the nsq-requeue node.
Each of the nsq-finish, nsq-touch, and nsq-requeue nodes only manipulate msg._nsq.
Producing Messages
Simply send a msg.payload and optional msg.topic to the nsq-producer node to send messages to an NSQ channel. The node does not manipulate the msg. In case of an error, the unmanipulated msg is sent on port 2.
Eample Flow
Below is the example flow depicted above.
[{"id":"815d6522.3a0368","type":"nsq-consumer","z":"7256ff08.e1332","connection":"bda31600.8aaee8","topic":"testTopic","channel":"node-red","finishImmediately":false,"x":100,"y":80,"wires":[["5a894cb9.61b1f4","e4d0d218.bf5e"]]},{"id":"bc186b0.bd2ff98","type":"inject","z":"7256ff08.e1332","name":"Send Foobar","topic":"","payload":"{\"foo\":\"bar\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":300,"wires":[["f4e9c3e0.052a7"]]},{"id":"5a894cb9.61b1f4","type":"debug","z":"7256ff08.e1332","name":"Message Received","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":310,"y":80,"wires":[]},{"id":"7180fa4f.bec1b4","type":"debug","z":"7256ff08.e1332","name":"Message Sent","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":580,"y":280,"wires":[]},{"id":"6bdd85f.dfa337c","type":"debug","z":"7256ff08.e1332","name":"Message Error","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":580,"y":320,"wires":[]},{"id":"f4e9c3e0.052a7","type":"nsq-producer","z":"7256ff08.e1332","connection":"bda31600.8aaee8","topic":"testTopic","x":340,"y":300,"wires":[["7180fa4f.bec1b4"],["6bdd85f.dfa337c"]]},{"id":"2dd89190.37329e","type":"debug","z":"7256ff08.e1332","name":"Message Finished","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":890,"y":120,"wires":[]},{"id":"f40381cb.e87ed","type":"delay","z":"7256ff08.e1332","name":"","pauseType":"delay","timeout":"45","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":280,"y":120,"wires":[["b4e17c43.39b61"]]},{"id":"e67f31.320c40d","type":"delay","z":"7256ff08.e1332","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":580,"y":120,"wires":[["91382503.521dd8"]]},{"id":"b4e17c43.39b61","type":"nsq-touch","z":"7256ff08.e1332","x":430,"y":120,"wires":[["e67f31.320c40d"]]},{"id":"91382503.521dd8","type":"nsq-finish","z":"7256ff08.e1332","x":720,"y":120,"wires":[["2dd89190.37329e"]]},{"id":"e4d0d218.bf5e","type":"delay","z":"7256ff08.e1332","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":280,"y":160,"wires":[["8fe9fb44.bf75c8"]]},{"id":"8fe9fb44.bf75c8","type":"switch","z":"7256ff08.e1332","name":"First Attempt?","property":"_nsq.attempts","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":440,"y":160,"wires":[["25867fe8.73f7a"],["3b7d3a34.ac9406"]]},{"id":"25867fe8.73f7a","type":"nsq-requeue","z":"7256ff08.e1332","name":"","delay":"15","backoff":false,"x":650,"y":160,"wires":[["904f9625.fa60e8"]]},{"id":"904f9625.fa60e8","type":"debug","z":"7256ff08.e1332","name":"Message Requeued","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":860,"y":160,"wires":[]},{"id":"3b7d3a34.ac9406","type":"nsq-finish","z":"7256ff08.e1332","x":620,"y":200,"wires":[["78659860.242738"]]},{"id":"78659860.242738","type":"debug","z":"7256ff08.e1332","name":"Message Finished","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":790,"y":200,"wires":[]},{"id":"bda31600.8aaee8","type":"nsq-connection","z":"","name":"Test","host":"nsqd","port":"4150"}]
